danny98 danny98 is offline
Car: 2018 Infiniti Q60
Default Map 6 Pull - 11-23-2021, 04:40 PM
Hello! Did a few pulls with psi tapering to 4.5 then down to 0 after 5k. Can i get a review pls? Can't upload my other log as it is too big. Current mods ldp with CBE.
Default 11-23-2021, 04:58 PM
Here is a CSV file of it
Car: Evo VIII
Default 11-24-2021, 11:49 AM
For proper log review, please upload a log in 3rd or 4th gear from 2k rpm to redline on a safe private track.
Default 11-24-2021, 02:43 PM
This was done in 3rd gear! Just wondering how the logs looks so far?
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 11-25-2021, 08:56 AM
Assuming pulls were at full throttle log looks fine (Pedal position is showing like 75, but throttle is showing 100).
That is a very conservative map for a non RS model. I would just use the stock maps provided by BMS. They do taper and your ECU boost tapers as well so you won't be over boosting at high RPM. Try Map 2 and post back. Make sure 100% throttle all the way to redline if you can safely.
Default 11-26-2021, 01:37 PM
The only log I see is not at WOT...there was not a second (proper) log uploaded.
