Blueberry96's Avatar
Blueberry96 Blueberry96 is offline
Car: Kia Stinger Gt1
Default BMS Differential Brace - 06-21-2019, 02:23 PM
Alrighty, as requested...
This part is the new part, drove around quiet a bit today and it felt like its starting to settle in, car rides like a dream, and when accelerating while rolling already, barely any hesitation
NOW FROM ORIGINAL POST
Today I received and installed the Differential Brace for the Kia Stinger GT1 RWD platform. I am going to break this down into a few pieces so here we go.
1. INSTALL
WITH THE RIGHT TOOLS, this should take no more then 30 minutes, however with me I was missing both a 14 and 15 mm wrench so I went to auto zone and grabbed them. Once I had them it was smooth sailing from there. Take off the 4 14mm nuts that are on the differential and then put the brace on, tighten them just enough so you have some play. Then put the L shaped brace on along with the back plate that goes into the car. Not sure how to explain that any better. Once everything is in, tighten them and go enjoy yourself.
2. THE DRIVING EXPERIENCE
Just going based off my car here. The car handles extremely well, going from a dead stop it actually gripped the road a lot better. I can't speak for everyone here, but my stinger has 450 wheel horsepower and 500 wheel torque, so I was actually (pleasantly) surprised with how quickly and how well the car got going. No complaints here, I am very happy with the product and if you do not have one yet... Id recommend it!
Any questions feel free to reach out on my instagram @goldmember_gt Ill be happy to answer.. or you can reach out to the BMS squad of Terry and Payam, both are awesome and will gladly help out when needed.
NEXT STEP WATER METHANOL INJECTION BABY
Default 06-21-2019, 03:12 PM
Awesome! I know the guys took photos during an install here the other day to get a proper install guide going. Should be posted shortly!
Default 06-21-2019, 03:15 PM
Already posted a video on youtube explaining how
Default 06-21-2019, 03:35 PM
Default 06-24-2019, 10:25 AM
Post the video up in this thread!!
Default 06-24-2019, 11:50 AM
Found it!
robz's Avatar
robz robz is offline
Car: Stinger
Default 06-26-2019, 08:31 AM
Easy enough.
Thanks for locating the video.
Default 06-26-2019, 09:12 AM
Originally Posted by robz
Easy enough.
Super easy and simple. Takes about 10 minutes to install once the car is on ramps or on a lift.
Sling3r Sling3r is offline
Car: Genesis G70 3.3t RWD Sport
Default 08-11-2019, 03:49 PM
Curious if this will fit on the Genesis G70 as well?
Default 08-13-2019, 10:05 AM
Send a photo of under the car/diff area and we can confirm.
Default 08-23-2019, 05:15 PM
Best pics I could get for now.
Default 08-23-2019, 06:15 PM
Looks the same to me... Give it a whirl!
Stung Stung is offline
Car: 2018 Kia Stinger GT2 3.3TT
Default 08-29-2019, 09:16 AM
Is there any discussion on this part, it's use and benefits somewhere to review and discuss? Thank you!
Default 08-29-2019, 09:33 AM
There are a few videos on the Stinger facebook page I believe. It's not a magic bullet but tightens up the rear suspension for sure. For the price and ease of install well worth it IMHO.
Default 08-29-2019, 09:49 AM
Ah. Yeah, I don't and won't use Facebook. LOL Thanks.
Default 09-01-2019, 02:13 PM
Yes it's not for everyone lol, I can only take so much of it. But sometimes good info posted there.
rboettcher81's Avatar
rboettcher81 rboettcher81 is offline
Car: 2019 Kia Stinger GT
Default 09-10-2019, 07:29 AM
So I installed the diff brace last night and ran into a small snag. I was able to work around it but at least wanted to post some feedback in case it could be useful to improve the product.
My issue is that when lining up the vertical "L" bracket that bolts to the subframe to the differential bracket after it's bolted to the diff, the two bolt holes that mate the two don't exactly line up.
In more detail, the rear hole was off (the front hole at least lined up). So from what I can tell, it was off perhaps due to a weld that was on the underside of the subframe. It was forcing the vertical "L" bracket down about a 1/4", throwing the alignment off for the rear hole. I ended up filing the hole just a little bigger so that both bolts could pass and be secured with the provided nyloc nuts.
Perhaps I should have just filed the top edge of the bracket so that it would form around the weld and allow it to be "square" with the subframe (in hindsight).
The vehicle it was installed on is a 2019 Stinger GT (base GT trim), if it even matters.
EDIT: In hindsight, filing the top edge will have thrown hole alignments elsewhere so, in fact, the bolt holes mating the two brackets probably just need to be a little bit wider. The weld is not the issue.
Default 09-10-2019, 11:42 AM
Got any pictures?
Default 09-10-2019, 11:51 AM
I didn't take any last night. I could later this evening.
Default 09-11-2019, 06:38 AM
I didn't get a chance to put the car on ramps last night (that dad life) but I did find a good picture of another Stinger rear subframe that shows the weld i'm referring too.
I will take pics of mine just to show in further detail when I get a chance though.
The red circle in the pic is the weld that is pushing the lower "L" portion of the vertical bracket down, causing some misalignment. On mine specifically it's down so much that it's hitting my exhaust cross-brace. I think i'm going to have to remove that L bracket and file the top edge where it's making contact with the weld so it has clearance with the exhaust brace. It rattles on cold starts.
Default 09-12-2019, 05:41 AM
So I was able to snap some pics.
I went ahead and removed the vertical bracket because the bottom edge was contacting the exhaust brace below. I ended up filing that edge to a 45 degree which gave it a couple mm clearance and all is well.
After further examination, filing the top edge of the vertical bracket where it touches the weld would've been a bad idea as it would have thrown off the bolt holes above it, to the subframe (that secures to the "nut bracket").
I still like the product but fitment was not exactly plug 'n play out of the box for me. Just make sure you have a large flat file and a round file with a bench vice to make small adjustments if needed.
Red arrows in pics are points of interest indicating contact/rubbing, areas filed, and clearance afterwards.
Default 09-17-2019, 05:22 PM
Interesting it's close on ours but plenty of clearance. Keep the photos rolling if there is a trend we'll modify the template for extra clearance there.
Default 09-18-2019, 05:24 AM
Yeah, I'm almost certain it may have something to do with how the subframe is manufactured. It seems to be a flat piece of metal that's bent into the shape and folded over itself on the bottom, then welded. This weld could introduce variances in how the BMS subframe bracket lines up to the BMS diff bracket and ultimately how it occupies 3D space above the exhaust cross-brace.
Just wanted to post anything helpful. Thanks for reading.
Default 09-18-2019, 06:51 PM
So with an aftermarket exhaust, like the Ark, this will be a non-issue, as there is no cross brace. Thanks for the photos.
robz's Avatar
Car: Stinger
Default 09-19-2019, 07:39 AM
Negative.
All aftermarket exhaust have the brace on the rear mufflers.
