barker2405 barker2405 is offline
Car: F10 535i
Default Fastest F10 535i - 04-11-2013, 05:07 PM
I wanted to start a thread for all the F10 modders out there. Just list your mods and what your looking to do in the future.
JB4 Stage 2
Flex Fuel (40%-E85)
Axle Back exhaust
Resonator Delete
RSi Ctls DP
Car: e90 lci n55
Default 04-15-2013, 01:20 AM
stock, ran a 14 flat.
ERnie
2011 AW/e90/n55 -gone
2016 AY F82
DinoNac's Avatar
DinoNac DinoNac is offline
Car: F10 535xdrive
Default F10 N55 mods - 08-23-2013, 12:45 AM
2011 535xi, RSI ******* DP, meisterschaft gts exhaust, bmw sci, jb4 stage 2. I can't get the boost I'd like to see from the stock turbo, not much past 16 psi. I'm considering meth but I'm being good it may not do much more than the cam2 100 octane. I'd also like to find an fmic but haven't been able to find one that will fit yet.
DinoNac's Avatar
Car: F10 535xdrive
Default 08-29-2013, 07:59 PM
Update on the FMIC. Tuning Technology Motorsports is currently in the process of installing the COBB FMIC for the 335, custom fitted to my 535. I do intend to Dyno the car after the install so Ill have much better idea of exactly what I'm generating.
Attachment 14461
2011 F10 N55 xDrive MSport
BMS JB4 STG 2, BMS SCI, COBB FMIC, Dr. Euro CTLS DP AA Custom CP, MEISTERSCHAFT GTS
Triple Mishimoto 12" fans, with Dual Drerale Controllers
Flex Fuel Connectors, 45% E85
BMS 2.3 METH Kit, 30% tint, BMS HID Fogs
DinoNac's Avatar
Car: F10 535xdrive
Default Cobb fmic - 08-29-2013, 08:02 PM
Attachment 14462
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Administrator
Car: M340i,X5,Raptor,C7 ZR1
Default 08-30-2013, 04:07 PM
Don't forget the BMS F10 Performance intake.
http://www.burgertuning.com/f10_535i...ce_intake.html
Applications:
BMW 5 Series
• 2010+ F10 535i Sedan
• 2010+ F10 535iX Sedan
• 2010+ F10 Hybrid 5 Sedan
• 2012+ F11 535i Touring/Sports Wagon
• 2012+ F11 535iX Touring/Sports Wagon
• 2012+ F11 Hybrid 5 Touring/Sports Wagon
BMW 6 Series
• 2011+ F12 640i Convertible
• 2011+ F12 640iX Convertible
• 2011+ F13 640i Coupe
• 2011+ F13 640iX Coupe
• 2011+ F06 640i Gran Coupé
• 2011+ F06 640iX Gran Coupé
DinoNac's Avatar
Car: F10 535xdrive
Default 08-30-2013, 04:21 PM
It was done around the same time I had my RSI ********* from BMS installed.
DinoNac's Avatar
Car: F10 535xdrive
Default 09-08-2013, 11:17 AM
Ok so here it is. The IC install was completed successfully. Because the stock fan would not fit with the IC installed it had to be removed. In its place are 3 12" low profile 1200 CFM fans, dual fans on the back of the IC pulling and a single in front pushing. They are controlled by temperature sensitive probes placed in the fins of the condensers and work very well, better in fact than the stock fan. If need be I could actually put s larger fan in the front but it was not necessary. They are wired into the battery and the controllers, into the start/stop fuse, and the setup works GREAT. The stock fan motor is mounted out of the way, still connected so the ecu senses it and avoids error codes, I am going to see if there's a way to remove it completely at BMW, but if not its really not a concern.
IAT's are fantastic compared to prior to the IC, at the end of a pull IAT was exceeding 160° with approx 70° ambient, now I'm seeing 90° with approximately the same ambient.... AWESOME! Also my engine oil temp is a good 20° less than prior to the custom fan setup. It was not an inexpensive modification, and I dont know that I would have done it prior to doing met if I knew the cost prior to beginning the install, but it was successful nonetheless and now the COBB N55 IC is installed and functioning very well. Short shifting combined with the lower IAT during pulls has significantly improved performance, especially top end.
Next up BMS meth kit.
DinoNac's Avatar
Car: F10 535xdrive
Default 09-16-2013, 08:54 PM
Now that ive done fbo with the installation of the IC, tomorrow the next modifications will be done. The BMS 2.3 meth kit and the active autowerkes N55 charge pipe are being installed beginning tomorrow. Once again part of this installation will be custom, the CP is for the 135/335 not the 535 so, my installer (camber toe, lynbrook, ny) will have to make a custom modification to the cp. Not sure if anyone is interested but i will post an update when finished. Since the title of this forum is fastest 535, I think its appropriate to mention that with the p3 indicator i recently had installed, I ran a 4.31 0-60 the other day on run flats and on a slight upgrade, so I think without the mods being done now I could get into the 4.2s and hopefully 3s with the meth and better rubber.
CyclePimps's Avatar
CyclePimps CyclePimps is offline
Car: 2012 F10 535i
Default 09-24-2013, 12:22 AM
Hey DinoNac,
I'm interested so keep up the good work.
Here's my info: 2012 F10 535i
Current mods: BMS Stage 1, F10 M5 OEM exhaust
Future mods: BMS JB4 Stage 2 upgrade
DinoNac's Avatar
Car: F10 535xdrive
Default 09-24-2013, 11:47 AM
Meth kit and CP installed by CAMBER TOE , 659 Merrick Rd, Lynbrook, ny. They did an outstanding job for a more than reasonable rate. They were professional, thorough, creative and highly skilled. I cannot say enough about how well they performed. The meth kit has made a significant improvement with IAT's, psi and performance, as gauged by my butt dyno. Actual dyno jet #s will follow. Also the custom modification to the charge pipe is a work of art in my opinion.
Pitch Black's Avatar
Pitch Black Pitch Black is offline
Prodigal Son
Car: 535xi
Default 09-24-2013, 03:17 PM
Sweet. I heard they did a Meth kit in a 5 recently.
Current Ride: Still picking one
DinoNac's Avatar
Car: F10 535xdrive
Default 09-25-2013, 08:12 AM
Yes, that was me. Thank you for the reference. They've done excellent work so far.
DinoNac's Avatar
Car: F10 535xdrive
Default 2011 F10 N55 AWD MSport FBO+METH(boost juice) - 09-29-2013, 03:02 AM
For those who expressed an interest in seeing some logs for the f10 N55 running meth, here you go. Ambient was between 53 and 58, Im running cam2 100 octane with 1 oz per gallon of Klotz octane boost, which claims to raise each gallon by 2.5 full octane numbers per oz added(I have not verified this however, I am just going by advertised gains, but the speed shops I have found it in claim it is accurate and, nonetheless I have not tested it myself), PID Gain raised to 14 and default wastegate set to 100, running a JB4 stage 2, map7, Meth additive 75 and scaling 60.
I would like to add that BMS had to send me specific firmware to run map7 with the meth and I WOULD NOT run meth in map 7 without acquiring the firmware from BMS first. If you install Meth run in map3 as per BMS instructions, unless told to do otherwise by BMS themselves.
Attachment 15089
Attachment 15090
Attachment 15091
Attachment 15092
Attachment 15093
Attachment 15094
DinoNac's Avatar
Car: F10 535xdrive
Default 09-29-2013, 03:15 AM
Originally Posted by CyclePimps
Hey DinoNac,
I intend to Dyno the car later in the week, and what I can tell you now is that while I do not see an extremely large gain in peak boost (there was a gain of 2-3 psi), the most noticable improvement is the sustained boost/power throught the higher range of the power band in each gear. Where previously I would get a substantial drop in psi as the rpms reached the 5K range, now the boost curve stays relatively flat and there is no drop off in pull felt from my butt dyno as ther was before. I had pulled a 0-60 in 4.3 before meth, I think I'm in the high 3's now. Im just specuating because I havent been able to get to track yet. Thats also coming within the next 7-10 days.
oldman12's Avatar
oldman12 oldman12 is offline
Car: 535i
Default 10-10-2013, 12:57 PM
I personally am looking forward to the track time numbers myself. If your car hits the 3.s, you sir will have the new M5 numbers in sight!!!!!!!! WHOA!
http://www.motortrend.com/roadtests/...t/viewall.html
http://www.caranddriver.com/reviews/...ad-test-review
Dr-Euro's Avatar
Dr-Euro Dr-Euro is offline
Car: E36 BMW
Default 10-10-2013, 10:21 PM
Formally RSI...now Dr Euro
Daniel | Owner
DMRinstall@gmail.com
www.Dr-Euro.com
Follow Our *New* Mobile Install Thread HERE
DinoNac's Avatar
Car: F10 535xdrive
Default 10-11-2013, 05:12 AM
My apologies I thought it was one in the same, I did not realize that. I stand corrected, well regardless the Dr euro ********* was one of the best bangs for the buck I got with all the mods that were done to my car.
Default 10-11-2013, 01:36 PM
I saw your car at Camber Toe and actually looked at tank placement and some install issues with them. Didn't see the finished job but sounds like it worked out well.
DinoNac's Avatar
Car: F10 535xdrive
Default 10-11-2013, 02:02 PM
Yes all is well they're very good at CamberToe. Honest, reliable and very reasonable with their labor rates. Meth kit is in place and working well.
F01Boost F01Boost is offline
Car: 750I
Default 10-12-2013, 01:52 PM
Dino, any news on the track
2018 BMW F90 M5 - Dme Stage 2 D/P & mid pipe
2014 BMW 650 dme tune - Gone
2012 BMW 750i M Sport - JB Beta - Gone
2011 BMW 135 - JB tuned - Gone
2008 BMW 535i - Jb tuned - Gone
DinoNac's Avatar
Car: F10 535xdrive
Default 10-12-2013, 03:56 PM
I'm having an issue with when I attempt to do a 3rd gear log and WOT at low rpm in 3rd gear that I want to resolve before hitting the track and/or dyno. Hopefully will be resolved early next week. Regardless of whether I figure the problem out or not I will be hitting the track within the next two weeks. Will keep you informed.
Car: 750I
Default 10-12-2013, 04:23 PM
Sounds good, hope you get everything worked out. What are you thinking for 1/4 miles mid to high 12s?
DinoNac's Avatar
Car: F10 535xdrive
Default 10-17-2013, 11:26 PM
I'd be very pleased with those numbers mid 12's would be awesome but to be conservative I think high 12's are more likely, but you never know.
DinoNac's Avatar
Car: F10 535xdrive
Default 10-17-2013, 11:35 PM
Attachment 14461
Something to add about Tuning Technolgy in Long Island. I would not recomend them, based upon several reasons. they did the work reasonably well, although they had myu car for a full two weeks for a IC install. The custom fan setup is what took the most time, and I certainly wouldnt call them resonably priced. Most recently, I had taken my car to Camber Toe for CP, Meth kit etc. and was having some issues with the fan setup that Tuning Technology installled and when asking for some wiring information, didnt receive it, and when I asked them to try to resolve the fan issue, I received no response. So to be fair, they did get the custom IC to function, but in my opinion didnt follow through with issues down the line and refused to assist in the troubleshooting by responding that your current installer will just have to trace the wires. I was not pleased.
Camber Toe on the other hand, has been thourough, accepted responsibility for any issues related to their work, and have been resonable with all billing.
Dyno update, I finally have found an AWD dyno in my area(I believe) and should have some dyno numbers next week.
