MNmaverick MNmaverick is offline
Car: 2022 X5 m50i
Default 2022 X5 M50i - recommend map - 12-02-2021, 06:43 AM
Hey all,
Short time lurker - first time poster. Sounds like the M50i is a n63r engine type? Anyways, it appears folks are recommending the map 1 vs 2 presently for a daily driver? Does that sound correct? I saw one map6 someone had custom built but unsure if anyone else has any more refined map 1 or map 2 like tunes they are running.
Thanks again!
Car: Evo VIII
Default 12-02-2021, 10:42 AM
Map 1 is less boost so naturally it will be easier on your mpg's. Although, it really only applies if you have a led foot. Map 2 also requires 93 octane or better.
Car: 2022 X5 m50i
Default 12-02-2021, 10:48 AM
In your opinion is map 2 stable enough to run as a daily driver?
phaser's Avatar
phaser phaser is offline
Car: X5 M50i
Default 12-02-2021, 03:10 PM
Originally Posted by MNmaverick
Hey all,
Thanks again!
I have a 2021 M50i and am condidering a JB4. Are you happy with it? Can you feel the torque increase, is the additional power linear? Very interested to hear.
Car: 2022 X5 m50i
Default 12-02-2021, 03:13 PM
Installing on the 13th so I guess we will find out! Not much feedback on custom maps or even if straying from map 1 for our engine is advisable…
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2022 X3 M40i
Default 12-02-2021, 03:32 PM
You have an N63B or TU3. I wouldn't run Map 2. I tried and it was significantly slower than Map 1, even with E30 in the tank. I think what has been said before is true, the Maps were designed around the N63R (TU2) engine, that only made 456hp and less boost. For the newer N63B, the turbos are bigger and make more boost, so adding 6psi to it puts us over 20psi, which the Maps weren't designed for. Causes them to lean out too much on the top end and hurts power.
Mike Levy
2022 Black Sapphire X3 M40i
Car: 2022 X5 m50i
Default 12-02-2021, 03:36 PM
Thank you for that insight - from my research on here that’s what I’ve been suspecting. I’m ok with Map 1, I assume further tuning and research will improve down the road. Jb4 still the way to go here over a racechip if I’m just doing stage 1 stuff?
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 12-02-2021, 07:51 PM
Yeah, JB4 is still the way to go.
Mike Levy
phaser's Avatar
Car: X5 M50i
Default 12-04-2021, 01:13 PM
Map 1 is +4 lbs.?
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 12-04-2021, 04:04 PM
Yep.
phaser's Avatar
Car: X5 M50i
Default 12-05-2021, 07:40 AM
Your M550i has the same engine as my '21 M50i.
How would evaluate the improvement with the JB4 in place on Map1. Is the increase in torque noticeable etc.? Thanks in advance for insights here as they seem difficult to find.
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 12-05-2021, 02:03 PM
It’s very noticeable. Thing pulls like crazy. If it ran like this from the factory, I think a lot more people would get these “base” V8s rather than the full blown M versions.
Mike Levy
Car: M550i
Default 12-05-2021, 02:13 PM
Map 2 on the 523hp motor is a bit wacky. Asking for 17-18psi at redline is just too much for these turbos.
phaser's Avatar
Car: X5 M50i
Default 12-05-2021, 04:30 PM
Thanks Mike, a noticeable bump over stock which I think is very strong will be mighty fine.
Car: 2022 X5 m50i
Default 12-06-2021, 02:54 PM
Thanks for the insight mike, much appreciated!
Antec800 Antec800 is offline
Car: 340ix
Default 12-12-2021, 07:45 PM
Any insight to this terry or anyone from bms? Seems quite worrying losing power on anything other then map 1 on newer n63s
Car: Evo VIII
Default 12-13-2021, 11:15 AM
Start uploading logs.
Car: 2022 X5 m50i
Default 12-13-2021, 11:20 AM
Any additional context on how to do that or what you’re looking for exactly? I think we were looking for more detail then one sentence…
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 12-13-2021, 02:00 PM
Nah, that’s not the answer. You guys gotta get one in house and actually tune it instead of relying on data from the older motor. Carbahn is making 640hp and nearly 700ft/lbs with their piggyback, using just MAP tuning on 93 octane. You guys are using obd2 as well, so there’s zero reason you shouldn’t be making that or more. Somebody actually has to give a damn though, and it kinda feels like nobody does and we’re an afterthought.
Mike Levy
Car: 2022 X5 m50i
Default 12-13-2021, 02:28 PM
Agreed with Mike
phaser's Avatar
Car: X5 M50i
Default 12-13-2021, 04:33 PM
Very good point you make Mike and well stated.
+3.
phaser's Avatar
Car: X5 M50i
Default 12-13-2021, 04:37 PM
Most interesting about Carbahn.
zse8h zse8h is offline
Car: M5501
Default 12-19-2021, 12:02 PM
Mike exactly. This reason alone is why I dumped JB4 and went with racechip. Racechip has actually had the 2020 + cars on a dyno. Map 7 on racechip blows map 1 or 2 jb4 out of the water. It nice to have a product that is designed and tested rather than the other option.
2021 M550i
Bernina Grey Amber Effect
BMS Elite Intakes
Active Autowerke High Flow DwnPips
JB4 Map 1
Retired:
2009 335xi
Completely Moded out
Car: 2022 X5 m50i
Default 12-20-2021, 11:00 AM
Update: uninstalling jb4 and on to the CarBahn piggyback. Jb4 kept throwing codes and response time to my shop installers was bad...needless to say this tune isn’t ready for the 2022s.
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 12-20-2021, 01:05 PM
I thought about doing the same. I'm loyal to a fault, but there comes a point where you gotta just say "f*ck it, they don't care about us, so why should I stick with them?"
I'll hold on for a few more months and then revisit. I have 21 months left on the lease, so I'd really rather not drop $1250 on another piggyback if I can avoid it. Flash is another story.
Mike Levy
