(#4426)
Car: q50
Default 07-12-2019, 04:24 PM
Got my JB4 setup back, thanks Terry for checking it out and the quick turn around shipping. Back in boost!
TwinTurboPete TwinTurboPete is offline
Car: 2019 Q50 RS
Default 07-12-2019, 07:39 PM
Hey everyone. Iím new here and was wondering if there are any Red Sports with JB4 in the 11ís yet? I have a 2019 and donít want to risk losing my warranty.
2019 Q50 RS
Montreal, Quebec
Default 07-15-2019, 10:29 AM
There are a handful of JB4 VR30s in the 11s but not sure if any are RS. I imagine so though.
Either way JB4 adds a ton of power and is really easy to install and remove. You'll love it.
Default 07-15-2019, 10:30 AM
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 07-16-2019, 07:51 AM
Glad to hear that. I got my JB4 and fuel wires back installed yesterday after she got her first oil change at the dealership. 1/8 track day on Thursday.. not going to expect much as it'll be 91 degrees and humid, which is the coldest day this week.
12.64 @114mph
0-60 4.46
Car: q50
Default 07-16-2019, 08:11 AM
Terry, do you have any info on when you upgrade phones how you get the JB4 app on the new phone? Do you have to contact the app company or anything special? I emailed them but haven't heard back yet.
Car: 2018 Q60 3.0
Default 07-16-2019, 10:39 AM
Terry how does this look to you?
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Megan LDP
Car: Red Sport 400
Default 07-17-2019, 05:37 AM
This looks like timing is being pulled. Did the car feel slower?
I recently had a Map 6 +5psi log with a similar ign pattern that was timed on dragy. Map 6 +5psi went 12.9 @ 107 vs Map 1 +4psi 12.6 @ 112
I also ended up doing a few runs in mexico after a few cars came up to my normal logging spot and ran Map 1 back to back to back all with very clean logs.
Also if anyone cares, I logged 4 0-60 runs with an empty tank of Costco 93 then got a full tank of Shell 93 VPower and ran faster times by .10 consistently. IIRC a full tank in the q50 is around 160lbs so it should've been slower
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
12.19 @ 115.87 on 93 (Map 6)
Car: q50
Default 07-17-2019, 07:10 AM
Terry and I have discussed what you're seeing in that log many pages ago. We're not totally convinced that that is knock you're seeing because it ALWAYS happens right around 52-5400 rpm's. It may be a drop in the spark advance table. If you're on the threshold of 2 rows or columns in the airflow vs. rpm vs. spark advance it may jump to the next row/column which calls for a decrease in timing. As you can see from the graph it drops ~3* right there and then timing continually climbs afterward. He could try dropping the boost and see if it goes away, but I'm not positive that its knock. If only we had that knock counts PID *cough* Terry *cough*
Car: Red Sport 400
Default 07-17-2019, 08:21 AM
Ahh the log I was referring to was a different more recent one that was never posted. I got Dragy a week ago and have been logging 0-60 & 1/4 mile runs.
I've been logging consistent 12.6-12.8 @ 110-113 but had one run using Map 6 +5psi go 12.9 @ 108 with similar ign pattern as the one Randy posted. The car felt noticeably slower that run so I assumed timing was being pulled? I would post it but i accidentally deleted the log.
But I appreciate the explanation to the log you're referencing a few pages ago. I was still confused as to why the log looked that way. The info you provide is definitely very helpful
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Default 07-17-2019, 08:43 AM
One timing drop but it's pulling smoothly behind the wheel its probably fine.
maracuch0 maracuch0 is offline
Car: Q50
Default Noob here - 07-18-2019, 09:53 PM
Hello, I just purchased a Stage 1 Q50 Tuner with the JB4 Wireless Connection kit. I purchased the Stage 1 by accident, but I want to know if it is compatible with the Wireless connection kit bluetooth? If not, I may have to exchange for the JB4 instead.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 07-19-2019, 07:42 AM
The JB4 BlueTooth Wireless Kit / Phone App work for both the JB1 and JB4.
The JB4 upgrade is definitely worth the extra $'s. Much smoother acceleration feel and the additional logging capabilities, fuel wires, and my new favorite WMI Kit are just some of the reasons to go with the JB4.
BMS WMI
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM3.5ís
  • AMS HE w/ Aux Tank & IC Pump
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
Default 07-19-2019, 10:01 AM
You can purchase the upgrade kit for more logging parameters down the line.
For stage 1 you'll only see boost.
vietnameeh vietnameeh is offline
Car: Q50
Default 07-19-2019, 08:13 PM
Decided to try map 5
Stock lux on 91 octane
How does it look
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Default 07-20-2019, 10:19 AM
How does it look
I suspect it's too aggressive for the octane.
Q50Philly's Avatar
Q50Philly Q50Philly is offline
Car: 2018 Infiniti Q50 Red Sport
Default Red Sportís running WMI? - 07-21-2019, 06:11 AM
Hi Folks - is anyone else with Red Sport running BMSí WMI Kit? If so, please share your experiences. You can see mine on the WMI thread.
2018 Q50 Red Sport AWD
BMS JB4 w/Map 0 for WMI Control
BMS WMI Kit
Ecutek Tune by R/T
AMS Red Alpha Cold Air Intakes
HKS Resonated LDP (no drone)
Tanabe Y-Pipe
Mishimoto Heat Exchanger
jayhawk91 jayhawk91 is offline
Car: Infiniti Q50
Default 07-22-2019, 03:40 PM
Recently installed the $300 BMS Heat exchanger and the car seems to be running better in the heat (close to 100 today). Trans temp in the afternoon is about 113-118 cruising. Did a low 3rd gear pull to WOT and the car got up to 130 before coming back down. Is this what I should be expecting from the heat exchanger? I have logs attached, running Map 5. Thanks!
Default 07-22-2019, 07:40 PM
Looks as expected!
Car: Q50
Default 07-23-2019, 10:54 AM
that is what I figured, thank you!
I have uploaded a map3 run I did yesterday freeway on ramp 20-100mph.
It felt pretty good
Let me know what you guys think
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Default 07-23-2019, 01:28 PM
Seems OK to me here.
Car: Q50
Default 07-23-2019, 02:21 PM
Thank You
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Default 07-23-2019, 05:17 PM
Hit the dyno today with a JB4 2L Q50... I'm sure all the VR30 guys are hanging on the edges of their seats but I'll make a new thread for it later.
Car: Q50
Default 07-23-2019, 06:41 PM
Thatís pretty cool actually canít wait to see
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
multiplexor multiplexor is offline
Car: 2018 Q50 SS
Default 07-24-2019, 09:41 PM
Hey guys :-)
First post on here... and it has a csv file attached lol.... So... 2018 Q50 SS, JB4 installed last week... I attached a csv file with some stop n go. Kinda curious what people think of the AFR and IGN values. Ran this in map 6 with 94 octane(chevron).
map6 boost started at 3 at 1500rpm, maxed at 6.9, and back down to 0 at max rpm.
