(#2026)
strotman1 strotman1 is offline
Car: Kia Stinger
Default logs - 04-13-2019, 10:21 AM
Hi Terry, can you please look over these logs. Note that I have not connected the fuel wires yet.
2019-04-13 12_27_45_Map-2.csv
2019-04-13 12_22_52_Map-1.csv
Default 04-13-2019, 06:33 PM
Originally Posted by CursingDingo
114.94 - 116.02 across four 12.3 runs.
Sounds right to me.
Attachment 85549
Attachment 85550
Seem fine. Am I looking for anything in particular?
Car: Kia Stinger
Default 04-13-2019, 07:23 PM
It was my first run with the jb4 and I wanted to make sure nothing seemed off. Thanks for taking a look.
Default 04-13-2019, 08:26 PM
Got it! You're clear for take off.
Maggei82 Maggei82 is offline
Car: Hyundai i30N
Default 04-13-2019, 10:46 PM
Veloster N / l30N
So I talked with a friend in South Korea and he talked with a friend (username is 1FastStagea)
The white wire from O2sensor is the red wire on engine harness side!
Car: Hyundai i30N
Default 04-14-2019, 01:22 PM
I did some log runs! Every run is 3th and 4th fear!
sym sym is offline
Car: Stinger
Default 04-14-2019, 05:13 PM
@Terry,
Finally made it out to the track. I have two 1/4 mile runs logged. Track conditions were pretty good, but I was hoping for better times. The times were identical to a 1/4 mile run before I added the WMI system last season.
Could you take a look?
I ran one run on Map 7 with WMI enabled since I knew the system was functioning and the tank was full.
I was running 98 octane race gas for this run so there shouldn't have been any octane concerns.
Default 04-14-2019, 09:02 PM
Originally Posted by Maggei82
Veloster N / l30N
Sounds good! At first glance logs look clean to me. Feel faster than stock I hope?
Default 04-14-2019, 09:05 PM
Originally Posted by sym
@Terry,
I expected a little more out of yours too, but traps were good in the 119mph range right? So I think the power is there.
Cobrajetguy Cobrajetguy is offline
Car: 2018 KIA Stinger GT2
Default Boost By Gear Settings - 04-16-2019, 07:44 AM
Getting ready to go to the drag strip this weekend and wondering what settings you have had luck with for boost by gear reduction for the best traction. My car is RWD and I got the GT2 so it has the factory LSD, I also have 285 summer tires on the back. I typically run map 2 and the car has an upgraded intercooler, intakes but is otherwise stock. Thanks,
Peter
Default 04-16-2019, 09:08 AM
I run -5psi in 1st and -2psi in 2nd most of the time. Good starting point anyway!
D-C D-C is offline
Car: Stinger
Default 04-16-2019, 12:36 PM
Terry could please check that my fuel wires are connected up and working correctly, I had to remove the JB4 for a service and want make sure everything is running fine.
Default 04-16-2019, 01:57 PM
Looks fine to me
D-C D-C is offline
Car: Stinger
Default 04-16-2019, 02:31 PM
Looks fine to me
Thanks mate
atr1 atr1 is offline
Car: Stinger GT
Default 04-16-2019, 04:33 PM
Hello
What should I look for in the logs to determine which level of meth additive I should use in Map8?
If boost is maintained at target level and ignition timings do not drop, then am I good to go?
So far I tried using 65 70 75 80 and 80 definitely feels faster, but I don't know what are the limitations to such a high setting. Is it only about fuel octane?
Default 04-16-2019, 05:16 PM
Timing advance is the main thing, as well as how boost is responding to the request.
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 04-17-2019, 06:08 AM
You gotta get out there and test launching in 2nd! I ran a 4.23 on Dragy, but it was 'invalid' at -1.53% slope at the very end of the run. I didn't have a need to lower boost when I ran that one; however, trying again yesterday I was getting sideways doing the exact same thing on a different road. Only managed a 4.30 which was valid, but not impressive. I would think your car could hit 3.9's launching in 2nd if you don't need to reduce boost
Default 04-17-2019, 08:18 AM
It's on the to-do list. Car is over at Fuel-IT in the next state right now. Hope to get it back in a couple weeks.
P4RTYH4RTY P4RTYH4RTY is offline
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 04-18-2019, 12:22 PM
Summer is coming, and the Sacramento heat won't be kind without a BMS Intercooler...
We're waiting!
Default 04-18-2019, 02:10 PM
We're working on it. Stuff always takes longer than expected it seems. =/
Car: Stinger GT
Default 04-18-2019, 03:48 PM
Will it be useful on top of the WMI kit?
Car: Hyundai i30N
Default 04-18-2019, 04:25 PM
Hello Terry,
i did some test runs. Can you have a look on it?
Map3 feels verry strong
Default 04-18-2019, 04:39 PM
There is certainly some overlap. WMI benefit really comes down to fuel quality and E85 access.
Default 04-18-2019, 04:41 PM
Hello Terry,
The 2l logs always freak me out for a moment because I think I'm looking at a 3.3L log and wondering why boost is so high.
Log looks great, timing is solid. I'm going to work on a dedicated 2l firmware or setting soon to get road speed logging working for them. Look for that soon.
