(#1126)
Alonso Flores Alonso Flores is offline
Car: 330i series G20
Default 05-22-2020, 11:52 AM
Hi somebody help me about jb4 to n55 series 1, both tach does not match with the odometer numbering, i mean the tach to choice map 2 does not map with 2000 RPM
drwillb drwillb is offline
Car: 2012 n55 135i
Default 05-22-2020, 02:57 PM
Use steering wheel controls. Set it to 5-1 to calibrate for the 135 gauges.
2012 135i Mods: air scoops, CP, BMS filter, PS1, N20 TMAP, ADE FMIC, BMW PE, JB4, BMS BEF, 1M front body, full M3 suspension
Buzz@N55's Avatar
Buzz@N55 Buzz@N55 is offline
Car: BMW 335I 2012 E92 N55
Default 05-23-2020, 10:54 PM
I still need advice on which flash do I use for my car. I have a 09/2012 built 335i e92. Do I use the DME unlock version or the other based on that MHD you no longer need to do a bench flash? Also I have a DCT is there a file for this transmission or does this no apply? Thanks guys
Car: 2012 n55 135i
Default Yesterday, 05:28 AM
You want the 9E06 files. Bench unlock is no longer needed. iOS software just came out about a week ago so no Android device needed if you are an iPhone user. You will need the orange MHD WiFi adapter. Terry/BMS sells those.
I have a 6MT so can’t help with DCT other than to tell you that there is software to be uploaded for that.
Should be a very simple search
Buzz@N55's Avatar
Default Yesterday, 12:41 PM
I have a 6MT so canít help with DCT other than to tell you that there is software to be uploaded for that.
Maybe Terry know more about which file for DCT cars
