(#1726)
F10MSP528 F10MSP528 is offline
Car: 2015 528
Default 08-14-2020, 08:12 PM
All bolt on except DP on 2015 F10N20. Is it safe to run Map 2? Canít find info for the 528. Thanks
iarthur's Avatar
iarthur iarthur is offline
Car: Mini Cooper S F56
Default 10-26-2020, 10:20 AM
What values ​​should be changed when adding the ewg connector?
Default 10-28-2020, 09:05 AM
Default settings should be included in the first post. Duty bias 50 across the board, FF I'd start at 50.
iarthur's Avatar
Default 10-29-2020, 06:11 AM
Is this configuration valid for version 13/6//5?
I made some comparisons between versions 13/6//5 and 13/5//5 I noticed a difference in the behavior of FF and WGDC, in version 6 there is a sudden drop in these parameters while in version 5 this drop is not so abrupt.
What are the differences between these versions?
Default 10-29-2020, 03:49 PM
I think the new settings and WGDC control scheme started in v7.
iarthur's Avatar
Default 11-18-2020, 01:29 PM
Hello Terry, when will the N20_OBDII_EWG_8_T2.hex version be stable? Thanks
Default 11-20-2020, 12:24 PM
Takes time for feedback to roll in. But you can always try it out, roll back if you don't like it or have any issues.
ergi ergi is offline
Car: x3 F25 20ix
Default 11-25-2020, 09:15 AM
Terry,
For a X3 F25 20IX EU type year 2015 engine N20B20A (10:1 ratio with 8psi pressure) 184ps:
What JB4 best configuration I have to get to run with gasoline 98oct
JB4 N20 / N26
Is the EWG Add On connector strongly suggested like for the 320i ?
I want to reach the performance power/torque of the 28i engine (17 psi pressure)
Thanks for your technical advice
Default 11-25-2020, 12:37 PM
EWG will be useful, yes. You'll use map5 similar to the 320i models.
Car: x3 F25 20ix
Default 11-25-2020, 11:15 PM
Thanks Terry for your advice
Do you know if the remote control from dashboard with buttons
is now functional with X3 F25, it seems it was some issues reading the forum.
If not functional, you have to connect computer to change map, right ?
Car: x3 F25 20ix
Default 11-25-2020, 11:54 PM
Sorry, one detail more:
Is it necessary to use Flex Fuel cable if i run only with 98oct ?
Default 11-27-2020, 04:12 PM
The fuel pressure connection is optional but if you post up a log we can confirm if you would benefit with it or not.
On BC button I think not active for F25 but app can handle everything!
seroga1986's Avatar
Default 11-29-2020, 04:32 PM
Is fuel pressure connector required to run e30? Can I just mix in to rep and run map2?
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Default 11-29-2020, 04:46 PM
It's usually needed to avoid maxing out the fuel trims but you can always post up a JB4 log if you want us to confirm!
