erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Talking map 6 tuning anyone? - 10-29-2014, 11:22 AM
does anyone tuning for map6? never tried it before and dont know how to tune using map6. perhaps anyone is an expert of this would help?
my car mods are as below signature.
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 10-29-2014, 11:59 AM
Erwan35, according to your signature, your car makes 64 ft/lbs of torque
I'm guessing that isn't right.
2011 E92 N55 xDrive 6MT
erwan35's Avatar
Car: bmw 335i e92
Default 10-29-2014, 12:04 PM
64 torque of kg
dallas_jeff dallas_jeff is offline
Default 10-29-2014, 12:58 PM
It mainly makes sense to use map 6 on upgraded turbos. I'd stick with map 3 since you're using meth.
FC4 FC4 is offline
Car: 435i
Default 10-29-2014, 01:27 PM
Question on Map 6 tuning...what exactly are the parameters open to tuning? One setup which I'd like to experiment with would be a map similar to the "M Map" on the S55 cars for my 435i with a rising boost target. Basically stock or close to stock boost values in lower RPMs with boost coming on stronger up top. Of course this won't result in a faster car, but now with map switching so easy, it would be nice to have a different feeling powerband.
Example, say we run proper fuel and Map 7 logs look great. Using the same fuel, could we simply adjust boost targets to climb by RPM (never exceeding Map 7 targets at any RPM point). Would everything else adjust accordingly?
Default 10-29-2014, 01:33 PM
It can be played around with. It generally allows adjustment of the boost profile and then the JB4 will try to compensate the duty cycle curve, fueling, etc, to match. Not all boost profiles are plausible especially at higher RPM but its something you can play with as long as you know how to read your logs.
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 10-29-2014, 06:06 PM
I have used Map6 a lot but in my experience, Map7 boost levels/curve works best for all around performance if you have the supporting mods. There is really little to be gained going more aggressive than Map7 boost targets from 5k and above. I have tried more boost and there is very little gain which I have documented on the dyno. The gains were <10 hp from increasing boost 2-3 psi over Map7 in the 5k and above range. Not worth it. From 4.5k and lower, you can certainly increase boost vs Map7 which will yield a nice torque increase (20-30 lb ft seen on DJ), but imo it's not necessary for other than dyno glory.
Whatever you do, just make sure you log and have the mods and fueling to support more aggressive tuning. The best time to test these changes is on the dyno.
335is DCT
erwan35's Avatar
Car: bmw 335i e92
Default 10-29-2014, 08:22 PM
Yeah true that
Bullitt1841's Avatar
Default 10-29-2014, 10:26 PM
I would put money on the likelihood of getting extremely bored with a map like that. Once you feel the low end torque gain, the "rising boost map" will feel really silly IMO. If you want that feeling, get a big single turbo
JB4UK JB4UK is offline
Car: F80 M3
Default 11-02-2014, 06:20 AM
The ///M map on the S55 is ideal for driving in the slippery conditions here in the UK at the moment.
Performance Centre - Large stocks of Burger Motorsport products with UK Nationwide fitting and dyno testing. http://www.theperformancecentre.co.uk/#!shop/c22lx
