(#2076)
Jnic335i's Avatar
Jnic335i Jnic335i is offline
Car: 08 E92 335i
Send a message via AIM to Jnic335i
Default 04-21-2011, 02:43 PM
I just want the GOLF TEE CHEAT CODE PLEASE!
JB4 | BMS DCI | UR DP | H&R | LC Z2s
Hocky Hocky is offline
Default 04-21-2011, 02:45 PM
Any thoughts on adding a steering wheel option to adjust the meth boost adder values? Could be useful.... :-)
Default 04-21-2011, 02:48 PM
Originally Posted by Elie335
bump for the new fw with cooling max feature
The firmware we're testing now has CANflap but maxcool is still disabled. We did add a bunch of the CAN backend stuff we need to turn it on though.
mcc mcc is offline
Car: 335xi
Default 04-22-2011, 11:15 PM
Is meth injection suggested on map 5 or should i stick with just map 3?
m1bjr m1bjr is offline
Car: 335i E92
Default 04-23-2011, 04:01 AM
Any tweaks likely to the map5 algorithms Terry?
Default 04-23-2011, 08:47 AM
Meth requires a flow sensor setup and map 3.
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Default 04-23-2011, 10:24 AM
I'm really digging the boost guage in the fuel guage, nice work T!
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB4/ BT
thesalg thesalg is offline
Car: 335xi
Default 04-23-2011, 12:09 PM
Terry do you think I can benefit from the CPS module, or dont bother without doing meth/upgraded turbo's first?
Default 04-23-2011, 04:54 PM
*EDIT* Found a couple. Thanks!
Jnic335i's Avatar
Car: 08 E92 335i
Default 04-24-2011, 07:38 AM
Mr. Terry when are you going to release the new firmware?
[IMG]http://excellentmarketing.info/wp-content/uploads/2011/01/pretty_please_***.jpg[/IMG]
Default 04-24-2011, 09:58 AM
I sent it out to a few for testing. Will expand the pool when I get a little more feedback.
Throttle's Avatar
Throttle Throttle is offline
Car: 08' 335xi
Default 04-24-2011, 05:37 PM
Maybe this has been discussed, but can we adjust throttle sensitivity with the JB4? I get annoyed by the delayed throttle response in this car.
Lexcami's Avatar
Lexcami Lexcami is offline
Car: BMW 135i
Default 04-24-2011, 07:12 PM
What we need is to get this automatics to shift faster. It takes too long to grab the next gear.
2009 135i auto, JB4, DP fix, Code 3 intercooler, RR *********, RR full intake system, custom 3in exhaust with Magnaflow pipe.
Eric SS's Avatar
Eric SS Eric SS is offline
Car: 2013 335i M Sport
Default 04-24-2011, 07:48 PM
+1 on this. I would love the ability to adjust gas pedal input vs. Throttle %. That might be different than what the above quoted poster meant. Kind of like the new skool version of adjusting throttle cable cams on the carb before drive by wire.
Default 04-24-2011, 07:51 PM
No plans to adjust the throttle mapping with the JB4. Just push the gas pedal down further or wear heavier shoes.
Dirty Dog's Avatar
Default 04-24-2011, 08:12 PM
tofu tofu is offline
Car: 335i e92
Default 04-25-2011, 04:35 AM
alpina improved on this somehow
Default 04-25-2011, 11:16 AM
Added alpha firmware and interface to the first post to expand testing.
1) Corrected 135i metric mode to properly reflect speedo input selections.
2) Lowered maximum FFPID value in 1st gear.
3) Added integration for CPS/SLD module including CPS charting.
4) Added "CANflap" commands to menu 4 options 4 (disable/go back to stock) and 5 (always open). This feature adjusts your factory exhaust flapper.
5) Added octane and oxygen sensor adaption reset commands to menu 4 option 7.
6) Rescaled FFPID function down 400rpm.
7) Added RPM by RPM global adjustment of air/fuel additive and CPS offset.
8) Complete redesign of data logging input functions for expanding user adjustable fields needed for #7.
9) Added "restore defaults" command to reset all user adjustable values (except map and meth settings) to the default values. Command is automatically sent following a firmware update to avoid firmware/setting compatibility issues.
10) Adjusted AFR output to always reflect leanest bank at any given time. Previously bank2 was always displayed.
11) If using external LM1 wideband FutureUseD=2 causes JB4 to use that value instead of factory widebands for all AFR use including internal safeties and nitrous trigger.
12) Default "exp1" logging parameter is now low system fuel pressure. Setting FutureUseD=3 outputs DME liters per hour consumed. Setting FutureuseD=4 outputs road speed in KMH.
13) Added iDrive radio auto on/off commands for testing. To enable set FutureUseD = 10. When engaging command mode via steering wheel controls iDrive screen should turn off. When exiting command mode iDrive screen should turn back on. In early testing it appears functional for 2008+ iDrive models only.
Car: 335 coupe
Default 04-25-2011, 11:18 AM
yeeeehaw!
alpinedevil335's Avatar
alpinedevil335 alpinedevil335 is offline
Car: 09' 335i Sedan
Default 04-25-2011, 11:23 AM
Sick work T!
idrive fix and flapper work great!
indy99gpgt indy99gpgt is offline
Engineer
Car: 2008 BSM 335i Coupe
Default 04-25-2011, 11:24 AM
Cant wait to leave the office!!
2008 BSM 335i coupe-jb4.BMS intake.meth
1999 Pontiac Grand Prix-10.5PSI.PRJ LL Cam.supporting mods
JHOOPS2 JHOOPS2 is offline
Country Roads!
Car: 2009 135i
Default 04-25-2011, 11:33 AM
+1
Mods: FBO
Trickcruiser's Avatar
Default 04-25-2011, 11:37 AM
GREAT STUFF MR. T!!!
(all caps even)
Unlike these suckers that have to work in an office I work from home!
But it is raining here so it looks like Karma owns me... lol
N54TW's Avatar
N54TW N54TW is offline
Obsessed with his BMW
Car: E92 335i 6MT
Default 04-25-2011, 11:38 AM
Originally Posted by JHOOPS2
+1
+1
Terry, would you suggest those of us that are upgrading the interface to uninstall everything from the old interface first and then install the new one?
2014 335i M Sport: bootmod3 Stg 2, AA CP, CSF FMIC, GFB DV+, VRSF down-pipe, aFe stage 2 intake, KW Clubsport Coilovers, xHP Stage 3.
Default 04-25-2011, 11:41 AM
As long as you install from the same path each time there is no need to uninstall the old interface. If you try to install from a different path you'll get an error and must remove the old one first.
