(#11501)
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 08-10-2019, 12:07 PM
Originally Posted by Rule77
I would say you should update your firmware.
Also enable 6cyl timing
08 E90 335i
Montego Blue
JB4/MHD E85 BEF
BMS DCI
BMS OCC
BMS Cowl Filters
VRSF ⬇️ Pís
MMP Chargepipe
TIAL BOV
BMS Pedal Tuner
BMS PCV VALVE
NGK 97506 @ .022
STAGE 2 LPFP
H&R Springs
19' 666m Wheels
Rule77's Avatar
Car: 08 E90 335i
Default 08-10-2019, 06:26 PM
Originally Posted by GotPwned
I noticed that my JB4 mobile is detecting an E85 level in my car. It does say that my car is around 53% e85 and fluctuates around +-2% e85 when driving. From what I know I dont think I have a flex fuel sensor in my car. Is this normal?
I would like to know about this since I just recently started running e30 and noticed the numbers under e85 in the cvs file are different.
08 E90 335i
Montego Blue
JB4/MHD E85 BEF
BMS DCI
BMS OCC
BMS Cowl Filters
VRSF ⬇️ Pís
MMP Chargepipe
TIAL BOV
BMS Pedal Tuner
BMS PCV VALVE
NGK 97506 @ .022
STAGE 2 LPFP
H&R Springs
19' 666m Wheels
ym12ad ym12ad is offline
Default 08-14-2019, 12:49 AM
hello,can i get some help,i have a 335i running with meth in map 3,at WOP,it switches to map 4 and flashes 4 times hazard lights,i never saw anything about 4 times hazard lights in any other post
Haynpunch's Avatar
Car: 07 E90 335i
Default 08-14-2019, 01:44 AM
post a log with it switching to map 4 in the Support section
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
x99percent x99percent is offline
Car: 2008 135i
Default 08-14-2019, 11:02 AM
4 flashes = low meth flow
Default 08-14-2019, 03:05 PM
when I did the logs is not switching anymore to map 4 but now I can hear a very strange noise from under the car,any idea what it can be?
attached the video and the logs
thank you
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 08-14-2019, 08:40 PM
thank you
Post in the SUPPORT section.
VinnyD VinnyD is offline
Car: 2008 Bmw 335xi
Default Need help maybe injectors - 08-17-2019, 08:42 AM
I have attached a log, I have changed spark plugs and coils. I can not do a full pull without going into limp mode. I have a 335xi n54 upgraded pure stage 2 turbos with full bolt ons with upgraded inlets this pull I was running 6 gallons of E85. I have xhp stage 3 trans flash and use jb4 custom hybrid turbo E85 backend flash.
Im thinking it might be the injectors because I get a check engine light for misfire in cylinder 6 often and 4 sometimes. I have index 9 and I know index 12 is suggested for tuned cars.
Any other ideas or is it bad injectors?
Thanks,
Default 08-18-2019, 11:43 PM
People, if you need help with your car, post in the SUPPORT section. This is for generic JB4 talk.
BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 08-19-2019, 04:33 AM
Relax dude, before you have a heart attack over a stupid ass reason.
Moderators will take care of it.
2009 E92 335i AT
Engine
Default 08-19-2019, 08:33 AM
Just pointing people in the right direction. Why do you sound mad? Sounds like you need to relax..lol.
Default 10-15-2019, 12:42 PM
Finally found and fixed this bug. Also have new flex maps for those running the MHD flex fuel sensor and the Fuel-IT flex fuel sensor. Both are supported.
T11) Fixed issue with E85 reading not showing properly when using MHD back end flash flex fuel integration, enabled on WMI page bit2 on for DTML Flex Input.
Car: 2008 E93
Default 10-22-2019, 09:32 PM
No luck on gauge sweep ?
BMWguy13's Avatar
BMWguy13 BMWguy13 is offline
Car: 335i N54
Default 10-23-2019, 09:24 AM
Hello, I just purchased a 2007 335i with JB4. I have downloaded the app to my MacBook but when i plug into the usb cable and hit connect nothing happens..... HELP lol
mb443 mb443 is offline
Car: 08 E90 335i
Default 10-28-2019, 09:04 AM
Newbie here with a some basic questions about JB4 maps.
Recently installed d-***** and switched JB4 from Map 1 to Map 2. I had run Map 5 while only DCI+FMIC but it felt inconsistent so I left it running Map 1.
Map 2 felt good initially, definitely more power. I noticed that Map 2 seemed to be targeting 17 PSI (according to gauge hijack) which doesn't align with map definitions listed in the first page of this sticky. Map 2 should be 14.5 PSI.
Ambient temps are falling nicely here in the PNW so yesterday on my Sunday morning spin I decided to switch over the Map 5 and do a few WOTs to let the JB4 learn what's up...
Holy crap! Wow is there more available power low down in Map 5, particularly in 1st and 2nd gear. Less of a noticeable difference in 3rd gear which is already rocketship-mode as we all now. Let's just say tires were "accidentally" spun at green lights more than a couple of times. The odd thing is now according to gauge hijack the car is only targeting 15 PSI... so apparently lower boost target than Map 2 (based on gauge hijack not advertised settings), yet feels stronger.
Wondering if anyone has had similar experiences, and could speak to the technical reasons why Map 5 might feel stronger at lower boost.
Thanks in advance
Trebila custom tune up next!
2008 E90 335i 6MT Sport > JB4 G5 ISO + PUMP BEF | N54Tuning d-p1pes | Evo 1 FMIC | Phoenix CP | Turbosmart DualPorts (50/50) | Burger DCI, OCC, CDV, diff brace, cowl filters, etc | Shiftek DSSR | ZHP knob | Michelin PS AS3+ on stock 162s | minor cosmetic stuff
nextNME's Avatar
nextNME nextNME is offline
Car: 2008 535xi
Default 10-29-2019, 06:20 PM
Its in the BEF thread... took me a while to find it too. Post#1, Note 13.
N54 BimmerBoost MHD Back End Flash Maps - N54Tech.com - International Turbo Racing Discussion
2008 535xi. BMS DCI. CP. BOV. 5" FMIC. OCC. JB4. MHD BEF. XHP. BR14's
Car: 08 E90 335i
Default 10-31-2019, 12:29 PM
Thanks very much, that explains the boost target question.
Amgkiller54 Amgkiller54 is offline
Car: N54 335i , E71 X6M
Default 11-06-2019, 06:27 PM
Greetings forum members , i have a problem with my n54 335i. Mods are : vrsf intercooler , ar cattles ** , rb inlets and outlets , vrsf chargepipe with hks blowoff valve , jb4 and mhd bef , fuel it stage 2 lpfp. I have recently tested my car with my dragy box with map 5 ( 13.1 sec at 107mph) and with the race fuel mhd back end flash (13.4 at 106mph) . I noticed that my times and speeds are bad . Thats why i wanted to ask help to look into my logs and find a solution for what i am doing wrong. Since i live in a country in soith america where we dont have a lot of tuners i am trying to learn things myself. Any help would be appreciated. The logs are attached.both logs were made with 97 octane renegade racing fuel. Dragy info: 79 fahrenheid
DA:1796 ft
Sealevel :8ft
RadarContact's Avatar
Car: 2006 E46 330cic ZHP
Default 11-06-2019, 07:56 PM
I need to update my firmware, but the big red note says:
ď***DO NOT UPLOAD FIRMWARE UNTIL YOU READ THIS *** All Duty Bias must be set to 0 or 50 to avoid 30FF under boost codes. 3rd gear boost limiting should also be set to 0 to disable. Menu4 in dash should be set to 3 for a factory flashed car or 2 for a back end flashed car. Failure to follow these directions will result in poor performance and 30FF or 30FE fault codes.***
I have a custom Trebila Performance (map 6) tune that has duty bias at 50 until 5,000 rpm then it goes up from there. Is that going to cause error messages and/or problems? (Or is it intended to say equal to or greater than 50?)
// Radar //
2010 535i M-Sport w/Sport AT, Alpine White w/Natural Leather, type-135 wheels w/spacers & Coilovers --- JB4 G5 ISO Trebila (Map-6) Custom Tune, Custom Meth Setup, VRSF 3" free-flow D/Ps, MMPe DCIs, Wagner 1060 Stepped FMIC, VRSF Chargepipe/Tial BOV, BMS Oil Cooler Valve
