(#1001)
Snkrspot Snkrspot is offline
Car: B9.5 S5
Default 10-07-2021, 10:23 AM
Finally getting around to installing my JB4 into my B9.5 S5 today. I intend on keeping the car stock (other than the JB4).
With that, curious if I should bother installing the BCM plug? Any benefits in doing so? Or risks if not? Also, I assume the ground wire still needs to be connected regardless of the BCM install?
Thanks.
Default 10-07-2021, 12:09 PM
Thanks.
Some customers report faster spool so wont hurt to fit it. Terry has covered the plugging in of it in this video: https://youtu.be/bNP1cy-QOi8
2021 VW Golf 8 R
Car: B9.5 S5
Default 10-07-2021, 02:10 PM
Thanks. Fitting it was a breeze. Overall the entire install was simple and straightforward (outside of running the OBD through the firewall).
One more question. Which Map would be the best for my application (stock B9.5 S5 Sportback w/91 Octane).
Thanks again.
Default 10-07-2021, 03:35 PM
Thanks again.
Map 2 is the recommended map for 91.
2021 VW Golf 8 R
perc9k perc9k is offline
Car: 2020 Audi S4
Default 10-13-2021, 11:45 PM
Running map 5 on S4 B9.5 and only seeing 4.0s to 60.
I run 5 gallons e85
Mid Muffler and resonator removed.
Los Angeles
What are good conservative map 6 settings that I can use without logging? (Haven't been able to log yet since I am using laptop.
Default 10-14-2021, 05:17 PM
I run 5 gallons e85
Los Angeles
You could possibly be spinning on the launch and loosing time. Log it and email logs to me at george@burgertuning.com and I can see if it can be improved.
2021 VW Golf 8 R
Bagy Bagy is offline
Car: Seat Leon Cupra 300
Default 10-16-2021, 12:42 AM
Hi everyone
I am running map5 (Audi RS5) and. noticed that after a launch control the shifting between first and second gear is not so fast as it should be. Like some kind of torque reducing is happening
Should i reduce the boost in the first gear? Or this should not happen
0-61mph takes 3,46 sek (0-100kmh). But i think it could go faster. Thanks in advance
Default 10-17-2021, 08:32 AM
Originally Posted by Bagy
Hi everyone
The time is pretty good relative to traction. It could be catching some wheelspin and reducing first might help. Try make boost cut 1st value 2 and see if it improves the shift. The value entered is how many psi it will cut in the gear.
2021 VW Golf 8 R
cory cory is offline
Car: Audi S5
Default 10-19-2021, 11:30 AM
Hi George! I've had my JB4 installed on my B9 S5 for nearly a year now. It's been great.
I've used map 5 with an E85 mix on 93 a handful of times.
One thing I've always wondered is, can I change from map 5 to map 3 (or any lower map) when I still have the E85 blend in my tank? Will this negatively affect anything?
When running on map 5 with E85 blend, I've always felt that I need to run the tank until nearly empty, and THEN fill up fully on 93 and then immediately switch to a lower map. Is this the case? Or am I assuming wrong?
Default 10-19-2021, 12:26 PM
When going down maps it will run fine in any map even stock with a blend in it.
2021 VW Golf 8 R
benign benign is offline
Car: B9 S5
Default 11-06-2021, 01:25 PM
Anyone know where I can source a the locking clip for the OEM fuel pressure sensor right below the high pressure fuel pump? When I was disconnecting it recently, the red locking clip shot out and I wasn't able to find it. It's a 3 pin plug that isn't shaped like a D, and I'm having no luck even finding a pigtail replacement for it. Pretty sure the wires are purple / blue on that one. It still clips in fine and is secure, I just would rather have the locking tab there in case I go in for service under warranty.
Default 11-06-2021, 02:12 PM
The only option is to order the plug from the dealer. Other option is to grab the part number off the plug and order it from somewhere like ECS.
2021 VW Golf 8 R
Car: 2020 Audi S4
Default 11-21-2021, 07:01 PM
https://mail.google.com/mail/u/0?ui=...id=f_kw8hxeev0
Happy holidays everyone, just logged a map 5 pull 3-4 gear as shown in the informative video.
Conditions
61 Degrees F
Almost full tank, 5 gallons e85 rest is 91
Mid muffler and dual resonator delete
Los Angeles, California
Altitude: about 300 feet
One passenger in car
Uphill slightly
Want to run map 6 as soon as possible and wanted to know the right settings to put in.
All help is greatly appreciated.
a1binos a1binos is offline
Car: Macan GTS 2021
Default 11-23-2021, 08:58 AM
Hi.
Just installed JB4 to Macan GTS 2021 2.9 375 hp.
On a map 3, I am seeing boost of 1.15 Bar, using application on my iPhone.
Is this ok?
Default 11-23-2021, 09:36 AM
Originally Posted by a1binos
Hi.
Is this ok?
Run some third gear logs and send to george@burgertuning.com. We can go higher on the GTS. When sending them through let me know the octane fuel you use.
2021 VW Golf 8 R
Conditions
61 Degrees F
Uphill slightly
Link is dead.
You can run some logs and email them directly to george@burgertuning.com
2021 VW Golf 8 R
Car: Macan GTS 2021
Default 11-24-2021, 10:09 AM
Hi.
Done it. Check email.
Macan GTS.
98 ron.
-1.5 degrees Celsius.
Map 3 and map 4 third gear runs.
