Default JB4 for S58 G Chassis M3/M4/X3M/X4M - 09-01-2019, 05:46 PM
This is the central point of contact for all S58 JB4 BETA related information. Anything from install directions, to firmware updates, to settings, to frequently asked questions. Any and all relevant info is linked in this post. If you come across something missing from here be sure to let us know.
Order the full JB4 system here.
Map changes, datalogging, updates are done using the BMS data cable or the JB4 Mobile bluetooth kit.
BMS data cable hard wired directions Click here
Map Guide as of v5 firmware:
Map 0: Stock operation, JB4 disabled
Map 1: Default performance map, 3psi peak request over stock (suitable for all 91+ RM2 fuels)
Map 2: 4psi peak request over stock (91 -93 suggested)
Map 3: 22psi absolute boost target (93 - E30 suggested)
Map 4: 23psi absolute boost target (E30-E40 suggested)
Map 5: 25psi absolute boost target (E30-E40 suggested)
Map 6: User adjustable map. RPM1500 value of less than 5.7psi make entire map6 additive target based, value over 5.7psi make entire map6 absolute target based.
Map 7: water/meth progressive map -- under development
Map 8: Low boost / VALET map
Note to properly delete fault codes the car must be in diagnostic mode first. With your foot off the brake press the ignition button 3 times fast. All lights will appear on dash.
For those helping test the fuel pressure add on connection: Green goes to 11, and black goes to 23 right below it
Exhaust Flap Control:
For X3/X4 using the BC button you can change between open (left arrow), closed (right arrow), and OEM operation (both arrows). Not working yet on M3/M4
Default Settings:
How to update firmware:
Car: F06 N55 640i Gran Coupe
Default 09-02-2019, 06:18 AM
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
MarinoB's Avatar
MarinoB MarinoB is offline
Car: E92 335i
Default 09-06-2019, 01:38 PM
Coming soon!
I see it up on burgertuning.com
Are those dragy numbers on 93 octane? Under 11 seconds with JB4 only!?
December can't come soon enough.
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
Default 09-06-2019, 02:00 PM
It did 10.8@126mph on E40 blend.
doberzus doberzus is offline
Car: 2020 X3MC/2018 Raptor
Default 09-08-2019, 11:19 AM
Will the JB4 be compatible on 91 octane at 4500 above sea level?
I'd be interested to see the power gains on 91 Octane/Map 1.
NJCarGuy's Avatar
NJCarGuy NJCarGuy is offline
Car: 2013 335i E93
Default Jb4 Installed on New X3M Comp - 11-16-2019, 02:52 PM
Hey guys, I just installed the JB4 Beta in my new X3M Comp.
Headed out to get some E85 now. I'll let you know how it runs.
Garage:
2020 X3M Comp - JB4
2011 X5 50i M-Sport - Dinan Stage 2
2002 M3 6-speed, Euro Cams, RE Exhaust, Intake, Dyno Tuned
2016 i8 - Installed K&N filter. Looking for mods
2015 X1 35i - FBO, Pure S1 Turbo + Meth
Default 11-16-2019, 03:12 PM
Yes map1 is fine for 91 octane, even at elevation.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 11-16-2019, 05:43 PM
Amazing. 10's with just a tune.
Is there no better place to run the OBD cable though? Looking at the directions, you have it going through the drivers door seal. That seems like it would get pinched. No grommets on the firewall you can use?
Mike Levy
Default 11-16-2019, 10:29 PM
Steve is the go-to person for that question as did the install.
NJCarGuy's Avatar
Car: 2013 335i E93
Default 11-20-2019, 04:59 AM
There's a hole in the firewall with a sticker over it. OBD cable passes through with ease.
Garage:
2020 X3M Comp - JB4
Mike_L's Avatar
Anti-Social
Default 11-20-2019, 03:08 PM
Nice. I was just fawning over one at the dealer. Made my choice so much harder for this spring/summer... X3M Comp or M550 LCI? Same price, only $40 a month difference in the lease. 503hp vs 523hp..... Going to have to see what the JB4 does with the M550s new motor.
Mike Levy
onfire onfire is offline
Car: X5 50i F15
Default 11-20-2019, 08:10 PM
Any Dyno Data ?
MarinoB's Avatar
Car: E92 335i
Default 12-22-2019, 03:06 PM
Break in service complete...about to order my Xmas gift!
Default 12-22-2019, 06:50 PM
Default 01-27-2020, 05:00 PM
Spent a few hours this am with Steve on the dyno dialing in some firmware changes. Initially on 91 octane then Steve poured in some E85 to get it up to E47. So much tuning potential on these! Can't wait until the S58 finds its way in to the new M3.
Mike_L's Avatar
Anti-Social
Default 01-28-2020, 12:05 AM
Looks like these are at least 10% underrated from the factory. Probably more since this was on ****ty 91 octane. 503hp my ass. 550+ is more like it.
Mike Levy
Default 01-28-2020, 09:19 AM
Man 660whp from stock turbos. I can't wait until the new M3/4 are out with the AWD system.
135idct 135idct is offline
Default 01-28-2020, 11:14 AM
FBO E85, 9 sec car
A418t81's Avatar
A418t81 A418t81 is offline
One tire fire
Car: E92 335, 6MT
Default 02-01-2020, 08:54 PM
Wow. This is bananas! May have to get a G80...I can outrun the ugly in it!
'18 Magnetic Gray Raptor
'19 GT3 RS Weissach
'09 997.1 6MT: FBO, 65mm VTGs. 730 whp
'18 Nardo Gray RS3 APR stage 2, 10.72 @ 130
Default 02-01-2020, 09:43 PM
lol
Default 02-01-2020, 09:48 PM
Canít wait for the new M3/4 to come & start turning up boost to it 💪🏻💪🏻💪🏻
MetzgerGt1 MetzgerGt1 is offline
Car: X3M
Default 02-26-2020, 05:15 AM
When is the next round of S58 updates expected? Anything in the works?
Juiced46 Juiced46 is offline
Car: 2011 335xi M sport
Default 05-31-2020, 09:13 AM
Are there any dyno #s on 93 octane only?
Also can maps 3 and 4 be used with good quality 93 octane?
2015 Yas Marina Blue M3
Default 05-31-2020, 10:26 AM
We've been working on stuff with people via email since the platform is still so new. Email me logs of how it's running and we can see if any of the changes might benefit your situation.
RoyB RoyB is offline
Car: X3M
Default 06-16-2020, 06:31 AM
Installed everything and the car limits power @ 3500 rpms. I emailed support and Ando requested I update firmware and log 3rd gear. I did and problem persists. I am running Map 1 on 93 octane.
Any ideas? Power feels like it's increased over stock until that point. Then it cuts power and bucks like a manual car in the wrong gear.
