(#1126)
Daily Three Daily Three is offline
Default 06-19-2017, 07:01 AM
i should probably chime in here.. i am running PI via the orange wire through the second output. I'll send my logs over to Terry to get his thoughts, but looks good so far overall.
Default 06-19-2017, 01:38 PM
Originally Posted by _ink
Hey Steve, my meth settings are:
Meth Safety: 2
Meth Trigger: 1
Meth safety must be set to 3 if you are running meth and no return signal.
kt0510's Avatar
kt0510 kt0510 is offline
Car: e92 335i
Default 06-24-2017, 02:06 AM
I need some instructions for dummy .
I cople questions about JB4 PI controller assembly.
First, instructions im page 1 says:
"Purple goes in the JB4 small gray subconnector #21 as read from the female side"
Doers this mean that side of subconnector where all wires are red?
And the blue wire from controller, that is going to stage 3 lpfp relay?
Hope You understand my poor English, and help me whit thease issues
edit:
My JB4 box is 2013, do I need new chip to JB4?
F20 M135 xDrive 445 bhp
Ex:E92 335iA N54 610 bhp, E93 335iA N54 460 bhp
Default 06-25-2017, 11:12 PM
Blue wire is not used at this time.
Pin 21 as labeled on the stock female connector.
Yes, you will need the anti-lag chip.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 06-26-2017, 03:44 AM
Do you need to be on a particular version of firmware for this Steve? No joy here.
Default 06-26-2017, 05:00 PM
Not sure what you mean.
You have safety set to 3 and trigger set to 1?
kt0510's Avatar
Car: e92 335i
Default 06-28-2017, 07:12 AM
Thaks Steve
So how does the second pump activate in LPFP if BMS JB4 TBI controller is not given that information? I dont use hobb's switch...
Pin 21 as labeled on the stock female connector..
Yep, I got it now, but I sill don't understand why you can't just say
male side of connector, slot 8?
Yep, I just make an order.
Default 06-28-2017, 09:46 PM
TBI controller? You mean PI controller? If so, that doesn't use a Hobbs switch and the Hobb's switch can be used to trigger the secondary pump.
Female 21/Male 8 on gray connector = same thing but adding more instruction just tends to confuse people.
kt0510's Avatar
Car: e92 335i
Default 06-29-2017, 05:28 AM
Thank you Steve for your patience
Sorry, my bad, I mean PI controller. So I do not need a Hobb's switch because PI controller is trigger the secundary pump? (blue wire from controller)
Its not always so simple when you are not native english
guwakjai010 guwakjai010 is offline
Car: E92 335i
Default 06-29-2017, 05:48 AM
Just got my BMS PI Controller this week, i was going over the wires and went thru this thread, I saw that Blue is not used at this time but didn't really see much details on the Orange wire. Do i need to tape that off or use it somewhere?
Default 06-29-2017, 06:26 AM
it depends on how you intend to trigger the secondary LPFP. If your using a hobb's switch then yeah tape it off.. if not connect to the 12V coming from the trunk
Car: E92 335i
Default 06-29-2017, 06:34 AM
Ahh got it, thanks. Not doing secondary pump or anything so I'll just tape them off.
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 06-29-2017, 11:55 AM
To simplify things, is there a wiring diagram drawn up for the BMS PI controller on the download page? I think that would clear up much of the confusion and keep you from answering the same questions over and over.
kt0510's Avatar
Car: e92 335i
Default 06-29-2017, 12:55 PM
You mean this:
And in yhe box:
Dont find any mention about that blue wire...
Car: E92 335i
Default 06-29-2017, 01:00 PM
Originally Posted by kt0510
You mean this:
And in yhe box:
There no mention of the Blue Wire or the Orange wire. I read through most of the 46 pages in this thread and they were mentioned once or twice. It may be new or it may be something only with BMW PI controller.
Default 06-29-2017, 01:01 PM
Gets confusing as there are 2 different controllers (BMS and AIC), and then on the BMS some wire colors have changed or been added depending on vintage, and then 3 different applications for install (E N54, N55, F N55/S55).
kt0510's Avatar
Car: e92 335i
Default 06-30-2017, 06:01 AM
Only one question about stage 3 LPFP, if I don't use Hobbs switch, how I get trigger to secundary pump?
Or is Hobbs switch the only way to trigger LPFP (secundary pump)?
_ink's Avatar
Car: 335i DCT
Default 07-01-2017, 07:57 AM
As in, there was no option to be able to use meth and PI together when i initially installed (i was one of the early ones).
Now we are saying this can be done? So there must have been a firmware change for this to occur?
Default 07-02-2017, 11:32 AM
It's never suggested but it is possible. You have to turn off the meth safeties if the JB4 can't monitor the meth signal.
_ink's Avatar
Car: 335i DCT
Default 07-03-2017, 01:44 AM
Yes, Meth safety is set to = 1.
Do you have a photo of how the wiring should look when running PI and Meth?
N54QC N54QC is offline
Car: 07 BMW 335i
Default 07-05-2017, 05:49 PM
I think Terry answered your question on post 1110?
Default 07-05-2017, 05:51 PM
Meth safety would have to be set to 3 if there will be no feedback signal from the FSB.
_ink's Avatar
Car: 335i DCT
Default 07-08-2017, 07:01 AM
It is Steve:
mike_nazz mike_nazz is offline
Default 07-08-2017, 05:19 PM
Is there anyway to test fire the injectors using the bms controller with the car off to check for faulty injectors ?
Rsoxs19's Avatar
Rsoxs19 Rsoxs19 is offline
Car: 2007 335i e92
Default 07-08-2017, 05:27 PM
Thinking about getting port injection and stage 2 LPFP. I still have stock turbos so I was wondering if I would even make any more power with it? Also, would running 100% E85 ruin my injectors?
2007 335i e92 Montego blue. JB4 Tune, Backend flash, VRSF C4tless D P's, VRSF Intercooler, VRSF Chargepipe, VRSF Relocated inlets, HKS BOV, Beluga exhaust. 30% e85.
