chris0325's Avatar
chris0325 chris0325 is offline
Car: 08 335xi coupe
Default Atlanta - 07-28-2012, 07:46 PM
Is anyone in the Atlanta area?
Jnic335i's Avatar
Jnic335i Jnic335i is offline
Car: 08 E92 335i
Send a message via AIM to Jnic335i
Default 07-28-2012, 08:55 PM
Yep. Sandy Springs here.
JB4 | BMS DCI | UR DP | H&R | LC Z2s
chris0325's Avatar
Car: 08 335xi coupe
Default 07-29-2012, 05:30 AM
You ever go out to any meets or anything I'm not far from you I'm in Duluth off of pleasant hill. I might go down to the varsity this Thursday but never have anybody to roll with.
07-335i's Avatar
07-335i 07-335i is offline
Default 07-30-2012, 06:32 AM
I'm in Lawrenceville.
maxwell600 maxwell600 is offline
Car: 07 BMW 335i
Default 08-29-2012, 02:07 AM
Suwanee here.
I hang in Duluth all the time.
335iTT's Avatar
335iTT 335iTT is offline
Car: '07 335i
Default 12-03-2012, 02:26 PM
I just picked up a 335a week or so ago- I'm in Lawrenceville.
J
07-335i's Avatar
Default 12-03-2012, 02:29 PM
Congratulations. You will love it. I have done all the mods except turbos so anything you need to know just ask.
335iTT's Avatar
Car: '07 335i
Default 12-03-2012, 02:44 PM
Yah-
Loving it so far. I've got 7 mos of CPO warranty left... But sometime soon I'm looking at adding a couple things.
Been eyeballing the JB4 tuner, then (maybe after warranty expires) DCI setup, and *********.
I think 380-90whp would be fun in this car.
J
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Administrator
Car: M340i,X5,Raptor,C7 ZR1
Default 12-03-2012, 03:19 PM
Originally Posted by 335iTT
Yah-
J
You can get all that stuff with your warranty. Just put the JB4 tuner on MAP 0 when taking it in for basic service. Just remove the intake when taking it in. No big deal.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 12-15-2012, 06:21 PM
Just got a dp job done from a shop in Smyrna(I don't live there though), and sevice and fee was probably the best bang for the buck. The shop charged me only 2 hrs labor, and total came 178. Several shops offered me 4-5 hours with higher rates, and this shop was professional in making engines or building project cars charging only 2 hrs (it actually took exactly 3 hours) was a hard to miss offer. Anybody looking into dp(*********....of course....it is for off road usage only, right?), I'd highly recommend it. PM me for further details.
najin23's Avatar
Car: 335i CDV
Default 12-15-2012, 06:25 PM
Yah-
J
DCI set up....I've had two people with mixed reviews. But DP is definitely an improvement and you won't regret a bit.
najin23's Avatar
Car: 335i CDV
Default 12-15-2012, 06:26 PM
OH...don't get me wrong...I don't work for anybody. I am absolutely not in car related business or career.
335iTT's Avatar
Car: '07 335i
Default 12-26-2012, 08:39 AM
Over the weekend, I installed my JB4, DCI, and put new plugs in the car... Running great now!
Maybe all this wet crappy weather will go away so I can test this thing out
J
07-335i's Avatar
Default 12-26-2012, 08:57 AM
+1 on the crappy weather.
najin23's Avatar
Car: 335i CDV
Default 12-26-2012, 09:26 AM
+2
New plugs should do well. I did mine over the weekend also 45k miles on the clock, can't really tell the differences in performance, but the couple old plugs seemed pretty bad in shape. Just made me feel better though, and hopefully get a better mpg.
Has anyone tried NLS feature on G5?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
427GTO 427GTO is offline
Car: GTO, 335i
Default 12-26-2012, 10:47 PM
Sandy Springs here, just picked up my 335i as a Christmas gift to myself and joined the forum after using it to research before my purchase.
najin23's Avatar
Car: 335i CDV
Default congrats! - 12-27-2012, 08:58 AM
Congrats for a new/used car and for joining N54/55!
Northeastern Metro suburb, and pm me for any questions.
Know couple good shops also.
Have fun.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 12-27-2012, 10:41 AM
I'm a couple hours south of ATL but I make it up there on a semi-regular basis.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
najin23's Avatar
Car: 335i CDV
Default 12-27-2012, 10:55 AM
Just did a map 2 and map 5 this morning, and I can't tell any differences than map 3. Is meth injection for cooling the engine only? What does meth really do? My additive is set at 40 with 49/51 boost juice.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Xearo's Avatar
Because Racecar
Car: '08 135i
Default 12-27-2012, 11:01 AM
40 add may be a bit low. Meth injection is for raising effective octane (meth is ~104 octane) and for cooling the intake charge. What nozzle are you using? Set meth flow on oil temp and make sure its flowing correctly. You could try goin up to 50 and logging. As long as there aren't large timing dips in your logs you can probably go up a bit.
My setup is 60 add with a CM14 running 80/20 meth/water. Runs about 18.5 psi tapering to ~15lbs. I'll attach a log in a few.
EDIT:
-'97 318is - Daily
-'82 320i
najin23's Avatar
Car: 335i CDV
Default 12-27-2012, 11:38 AM
EDIT:
I think mine is CM7 or 10 whatever came with ww meth set up. Is CM14 better? More injection, i guess? My meth flows 100% upon my oil gauge. I will try 50 then. Now timing....you mean the Ign Advance in the log? What is the normal values?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
najin23's Avatar
Car: 335i CDV
Default recent log - 12-27-2012, 11:44 AM
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
drm916 drm916 is offline
Car: 08 335i
Default 01-10-2013, 09:04 PM
I am downtown ATL. picked my car up used from a friend about 4 months ago. Loving the car so far.
najin23's Avatar
Car: 335i CDV
Default 01-10-2013, 10:09 PM
Have fun.
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Car: 08 335i
Default 01-10-2013, 11:23 PM
Have fun.
I have thrown lots of money at it over the past 4 months.
Full Mtech body kit with IS diffuser
Coilovers
19in 230 style wheels w/ michelin SS
JB4 G5iso
Charge pipe w/ BOV
DCI
BMS *********
BMS DP fix
AMS front Mount
clutch stop
CDV
Tow hitch
Backup camera
Ipod adaptor
New shifter
Alum pedals
Rob Beck PCV
BMS oil catch can
Wheel spacers
Rolled fenders
Sunglass holder
Front Camera
CPE oil cooler (not yet installed)
UUC segmented kevlar clutch and flywheel(not yet installed)
Next up will be RB turbos with BMS backend flash, limited slip, rear bushings and sway bars. Possibly Meth..
