(#2126)
mushu614 mushu614 is offline
Car: '07 e92 335i
Default 04-26-2011, 09:07 AM
Terry,
any plans to do some work on the new 1 series M? since it's going to have the n54 engine
Default 04-26-2011, 09:22 AM
Originally Posted by mushu614
Terry,
Definitely! JB4 should be fully compatible.
303_335i's Avatar
303_335i 303_335i is offline
Default 04-26-2011, 09:51 AM
Originally Posted by Kevron
I just uploaded the new firmware, I have an '06 build and my iDrive didn't turn off. The iDrive thing doesn't bother me anyway cuz my stations would always change and then it would unmute so I just turn the volume all the way down when I make in-dash changes... Anyway, I tried out the CANflap option and I noticed that I can close it but then a few seconds later it just opens itself back up again, is that normal? I've never played around with the flap before today so I don't know when it's suppose to open or close but I thought it was suppose to stay closed at idle and low RPM conditions and that's why people were rigging it open...
I also have '06 build and the iDrive didn't turn off too.
SlicktopTTZ's Avatar
SlicktopTTZ SlicktopTTZ is offline
Turbo Lover
Car: 300zx TT, 1M
Send a message via Skype™ to SlicktopTTZ
Default 04-26-2011, 10:14 AM
i hope so
Car: '07 e92 335i
Default 04-26-2011, 10:19 AM
woo hoo! although i think that just makes my future decisions harder when it comes time to trade in the 335
Default 04-26-2011, 10:32 AM
I had a couple reports of 2008 models not turning off also. But reports of 2009+ models working fine. If you have a 2008 iDrive let us know if it works or doesn't.
ronnyb29 ronnyb29 is offline
Default 04-26-2011, 11:39 AM
Updated to the 4/20 firmware this morning with no problems. iDrive did not turn off on my 2007 after changing the setting. I will snip the zip tie off the exhaust line to check out the canflap tonight. Switched back to map 5 from map 2 and will see how it runs over the next couple days and then send you some logs.
Appreciate it!
indy99gpgt indy99gpgt is offline
Engineer
Car: 2008 BSM 335i Coupe
Default 04-26-2011, 11:43 AM
Map 5 feels pretty nice. Ive noticed a little bit more boost this time. Ill get some logs on my way home from the office.
2008 BSM 335i coupe-jb4.BMS intake.meth
1999 Pontiac Grand Prix-10.5PSI.PRJ LL Cam.supporting mods
magha magha is offline
Car: 2009 135i
Default 04-26-2011, 03:24 PM
Terry i dont see the 0420 firmware hex file only see the earlier version
Default 04-26-2011, 03:33 PM
Yep, we removed it after around 125 downloads to wait for any bug reports, etc.
Car: 2009 135i
Default 04-26-2011, 03:39 PM
oh damn i shouldve downloaded it last night was going to do it now and update the software. thx for the quick response. damn work coming in the way of a firmware update!!
Elie335's Avatar
Elie335 Elie335 is offline
;o
Car: E92 335i/320i
Default 04-26-2011, 04:23 PM
T, would it matter if I uploaded the 4/20 FW with the OLDER version of the jb4 interface software?
Lexcami's Avatar
Lexcami Lexcami is offline
Car: BMW 135i
Default 04-26-2011, 04:24 PM
Is there anything electronic/program related to the automatics for shifting? Or is there only a mechanical part to make it shift faster?
2009 135i auto, JB4, DP fix, Code 3 intercooler, RR *********, RR full intake system, custom 3in exhaust with Magnaflow pipe.
Bimmer Barney's Avatar
Bimmer Barney Bimmer Barney is offline
Car: 07 E90 335i
Default 04-26-2011, 04:31 PM
SUPER Lame! I want the new firmware. How long do we have to wait now???
LostMarine's Avatar
LostMarine LostMarine is offline
Car: E92 DCT ///M
Default 04-26-2011, 04:34 PM
i dont think you want to do that.
Elie335's Avatar
;o
Car: E92 335i/320i
Default 04-26-2011, 04:36 PM
I've done it and no problem so far....
PS: I will re-upload it now with the new interface software, but I was just wondering what could it do or be harmful ?
Default 04-26-2011, 04:41 PM
You can upload firmware using the older interface but logging, etc, won't work.
Elie335's Avatar
;o
Car: E92 335i/320i
actually it worked - I was able to log and I knew I had a boost leak because I was off the target within 2 PSI and the boost leak was found
Default 04-26-2011, 05:30 PM
Just don't expect it to work 100% or be accurate with mismatched firmware/interface.
Elie335's Avatar
;o
Car: E92 335i/320i
Default 04-26-2011, 05:31 PM
oh okay, re-installed the new interface software anyway
thesalg thesalg is offline
Car: 335xi
Default 04-26-2011, 08:28 PM
probobly has to do with the difference of the CIC idrive in 09+ models, and the CCC idrive in earlier models.
I can say that the radio auto on/off worked fine in my 09 335
Kevron Kevron is offline
Car: 2007 335i
Default 04-26-2011, 08:46 PM
Sweet beans! Lolz, we got an early release of the firmware! I'm gonna be getting some dyno runs in but not until the 14th of May so I don't think that's gonna help you much Terry, and I don't like logging on the street cuz I don't wanna chance getting busted doing a 4th gear pull....
Default 04-26-2011, 08:49 PM
Could be. I was hoping the commands we used would hit both models as we grab it at junction between the iDrive and the rest of the car. Once we confirm 2009+ only for those commands we'll add that to the documentation.
Found a little bug in the CANflap in 4/20 we're working on now. Apparently it will sometimes revert back to stock operation while driving. Also noticed it does not disable itself on map 0. Both easy fixes.
mcc mcc is offline
Car: 335xi
Default 04-26-2011, 09:01 PM
Meth requires a flow sensor setup and map 3.
I guess a better question is if I am in map 5 will the failsafe still work? I have no access to race gas so I am dependent on meth for octane. I know the JB4 will self adjust boost, but will it recognize meth flowing as higher octane to optimize performance?
Default 04-26-2011, 09:51 PM
No, the meth failsafe only works with map 3. If you are using meth you must use map 3 with a flow sensor.
