(#176)
BeGooD69 BeGooD69 is offline
Default 12-28-2021, 04:08 PM
Any help on those steering wheel controls please?
Default 12-28-2021, 07:20 PM
Originally Posted by BeGooD69
Where can i find the steering controls. I am not familiar on haor to do the map switch on the fly. Im only able to do ot with JB4. Any videos on how to use the controls out of the steering wheel. How to get into the menues. Thx
The BC control is limited and not supported on all models. But it's fairly easy to use. Similar to below.
'OBDII In Dash Menu
'0 map menu, map shown on tach (tach shows Map)
'1 Active Sound delete (for models equipped)
'2 Boost gauge on fuel, scaling in dash is 0 to boost safety setting, turns on when gas pedal is pressed 60% or more and turns itself off when you resume low throttle use. (tach = 0 OFF; tach = 1 Boost Only; tach = 2000 Boost on fuel, Meth on speedo ring; tach = 3000 Boost on fuel, Timing on speedo ring; tach = 4000 Boost on fuel, AFR on speedo ring)
'3
'4 Delete Fault Codes
'5 Dash Mode. tach = 1000, SAE; tach = 2000 Metric
'6 1st gear boost limiter. (Tach = boost cap / 3)
'7 2nd gear boost limiter. (Tach = boost cap / 3)
'8 3rd gear boost limiter. (Tach = boost cap / 3)
Default Yesterday, 01:10 PM
Thx you very much.
Next thing i have is: i dont see AFR2 and Trims2 not sure what the issue could b. Could u please review and feedback on the attached file.
I think i have my settings wrong, any input will help. For now map1 just to start safe ish until i get it all figured out.
Setup: 93oct, cold air intake, d@#% p!&€$, jb4/bcm installed
(Maf sensors unplugged as per install instructions)
Thx you
'OBDII In Dash Menu
'3
