(#176)
Default 05-16-2020, 03:35 PM
I'd have to see the log for more specific advice on it.
Dgvr6's Avatar
Dgvr6 Dgvr6 is offline
Car: 2016 S6 and 2018 q50
Default 05-17-2020, 01:34 PM
Your new 1-3 log looks better, if anything the boost is conservative. You're running stock boost in 1/2 and then you can see the target come up in 3rd gear. Would have been good to see the top end of 3rd though since thats where you're first log was acting weird. AFR/timing look better. Anything less than 5* I start to consider as being too low and either up the octane or lower the boost. Your EWG settings look correct. See if you can get another full 3rd gear pull at some point so we can see if that first log was a fluke or is repeatable. You might also try map 0 or 1 for the same 3rd gear pull so we can compare.
Ddnspider, what do you think about the new logs?
I notice on run 4, 5 and 6 the double hump started to even itself out.
Maybe something to do with adaption or the FW can be making the curve do some funky things?
Car: q50
Default 05-17-2020, 01:43 PM
I think pull 5 looked the cleanest. Boost is reasonable, AFR is good, timing is pretty low down low but is increasing the entire pull ending in double digits so its happy. You should also consider playing with a map 6 custom map. Lot of people go that route too....but wont help with traction
Q50 Premium RWD
BMS JB4 w/ FW, WMI, EWG
BMS HE
Low cost LSD
BostonianToro BostonianToro is offline
Car: 2016 Q50 Red Sport AWD
Question 05-18-2020, 02:34 PM
Here are two runs, I upped the FF to 55, and left the boost by gear at 2 and 1. Everything looked good to me, thoughts?
Could only really do the runs on the highway, not from a stop. I will try and get one of those as well.
Default 05-18-2020, 04:42 PM
How well does your map0 boost match DME BT? Assuming closely then the EWG is well configured here. And as you run more aggressive boost targets like say map2 should see a more aggressive EWG profile to match.
Default 05-18-2020, 08:42 PM
OK, maybe I need a little more learning, but in all the guides to understanding the JB terms they say that you don't need to pay much attention to the DME BT, so how do I go about verifying what you said? Do I turn off the EWG and the FW with the Bits, and then do a run on map0 and then look at the boost ad see if it looks like what this last run's DME BT look like? (I think that is what you said).
Thanks again for the fast responses Terry, I'm loving these EWG. I think after I verify this map0, I will try upping a little of my map6 boost targets to be a little more aggressive, now that I know more of what I am looking for.
Default 05-19-2020, 03:10 PM
Yes log map0 and we can compare it, then you can raise or lower FF as needed to drive up WGDC and thus boost a little as needed.
Dgvr6's Avatar
Default 05-19-2020, 06:55 PM
Terry, on the initial WOT hit, WG is mostly closed— which sometimes makes boost come on abrupt. If I’m getting this correctly, would I be able to adjust the duty bias on the lower RPMs to about 40-45 and keep it default towards the mid range to overcome that?
The more I decide to climb in boost settings, the lower I should adjust the duty cycle (40-45) to negate boost spike accordantly, and maybe set default WG position a little more open 40 rather than 35?
Also, shift reduction setting at 60 with 100 meaning no WG reduction or MAX.
Default 05-19-2020, 07:13 PM
You can always play around with it to see what works for your specific situation. Lower shift reduction reduces WGDC drop and duration during shifts, higher increases the effect.
Dgvr6's Avatar
Default 05-19-2020, 08:02 PM
Sounds good, wanted to make sure I have the correct idea.
Thanks terry
importroller importroller is offline
Car: 2016 Q50 3.0t
Default 05-20-2020, 07:31 PM
For non RS owners, do we need to set any of the options to "ON", or is that RS models only?
Default 05-20-2020, 08:36 PM
You don't, that setting is for the RS models only
ClevelandMSR ClevelandMSR is offline
Car: 2018 Infiniti Q50 RedSport
Default Install Guide - 05-22-2020, 09:05 AM
Anyone have a guide to install these on the Q50 RS?
Default 05-23-2020, 08:42 AM
This is the best I could get today. It is not long, but wiwth the Map0 and EWG off, the baseline boost is similar to what the DME BT looked like in my previous runs, i think?
Default 05-23-2020, 10:24 AM
Looks fine to me here, psi mirrors DME_BT, so you can adjust FF as needed for your targeting. Value of 60 is popular.
guitaristguy313 guitaristguy313 is offline
Car: 2020 Infiniti Q50
Default 05-23-2020, 06:39 PM
Hey everyone. Just got the cables in today and installed. What sort of log should I take. I usually do 3rd gear from 25mph to bear red line. Does that apply for the ewg too?
Default 05-23-2020, 11:24 PM
Well I went out and did some 3rd gear pulls and some pulls from a dig. Running map 4 with 92 octane. Have some logs before EWG and after. Running with duty bias 50 across the board. FF 60, Auto shift boost reduction 60, and PID gain 20. Looking to get a second set of eyes on these. Thanks!
nofear72784 nofear72784 is offline
Car: Q50 RS
Default Yesterday, 09:51 AM
@Terry. How's this look? Waiting on my WMI kit to come in. 93 Oct. Been playing with the settings trying to wakeup the bottom end it was like an on off switch before. This feels good. Opinions pls
Car: Q50 RS
Default Yesterday, 10:17 AM
Did one more. Feels like it was breaking up a little could have been loosing traction though on the rough road... thoughts?
JP813's Avatar
JP813 JP813 is offline
Car: 2018 Infiniti Q50 Luxe
Default Got my EWG installed - Yesterday, 01:31 PM
Hi all,
Recent pull from 2nd thru 3rd with the FW and EWG enabled. Howís it look to you guys? It feels like itís running the best Itís ever ran
Frozen Boost 118 HE
AMS intakes
HKS Bov's
JB4 w/BT, FW & EWG
