(#1451)
dMau1986's Avatar
dMau1986 dMau1986 is offline
Default 02-21-2011, 08:51 PM
Right now, map 4 is the same as stock in terms of fuel economy. But fixing that is on the to-do list!
I would like to make a plug for the econ map 4 and the exhaust flap bypass as well. Also, adjustable/lower stealth gauge hijacking (50%?).
Couple questions:
- Would you expect the new "economy" map 4 to yield much better fuel economy for highway driving than stock/Map 1? Do the turbos even produce boost at cruising speeds on stock/Map 1 mappings? (maybe a silly question, but I am no FI expert)
-Would you expect the final Map 5 to produce more power/boost on all stock cars than Map 1 (93 oct)?
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 02-21-2011, 09:12 PM
FWIW, I noticed about a 5 mpg spread between Jb3 map 0 and Map 5, all highway driving approx 400 miles.
Kongen71's Avatar
Kongen71 Kongen71 is offline
Default 02-22-2011, 12:08 AM
Originally Posted by Naptime
+1
+2 I have been running map5 for a couple of days now and did some 0-200 km/h yesterday. It feels very smooth but is it possible that it's faster than map 2? I got that feeling. Running 98 RON V-Power.
Default 02-22-2011, 12:29 AM
Hey guys, uploaded 2/21 firmware:
1) Revised map 5 algorithm from 0-20 steps down to 0-15 steps but with each step representing more of a boost change. Resulted in improved stability.
2) Lengthened window for increasing aggression 15%.
3) Revised map 1 to include a little more high rpm taper based off customer provided logs.
4) Fixed bug with aggression level resetting when entering command mode even if no map selection change is made.
Default 02-22-2011, 12:30 AM
Entirely possible. It will all very much depend on how close a fit map 2 was to your car prior.
moodi's Avatar
moodi moodi is offline
Car: 335I
Default 02-22-2011, 05:56 AM
I also felt like its faster than map2 ,throttle response is HIGHER...
i was running on map 2 ,i did some WOTs but the ffmax didnt change (=100) ,isnt it supposed to change?
I am now running map 5...lets give it some more time to adapt...
Kongen71's Avatar
Default 02-22-2011, 06:33 AM
I noticed that as well. After I updated to 2/18 the ffmax value was still 51. I changed it to 100. I thought it would change automatically with new firmware?!? Will try to run a log tomorrow.
tofu tofu is offline
Car: 335i e92
Default 02-22-2011, 08:32 AM
I understand map5 is safer due to autotune, but what about a scenario where it tunes to 16psi one night, and fuel or weather conditions suddenly take a turn for the worse after a morning refill? It does not learn until WOT high rpm 3rd and 4th gear runs, so what if a user unknowingly burns through first and second with unsafe autotune intervals set, when their "safe zone" is really only 12psi?
JHOOPS2 JHOOPS2 is offline
Country Roads!
Car: 2009 135i
Default 02-22-2011, 08:57 AM
It is a non issue at part throttle I would guess because the DME is constantly monitoring things and making adjustments.
Mods: FBO
Car: 335i e92
Default 02-22-2011, 09:04 AM
yes, we dont reach full boost at part throttle, but there (although seemingly unlikely) are people who may WOT in first and second and hit the autotune 16psi target unsafely, no?
Kongen71's Avatar
Default 02-22-2011, 09:26 AM
Terry - How long would it take to adjust back from 16 psi to let's say 12 psi? Especially interesting to know if we don't use the same gasstation all the time.
Default 02-22-2011, 11:07 AM
It will change itself if needed. The 100 default value we used was an average based on many cars so it's going to be very close in many cases.
Default 02-22-2011, 11:09 AM
1st and 2nd gear are not at all knock prone so there isn't much of a concern there. Besides I think people take the "safe zone" a little too literally. We've had customers running JB3 map 7 tune only with 2-3 major timing drops per gear for YEARS without issue! So a drop here and there is not an issue at all.
Default 02-22-2011, 11:10 AM
The algorithm is quick to drop boost and slow to raise it. You could get from 16psi down to 12psi in 10 seconds of WOT, but to go from 12psi up to 16psi would take a minimum of 50 seconds.
HondaGoneRogue's Avatar
HondaGoneRogue HondaGoneRogue is offline
They like my swag....
Default 02-22-2011, 11:32 AM
Awesome info.
2015 F36 - JB4 - VSRF CP/Tube/FMIC
square&level square&level is offline
Default 02-22-2011, 04:01 PM
That was fast, I barely had time to data log the 02/18 firmware. Can't wait to try it out.
Default 02-22-2011, 06:09 PM
2/22 Logs sent
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 02-23-2011, 01:25 AM
uoooooooohhhh !!!!
You have a firmware that is not out yet !!!! lol
Time is the best teacher
Too bad it kills all its pupils ....
E S P E S P is offline
Car: 335i convertible, JB4, Injen intake
Default 02-23-2011, 01:53 AM
Hey guys. Loving the Jb4
I am running intake and 95-98octane
Am I safe to run map 7 with auto tune?
Just installed new firmware
Default 02-23-2011, 02:32 AM
Sorry. Typo. Meant map 5 with auto tune?
Kongen71's Avatar
Default 02-23-2011, 03:02 AM
Originally Posted by infinity
uoooooooohhhh !!!!
it's out - check the first page
Kongen71's Avatar
Default 02-23-2011, 03:09 AM
Safe on map 5 - autotunes down to 12 psi which is lower than map 1 for stock cars. I have been driving on map 5 for some days now and it feels great - powerful and smooth Using 98 V-power, DCI and DP's. It takes a couple of days before it's fully adjusted though when you switch.
elsabor67's Avatar
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 02-23-2011, 04:19 AM
I Like Maps 1&2 with their aggresiveness and the power on tap, but I am really starting to like map 5. Very progressive and adaptable. I was mapswitching on the way to work this morning and you can definetly tell the difference.
Now to update and do some logs today!!!!
E90PAT E90PAT is offline
Car: 08 BMW 335i
Send a message via AIM to E90PAT
Default 02-23-2011, 04:39 AM
thats no joke! when i first istalled the jb i took her out for a spin and wasnt impressed, then driving home from school on the highway i overtake a truck DAMN! where did all this power come from??
Car: 08 BMW 335i
Default 02-23-2011, 04:40 AM
hey T does the jb4 revert to map0 when its cold engine?
