(#2026)
prelude2perfect's Avatar
prelude2perfect prelude2perfect is offline
Car: '07 335i
Default 04-14-2011, 11:52 AM
The flapper valve control only took 30 min or so to code up. Was working OK in the garage, time for some real world testing later today. The next little project is around 8hrs of coding redesigning how the JB4 and interface pass user settings back and forth, to allow for the user adjustable AFR and CPS RPM curves. Quite boring work.
Sounds pretty boring, I started dozing off just reading about it
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
JHOOPS2 JHOOPS2 is offline
Country Roads!
Car: 2009 135i
Default 04-14-2011, 12:09 PM
Boring, but awesome!
Mods: FBO
Car: '07 335i
Default 04-14-2011, 03:43 PM
Well now that's outta the way, what's next Terry? Besides the CPS stuff I mean.
Best 1/4 ET: 11.4
marconi118 marconi118 is offline
Default 04-15-2011, 10:10 AM
what about adding to the wheel command menu the adaptation reset items:
Throttle
Lambda
AFR
Battery
Knock
Octane
VANOS
VVT
6AT
ECU Reset
Basically the same as procede....
This is important when changing maps or tune etc...
Default 04-15-2011, 10:17 AM
Most of the adaption resets are already in there, just not documented. It's one option that goes and resets everything. We'll document it in the next release. But resetting adaptions is not very important when changing maps or tunes.
saifsiddiqui saifsiddiqui is offline
Default 04-15-2011, 11:18 AM
Terry, I still haven't seen any conclusion to the launch control for automatics and xi's that don't have to worry about traction. I hate having to brake boost because I know it's not the best thing for the car so having a launch control of some kind would definitely be a lot better. Sorry I know the questions been asked a lot but I'm just looking for a solid answer. Thanks!
Default 04-15-2011, 11:47 AM
The launch control is the same thing as brake boosting. Only instead of only building say 4psi before pushing through the brakes we let it get up to around 6-10psi. If you have an objection to holding the brake and gas down at the same time, for whatever reason, launch control will also not be for you.
Default 04-15-2011, 11:52 AM
Do you think that it's harmful on our cars if we do it once in a while? I had a 97 540i back when I got my license. It was like 4 years old and I brake boosted once so hard that the radiator pipe broke off and it was a huge problem. Ever since then I've learned from my mistake.. lol
Default 04-15-2011, 11:56 AM
No issues with brake boosting. I've been doing it for years with the N54.
tofu tofu is offline
Car: 335i e92
Default 04-15-2011, 06:12 PM
how much time between launches on hot days? doing that generates A LOT of heat, no?
Default 04-15-2011, 06:18 PM
Normally at the track you get more than enough cool down between runs.
Default 04-15-2011, 06:21 PM
so with a launch control program id be at around 10 psi vs 4? Id still be down for that! Hope thats going to be an option soon.
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Default 04-16-2011, 12:58 PM
I finally got it installed today. I love having the extra power!
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB4/ BT
335why's Avatar
335why 335why is offline
Default 04-16-2011, 04:23 PM
When is the new update coming out?
2007, 335i, Auto
Default 04-16-2011, 05:27 PM
Making significant interface changes to allow for some advance features. Hope to have those done early next week. Then a few days for alpha testers, and if all is good we'll throw it up late next week. No promises though.
bnk bnk is offline
Default 04-16-2011, 05:44 PM
Do all the JB4 features work with an old 2006 Progman version?
Default 04-16-2011, 05:52 PM
Yes, except the built in ******** fix.
Elie335's Avatar
Elie335 Elie335 is offline
;o
Car: E92 335i/320i
Default 04-16-2011, 07:51 PM
I heard the FW is already on the first page ? :D:D
lilrocket58 lilrocket58 is offline
Car: 335xi
Default 04-17-2011, 08:22 AM
I finally found time to put in my JB4 w/ hidden USB wire in the glove box....Just in case the dealer needs to get in there. What a change! It's like driving a different car. Install took a bit longer but had no issues what-so-ever. If someone needs a hand with install around Beantown arean let me know. I'm willing to help.
Terry, So when are you running for President?
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 04-17-2011, 08:55 AM
yet not.
Time is the best teacher
Too bad it kills all its pupils ....
GtiGyver GtiGyver is offline
Talking 04-18-2011, 08:11 AM
Hi Terry,
wondering if you could make an option such that the flap would be manual open/close where we could force it open or closed all the time and/or have an RPM or throttle position trigger to open the valve.
So settings would be: stock, always closed, always open and throttle or rpm triggered.
Is that possible? I'm sure a few of us would be interested
Also, wondering if as part of the gauge hijacking, you could display the water temps in lieu of the oil temp until the water temp reaches a set threshold.
That would be awesome, and it would free up one of my gauges for meth in future
mobilefitt's Avatar
mobilefitt mobilefitt is offline
M3 Eater (m3eater)
Car: 07 E90 Non Sport...Sleeper
Send a message via AIM to mobilefitt
Default 04-18-2011, 09:36 AM
isn't it made to work that way in the first place?????
JB4 15ohm w/ FSB & CM10, ETS-FMIC, Evolution Race Works charge pipe, Forge DVs, AR *********, Injen dual cones, DIY catch can-vent to atmosphere, Koni FSD,TSW Donnington 18's, Bridgestone Potenza 760 Sports.
mobilefitt's Avatar
M3 Eater (m3eater)
Default 04-18-2011, 10:00 AM
I thought that the valve stayed closed during initial load (acceleration) and then when a certain rpm was reached that it opened automatically???
Default 04-18-2011, 10:55 AM
It's function is load-based, not RPM it seems, and we have no control over it *yet*.
Default 04-18-2011, 11:02 AM
Originally Posted by GtiGyver
Hi Terry,
We could do more with it. But why would you want an option to force it closed during WOT?
