(#2351)
Default 07-10-2019, 08:51 AM
Originally Posted by ecko04
Just change the JB4 WMI setting under boost additive to 70?
Right
Default 07-10-2019, 09:09 PM
Kato doing work tonight, setting the stock turbo Stinger 1/4 mile record on stock rims and 93 octane!
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 07-10-2019, 10:20 PM
Wow
2019 Genesis G70 3.3T AWD Sport
Jays_stinger Jays_stinger is offline
Car: Kia Stinger GT
Default 07-11-2019, 07:41 AM
Hi Terry,
I purchased a 50mm tial BOV and put in a 6psi spring which I read is recommend for the stinger.
The car doesn't seem to hold boost. The car feels smoother with the stock recirculating valves.
I data logged a few runs they're very short and small but maybe you can see what I'm talking about?
Appreciate all the help.
Jay C.
Default 07-11-2019, 08:08 AM
The one full throttle log looks good to me. On the Tial BOV as a test try running it manually off the manifold directly like this:
robz's Avatar
robz robz is offline
Car: Stinger
Default 07-11-2019, 08:13 AM
Do we need to drill a whole in it? Or is there a nipple already there we can tap into?
Car: Kia Stinger GT
Default 07-11-2019, 08:17 AM
I will go ahead and do so and report back. Also, I can just leave the other vacuum port without a hose? and is that a hose adapter connecting both hoses?
Thanks terry.
Default 07-11-2019, 08:22 AM
Yes the vacuum canister there is only used for the BOV so the other vacuum line you remove can stay unplugged. Also be careful when removing it, don't want to break the plastic nipple. I used a small screw driver to sort of pry it forward a bit before pulling it off.
robz's Avatar
Car: Stinger
Default 07-11-2019, 08:27 AM
Understood. Will try it today. Not having any issue but I'd rather have it working manually
crewdawg130 crewdawg130 is offline
Car: 07 335i e90
Default 07-11-2019, 11:07 AM
Make sure you get the proper spring. My car pulls around -18” of vac so I have a plain spring and it works perfect now.
Car: Kia Stinger GT
Default 07-11-2019, 11:13 AM
Originally Posted by crewdawg130
Make sure you get the proper spring. My car pulls around -18Ē of vac so I have a plain spring and it works perfect now.
You have a stinger GT as well? Everyone recommends a 6 psi spring for it with a tial.
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 07-11-2019, 01:46 PM
I recently uninstalled then reinstalled my JB4, and now it feels like there is a lag until 4K rpm. It feels a lot like VTEC; not much going on until after 4K, even at WOT. I’ll usually start my pulls in 2nd gear @ 3k rpm. I don’t remember it feeling like this the first time around with the JB4. Did I just forget, or is this normal?
Default 07-11-2019, 02:06 PM
Originally Posted by P4RTYH4RTY
I recently uninstalled then reinstalled my JB4, and now it feels like there is a lag until 4K rpm. It feels a lot like VTEC; not much going on until after 4K, even at WOT. Iíll usually start my pulls in 2nd gear @ 3k rpm. I donít remember it feeling like this the first time around with the JB4. Did I just forget, or is this normal?
Can you get a log so we can check it out? What map and fuel are you using?
Default 07-11-2019, 07:32 PM
Got in 20 of our unique Stinger zero-service OCC! Get them while they are hot.
https://burgertuning.com/products/bms-stinger-occ
przemek.k przemek.k is offline
Car: Stinger
Default 07-12-2019, 01:02 AM
Sorry if it had been already mentioned but cannot find it.
JB4 / BMS intakes / custom made exhaust 3.3TT - HKS 45iL plugs: should be gapped to 0.22, 0.23 or 0.24?
Which is the best and tested (mostly for MAP1/2)?
robz's Avatar
Car: Stinger
Default 07-12-2019, 07:33 AM
0.22 or 0.23 will work.
I'd go with the closer gap to prevent/minimize spark blowout.
Car: Stinger
Default 07-12-2019, 07:48 AM
thanks
RandallK's Avatar
RandallK RandallK is offline
Car: 2018 Kia Stinger GT
Default 07-12-2019, 02:24 PM
Ordered the Catch Can this morning.. super stoked on it...
Default 07-12-2019, 05:02 PM
terrelltechsup terrelltechsup is offline
Car: 2019 Stinger GT1 RWD
Default 07-12-2019, 09:25 PM
Installed JB4 today and ran a couple Map 1 pulls without fuel wires and stock plugs for now. Mind reviewing them Terry? Ill test some more tomorrow now that I have the fuel wires in(damn that little grey positap fitting and the undercarriage covers).
Thanks a bunch.
Default 07-12-2019, 09:48 PM
Thanks a bunch.
Looks all normal to me! Sucks on the posi-tap, we have spares on the site if you need. Or maybe a local hardware store will sell them.
thuglifesk thuglifesk is offline
Car: Kia Stinger GT2
Default New Install - 07-12-2019, 09:51 PM
Hey Terry,
Just installed JB4 in 19 Stinger with fuel wires and denso plugs gapped at .22 as suggested. Please see attached logs for map 1 and map 2 and confirm all is okay. I am current using Shell 91. Usually use Petro 94 but I read in the Canadian thread that Petro 94 is not that great.
Default 07-12-2019, 10:08 PM
Oh don't you worry. I found it. One floor jack, one jack stand, one 10mm socket, 8 bolts and 1 pop rivet later. Thanks again for taking a look at it.
BMS Fanboy
Default 07-14-2019, 10:05 AM
I've attached 2 logs; I started each log between 2k and 3k rpm in 2nd gear. I'm running map 3 with e30.
I don't know if this would have any affect, but when I uninstalled the fuel wires the first time around, I noticed a few of the internal wire strands had been pinched off when screwing/unscrewing them in; I ended up just reinstalling them as is. Should I cut the wire down so all internal strands are still intact? Does this make sense?
Thanks.
Default 07-14-2019, 10:14 AM
Originally Posted by thuglifesk
Hey Terry,
I think map2 looks fine here on your Shell 91.
