(#1976)
DarkPhantom DarkPhantom is offline
Default 04-09-2011, 11:13 AM
Read the FAQ in the first post!
Yep, I'm blind :P
Default 04-09-2011, 12:02 PM
Originally Posted by Babyjoe1973
Terry waiting for new MAPs! Olf JB3 Maps were better!
Torben
No way, the JB4 maps are much better!
We have a lot of stuff in the works but can't promise a date for the next map release. Need to get a few more things done first.
GbreeE90 GbreeE90 is offline
Default 04-09-2011, 12:21 PM
Torben
Not sure if serious.
Jodi Jodi is offline
Car: 335 AT
Default 04-10-2011, 04:36 AM
Terry, can you give an approximate release date of the next map release?
I am planning to install LSD, FMIC and DP's next weekend and it will be great If I manage to update my JB4.
Thx
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Default 04-10-2011, 09:56 AM
Guys thanks for the answers about map 5 and map 2!
Terry yesterday my cell light was on (i´m sure that it is my ******* DP). I tried to read with my laptop but it said "no code found". Then I tried with the speedo and gave me some codes.
I selected the option "delete codes" with the laptop and bye bye cell light...
Why I cant read the codes with my notebook?
Default 04-10-2011, 10:01 AM
With the last laptop interface sometimes you need to read it twice for them to display.
WDBi's Avatar
WDBi WDBi is offline
Car: any
Default 04-10-2011, 08:07 PM
I know this had been asked a bunch but when or will we ever get a launch control feature
Default 04-11-2011, 12:08 AM
I <3 map switch feature via dash.
Default 04-11-2011, 09:17 AM
There is one in there for automatics running full slicks at the track. Need to do a little more refining though. At the moment people are cutting mid 1.6 60' times without it so hasn't been a big priority. Just brake boost up to 2400rpm and let her rip!
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 04-11-2011, 09:35 AM
I have found the sure fire way to get the best launches with my AT is to wait until the second yello light coming down before you brake hard and time the WOT just right. It is a transition thing ... takes practice ... but I cut better times this way. When brake boosting to 2400 too soon, I'd spin at the starting line, or push myself forward or even push through the lights.
Don't forget the value of the roll out: stage WAY back in the gate, then jump out with WOT on the last yellow light. My best result: 1.50 60' with drag radials at 15 lbs. psi.
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
WDBi's Avatar
Car: any
Default 04-11-2011, 02:59 PM
do you need to set something to do this?
so pretty much hit WOT at the last yellow light then release the brakes when green? what do you mean about the gates
Lexcami's Avatar
Lexcami Lexcami is offline
Car: BMW 135i
Default 04-11-2011, 03:24 PM
Where can I find more info on this?
2009 135i auto, JB4, DP fix, Code 3 intercooler, RR *********, RR full intake system, custom 3in exhaust with Magnaflow pipe.
Default 04-11-2011, 03:36 PM
It's blocked out right now until I get a chance to fix a bug. Would sometimes throw a CEL during staging. Not fun. But makes those 1.6 60's turn in to high 1.5s if traction permits. Keep in mind unless you're already running 11.50s or faster its probably not for you.
saifsiddiqui saifsiddiqui is offline
Default 04-11-2011, 04:53 PM
would this help out for xi's with just a jb4/dci? Would be cool to have an actual launch control without brake boosting
VictorFranko VictorFranko is offline
Car: 335xi
Default 04-11-2011, 07:55 PM
Oh yeah. I'd like to improve my 1.6s to 1.5s Where do I sign up?
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 04-11-2011, 08:39 PM
Are you starting in first or second gear?
prelude2perfect's Avatar
Car: '07 335i
Default 04-11-2011, 09:06 PM
Hey Terry, what about a real launch control for those with manuals? You know, if I'm sitting at the light with the clutch pedal on the floor waiting for the green, I want it to where when I press the gas pedal to the floor it only goes to a set rpm, ie 4k rpm's if thats where I get my best launch. That way we aren't feathering the gas pedal at the line and trying to watch the tach and the tree at the same time. I want to be able to just floor it and drop the clutch on the green. I have that on my Hondata S300 and it's a really great feature
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
OldBooster's Avatar
Car: 2008 135i AT
Default 04-12-2011, 05:23 AM
I launch in first gear (M1). I've never tried 2nd (M2) gear. But next time I'm racing on street tires I will try it.
When on my DRs, my MTs stick so well (with my LSD) I don't know if M2 launches would be necessary. (What would we do without all these acronyms?)
Bimmerocious Bimmerocious is offline
Car: 335 coupe
Default 04-12-2011, 07:06 AM
Default 04-12-2011, 10:30 AM
Probably isn't going to happen with this platform. Would require lots of work and extra hardware.
Car: '07 335i
Default 04-12-2011, 11:58 AM
Didn't expect that for an answer at all. I guess that with all the other amazing things you can do with this piggyback I assumed that something that simple wouldn't be hard.
Best 1/4 ET: 11.4
infinity's Avatar
infinity infinity is offline
metanol pawa!!
Default 04-12-2011, 01:16 PM
we had hopes for it
Time is the best teacher
OldBooster's Avatar
Car: 2008 135i AT
Default 04-12-2011, 01:18 PM
You manual guys can always put a block of wood under the gas pedal. Each 1/4" of wood = 500 RPMs.
DCTepper DCTepper is offline
Car: '07 SGM 335i
Default 04-12-2011, 01:26 PM
Tie a rope to it and yank the wood out from under the pedal after you launch.
LostMarine's Avatar
LostMarine LostMarine is offline
Car: E92 DCT ///M
Default 04-12-2011, 03:26 PM
OB, any worries about the halfshafts in our AT's?
also, doesnt 15psi affect your mph?
im actually gonna try and run this sucker this summer and want to learn from my elders
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Maximum996
