(#2326)
Dion Dion is offline
Car: Stinger
Default Overboost - 07-04-2019, 01:50 AM
Gday Terry, love your work mate. Iíve run the jb4 in my old stinger and had great success. I have only just fitted it on my new one to check out information. Iíve fitted turbo back exhaust and getting overboost. Can the jb4 help me with this at all?
Ta, D
Default 07-04-2019, 08:54 AM
Ta, D
First step is to do a JB4 log on map0 and lets see what is going on technically.
Car: Stinger
Default Overboost - 07-04-2019, 04:43 PM
It cut boost after second at about 5k but looks like it didnít log the boost cut off but let me know what you see. Thanks mate.
u/tonyv1990 u/tonyv1990 is offline
Car: Stinger GT
Default 07-05-2019, 02:08 PM
Got it Bud cant wait to start putting up numbers!
Default 07-05-2019, 02:19 PM
You need to attach the CSV file itself, photos are not useful.
Car: Stinger
Default Overboost - 07-05-2019, 07:50 PM
Default 07-05-2019, 08:31 PM
I see it. Does the issue come up on map1?
Car: Stinger
Default 07-06-2019, 12:53 AM
No didnít do any maps, thought that would still overboost but just at an elevated level which was my concern. Has anyone else come across this?
Iíll give it a try in the morn.
SVStinger SVStinger is offline
Car: 2019 Stinger GT2
Default 07-06-2019, 07:46 AM
Terry,
Good morning. Just installed the JB4 and did a trial run in MAP1. I am on V7 not the latest. I still need to figure out how to do the firmware update. That is a topic for another day. No issues that I could feel. If I get a log file may I send it to you so you can confirm that all is well before I move forward?
Tks,
Kevin
SVStinger
2019 Stinger GT2 AWD
Default 07-06-2019, 09:24 AM
Originally Posted by SVStinger
Terry,
Tks,
Kevin
Sure just add it to this thread and I can review it for you!
ChiTownStinger ChiTownStinger is offline
Car: 2018 Stinger GT1
Default 07-06-2019, 03:55 PM
Hey Terry, can you look at this log? Map 2 w/92 octane. Thanks!
Car: Stinger
Default Overboost - 07-06-2019, 04:54 PM
Gday mate, same thing. On map 1
Default 07-07-2019, 09:13 AM
Short run but seems fine to me.
Default 07-07-2019, 09:14 AM
Not much to go on. You threw an over boost fault code here? ECU only sees boost as 10psi, doens't add up?
Car: Stinger
Default Overboost - 07-07-2019, 02:08 PM
No codes, just breaks up for a sec then cuts boost until I restart engine.
Default 07-07-2019, 02:26 PM
Next stop map2. But since you have a unique support situation with your full exhaust you'll have to email us for further help. Doesn't really apply to the general thread.
Car: Stinger
Default Overboost - 07-07-2019, 05:37 PM
Sounds good. Whatís your email?
Hereís another 2 on map 1. First is normal second is traction control off.
Default 07-07-2019, 06:41 PM
terry@burgertuning.com
ecko04 ecko04 is offline
Car: N55 335i
Default 07-08-2019, 06:57 PM
Terry,
Would you mind taking a look at these logs? E30 and WMI on Map 8.
Default 07-08-2019, 07:08 PM
Originally Posted by ecko04
Terry,
Looks good to me. Next stop 70 additive!
Bratboy90 Bratboy90 is offline
Car: 18' Stinger GT
Default 07-09-2019, 10:34 AM
18' Stinger GT
Hoping for insight to make sure everything looks good. Stock plugs still. Didn't have time to put the upgraded ones off BMS in tonight. Got the JB4 in with fuel wires and OBD. Stock everything on the car. Will run MAP2 mostly with 93oct. Hoping to do plugs then run 110oct for upcoming track event in Aug. What's a safe map to run for 110oct race gas with no other mods?
Couple logs of MAP1 and MAP0.
Appreciate your insight Terry.
Default 07-09-2019, 11:09 AM
Can't look at all of the logs, but opened a couple map1 logs and they seem fine to me.
Only run unleaded fuel... VP100, MS109, GT-260, etc. Should be fine on map5 with it.
Car: 18' Stinger GT
Default 07-09-2019, 05:10 PM
Hey, thanks a ton. Love the JB4. Coming from Chevy with Hptuners changing tune on the fly and logging made easy is so awesome. The bluetooth makes it so simple. Great job on the whole setup!
Car: N55 335i
Default 07-10-2019, 07:02 AM
Just change the JB4 WMI setting under boost additive to 70?
Car: N55 335i
Default 07-10-2019, 07:04 AM
You can also run E30 on Map5. Just log it and have Terry take a look. I daily on Map5 and E30. At least until I got WMI. Now I daily on Map 8.
