(#2326)
Default 07-06-2019, 09:24 AM
Originally Posted by SVStinger
Terry,
Good morning. Just installed the JB4 and did a trial run in MAP1. I am on V7 not the latest. I still need to figure out how to do the firmware update. That is a topic for another day. No issues that I could feel. If I get a log file may I send it to you so you can confirm that all is well before I move forward?
Tks,
Kevin
Sure just add it to this thread and I can review it for you!
ChiTownStinger ChiTownStinger is offline
Car: 2018 Stinger GT1
Default 07-06-2019, 03:55 PM
Hey Terry, can you look at this log? Map 2 w/92 octane. Thanks!
Dion Dion is offline
Car: Stinger
Default Overboost - 07-06-2019, 04:54 PM
Gday mate, same thing. On map 1
Default 07-07-2019, 09:13 AM
Short run but seems fine to me.
Default 07-07-2019, 09:14 AM
Not much to go on. You threw an over boost fault code here? ECU only sees boost as 10psi, doens't add up?
Car: Stinger
Default Overboost - 07-07-2019, 02:08 PM
No codes, just breaks up for a sec then cuts boost until I restart engine.
Default 07-07-2019, 02:26 PM
Next stop map2. But since you have a unique support situation with your full exhaust you'll have to email us for further help. Doesn't really apply to the general thread.
Car: Stinger
Default Overboost - 07-07-2019, 05:37 PM
Sounds good. What’s your email?
Here’s another 2 on map 1. First is normal second is traction control off.
Default 07-07-2019, 06:41 PM
terry@burgertuning.com
ecko04 ecko04 is offline
Car: N55 335i
Default 07-08-2019, 06:57 PM
Terry,
Would you mind taking a look at these logs? E30 and WMI on Map 8.
Default 07-08-2019, 07:08 PM
Originally Posted by ecko04
Terry,
Looks good to me. Next stop 70 additive!
Bratboy90 Bratboy90 is offline
Car: 18' Stinger GT
Default 07-09-2019, 10:34 AM
18' Stinger GT
Hoping for insight to make sure everything looks good. Stock plugs still. Didn't have time to put the upgraded ones off BMS in tonight. Got the JB4 in with fuel wires and OBD. Stock everything on the car. Will run MAP2 mostly with 93oct. Hoping to do plugs then run 110oct for upcoming track event in Aug. What's a safe map to run for 110oct race gas with no other mods?
Couple logs of MAP1 and MAP0.
Appreciate your insight Terry.
Default 07-09-2019, 11:09 AM
Can't look at all of the logs, but opened a couple map1 logs and they seem fine to me.
Only run unleaded fuel... VP100, MS109, GT-260, etc. Should be fine on map5 with it.
Car: 18' Stinger GT
Default 07-09-2019, 05:10 PM
Hey, thanks a ton. Love the JB4. Coming from Chevy with Hptuners changing tune on the fly and logging made easy is so awesome. The bluetooth makes it so simple. Great job on the whole setup!
Car: N55 335i
Default 07-10-2019, 07:02 AM
Just change the JB4 WMI setting under boost additive to 70?
Car: N55 335i
Default 07-10-2019, 07:04 AM
You can also run E30 on Map5. Just log it and have Terry take a look. I daily on Map5 and E30. At least until I got WMI. Now I daily on Map 8.
Default 07-10-2019, 08:51 AM
Right
Default 07-10-2019, 09:09 PM
Kato doing work tonight, setting the stock turbo Stinger 1/4 mile record on stock rims and 93 octane!
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 07-10-2019, 10:20 PM
Wow
2019 Genesis G70 3.3T AWD Sport
Default 07-11-2019, 08:08 AM
The one full throttle log looks good to me. On the Tial BOV as a test try running it manually off the manifold directly like this:
robz's Avatar
robz robz is offline
Car: Stinger
Default 07-11-2019, 08:13 AM
Do we need to drill a whole in it? Or is there a nipple already there we can tap into?
Default 07-11-2019, 08:22 AM
Yes the vacuum canister there is only used for the BOV so the other vacuum line you remove can stay unplugged. Also be careful when removing it, don't want to break the plastic nipple. I used a small screw driver to sort of pry it forward a bit before pulling it off.
robz's Avatar
Car: Stinger
Default 07-11-2019, 08:27 AM
Understood. Will try it today. Not having any issue but I'd rather have it working manually
crewdawg130 crewdawg130 is offline
Car: 07 335i e90
Default 07-11-2019, 11:07 AM
Make sure you get the proper spring. My car pulls around -18” of vac so I have a plain spring and it works perfect now.
P4RTYH4RTY P4RTYH4RTY is offline
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 07-11-2019, 01:46 PM
I recently uninstalled then reinstalled my JB4, and now it feels like there is a lag until 4K rpm. It feels a lot like VTEC; not much going on until after 4K, even at WOT. I’ll usually start my pulls in 2nd gear @ 3k rpm. I don’t remember it feeling like this the first time around with the JB4. Did I just forget, or is this normal?
