(#3876)
Car: 2008 E93
Default 08-28-2019, 07:32 PM
Originally Posted by Rule77
Thanks! So if Im gonna go e40 should I change to the E85 bef?
Try e40 and log, that will dictate whether to change flash or not or if your car will even handle e40.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 08-28-2019, 07:40 PM
Why wouldnt it handle e40?
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5 RACE FMIC
VRSF DPs - VRSF INLETS - VRSF OUTLETS
MISHIMOTO 25 ROW OIL COOLER
19 666m WHEELS - HANKOOK VENTUS V12 EVO 2s
Car: 2008 E93
Default 08-28-2019, 07:58 PM
A few factors. Boost ? How healthy is hpfp ? I see you have a stage 2 lpfp so you should be good there. Current log to look at ?
Rule77's Avatar
Car: 08 E90 335i
Default 08-28-2019, 08:13 PM
Heres a couple. IATs are an issue that will be fixed soon.
Car: 2008 E93
Default 08-28-2019, 08:27 PM
Logs are a little short. I would like to see to redline BUT, it looks fine to handle e40 if these are on E30. I would probably flash E85 map. Your trims are fine now, a little high, but will climb higher with more ethanol. Make sure you log to check hpfp.
Rule77's Avatar
Car: 08 E90 335i
Default 08-28-2019, 08:35 PM
Originally Posted by THE BEAST
Logs are a little short. I would like to see to redline BUT, it looks fine to handle e40 of these are on E30. I would probably flash E85 map. Your trims are fine now, a little high, but will climb higher with more ethanol. Make sure you log to check hpfp.
Will do. Thanks!
Rule77's Avatar
Car: 08 E90 335i
Default 08-31-2019, 10:34 AM
Heres a better log with e30.
Car: 2008 E93
Default 08-31-2019, 02:13 PM
Trims, AFR, Boost all appear to be in check. Main issue I see here is timing and high IATs. Timing will take a dump due to high IATs. Definitely need a better FMIC and more octane can only help. Lpfp has room for E40 most likey, not too sure about hpfp until you try it and log. I wouldnt push too hard with those IATs though personally. I would address that first, and to be on the safe side, I would lower boost until you do so. Thats IMO. You could throw some logs up in support section for more feedback from others.
Rule77's Avatar
Car: 08 E90 335i
Default 08-31-2019, 02:28 PM
Thank you very much!
Car: 2008 E93
Default 08-31-2019, 02:40 PM
Welcome.
StormShadow335's Avatar
StormShadow335 StormShadow335 is offline
Car: 355i
Default Pump gas ST TS BEF - 09-09-2019, 02:07 PM
So I have the Doc Race kit and need to flash my DME with the ST TS BEF, but all maps with TS in the title seem to be some form of e40, e85, etc maps. The only other option is the ST map that doesn't reference TS. Which map should I be flashing to my DME?
2008 335i 6MT, Doc Race Precision 6062 GEN2 kit, JB4 ST BEF, BMS Meth & dual OCC kit, Helix hpfp, Boost Concepts Stg 2 lpfp, VRSF 3.5" exhaust, & FMIC, ER CP, HKS BOV, 550i clutch.
farzeen1232 farzeen1232 is offline
Car: 335is
Default BEF 335is - 09-13-2019, 07:23 PM
Do I load the jb4_mhd or the jb4_bb2 file if im using MHD flasher?
Rule77's Avatar
Car: 08 E90 335i
Default 09-13-2019, 07:32 PM
MHD
Car: 355i
Default 09-14-2019, 06:59 AM
I'm pretty sure you can either load MHD or BB BEF. It's depends on which one you wanna load.
RhynoBoiler's Avatar
RhynoBoiler RhynoBoiler is offline
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 09-28-2019, 08:37 AM
Hi all, I've searched around and can't seem to find the clear answer to requirements to running pure e85.
I'm a 335is FBO with upgraded coils, stage 2+ LPFP, stock turbos, jb4 / BEF, & 3.5bar tmap. Usually running the PUMP flash, car also loves RACE flash when I put above 100 octane in.
I'd like to run full e85... Is there anything else I would need to do other than load the e85 flash? My HPFP is still stock. I've seen the throttle body injection option, but want to know if that's required to run safely, or simply helps make more power
Thanks in advance.
All aboard the Lakeshore Drive Express!
AJoosten AJoosten is offline
Default 09-28-2019, 08:47 AM
You will not be able to get enough E85 to run more than map 1 or map 2 on full E85. To run race map with full e85 you will need to go port injection and a second lpfp.
09 135i N54|JB4 G5|BMS PI Cont|BEF Hybrid PI E85|Pure Stage 2 Hi-Flow Turbos|NGK 97506|Fuel 85% Ethanol|BM-Parts PI 750cc|Dual Walbro 450LPFP Bucket|Ethanol Sensor|3/8" Fuel Line|Stett Dual Oil Cooler|VRSF Relo Inlets|Active Autoworks7" FMIC|VRSF CP|HKS SSQ BOV|Agency Down & Mids|BMS Cowl Filter|MFactory LSD|JE Piston Heads|SPEC STG 3 Spr 6|ACT Pressure Plate|SPEC Single Mass Alum Flywheel|COBB Sway Bars|Ohlins Coilover 400/600|CAR BLOG
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 09-28-2019, 08:59 AM
I appreciate the reply.
So I can run map 2 (depending on how the logs look) on full e85 if I flash the e85 BEF?
If yes, would that make more power than 93 octane on map 5?
Rule77's Avatar
Car: 08 E90 335i
Default 09-28-2019, 09:28 AM
Your stock hpfp will be the factor. It can’t keep up on full E85. You’ll need a hpfp overdrive kit to run full E85.
Spool Performance Helix HPFP overdrive system
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 09-28-2019, 09:50 AM
Your stock hpfp will be the factor. It cant keep up on full E85. Youll need a hpfp overdrive kit to run full E85.
Are you recommending that in addition to a throttle body injection / port injection kit, or is a HPFP overdrive kit a replacement for those?
Rule77's Avatar
Car: 08 E90 335i
Default 09-28-2019, 10:25 AM
Without port injection.
Default 09-28-2019, 12:12 PM
Try full e85 and log log log. You will need supplemental fueling to really get the most out of e85.
nextNME's Avatar
nextNME nextNME is offline
Car: 2008 535xi
Default 10-07-2019, 10:36 AM
I have been running PUMP back end flash for a long time now, and is currently loaded. But this weekend I needed to do a Factory Reset on my tablet - - now MHD BEF wants to do a "long write" rather than 2min update - - okay to proceed as is with Long Write? Or anything needs to be addressed first?
Edit: in case anyone was wondering, did the long write and it was fine.....
2008 535xi. BMS DCI. CP. BOV. 5" FMIC. OCC. JB4. MHD BEF. XHP. BR14's
JakemeC JakemeC is offline
Car: 2007 BMW 335i
Default What MAP Should I run? - 10-15-2019, 06:58 PM
Should I use PUMP, Race or the e40.
I only use 93Gas in my car but its my first time doing a back-end flash.
I'm wondering which ones flashes better ?
Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default 10-15-2019, 07:04 PM
You will run the pump map
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Car: 2007 BMW 335i
Default 10-15-2019, 07:27 PM
I have ******* *********, Metal Charged *****, Large Intercooler and Dual Cone Air-Intakes..
Is this still valid for Pump or Race?
