(#501)
2.7Boosted-Brad's Avatar
2.7Boosted-Brad 2.7Boosted-Brad is offline
Car: 2018 F-150 2.7
Angry Check Service manual message - 06-16-2019, 04:59 PM
WOT for more than 4 seconds or so will often send the truck into limp mode (check service manual message) comes on. Everything looks good in the logs to me, overboost?
Default 06-16-2019, 06:38 PM
Update to v6 firmware in the first post and relog so we can see fuel pressure...
Car: 2018 F-150 2.7
Default Wow! - 06-17-2019, 04:28 PM
Amazing customer service! I was having trouble updating and kept getting an error after updating. I kid you not five minutes after emailing support I got the solution I needed!
Default 06-17-2019, 05:34 PM
Glad to hear it!
Car: 2018 F-150 2.7
Default Limp mode - 06-17-2019, 09:05 PM
Limp mode in map 5, here’s the log.
WOOSH!
Default 06-18-2019, 09:47 AM
I can't see any obvious cause, but map5 is up there. Does it come up on map2?
Car: 2018 F-150 2.7
Default 06-18-2019, 10:04 AM
Will log again tonight on map 2. Only 1 out of every 20 or so runs on map 5 will it be triggered.
WOOSH!
Default 06-18-2019, 02:04 PM
Got it... And never any codes?
Car: 2018 F-150 2.7
Default 06-18-2019, 05:39 PM
30 roll triggered it again +p0263 code. (Map 5 still)
WOOSH!
Default 06-18-2019, 05:41 PM
I think it's just a boost under target code. Map 5 is too high, you're not making as much boost as is being requested, and thus the fault. The P0263 number looks up to some sort of cyl1 misfire sort of code though.
Either way I'd get over to map2.
Abyssf150 Abyssf150 is offline
Car: 2019 f150 2.7 Ecoboost
Default 07-05-2019, 09:09 PM
I'm running a 2019 f150 2.7 completely stock other than JB4. Which firmware should I be running 3.hex or eco 6.hex?
Default 07-05-2019, 09:46 PM
Either is fine, v6 is the latest one.
Default 07-05-2019, 09:50 PM
OK thanks just wanted to be sure. So far so good. Are the pure 550s going to be available on your website?
Default 07-06-2019, 09:40 AM
No we don't sell them, so just contact Pure directly!
Default 07-07-2019, 08:41 AM
Hey I keep getting a p0400 EGR valve fault ever since I updated to the 6.hex firmware. I'm currently putting it to map 0 to see if this clears it up. Anyone else having this issue? Should I go back to version 3?
Default 07-07-2019, 10:24 AM
Not had any reports of that specific to v6 but easy to go back to v3 to confirm it's related!
Normally that fault is related to intakes in my experience.
Default 07-07-2019, 01:11 PM
Completely stock other than JB4. I'll keep an eye on it. And will switch back to v3 if it pops up again. Thanks you
Codeman911 Codeman911 is offline
Car: 2018 Ford F-150 3.5 EB
Default 07-08-2019, 05:50 PM
Hi all! I have a 2018 3.5 and want to try E30. My truck is stock other than the JB4. What do I have to do? Fill it with E30 and run the tune for E30? Is that all or do I have to blend the E30 with premium? Tia
Default 07-08-2019, 06:54 PM
Just add in 6-7 gallons of E85, select map2 or map3 on the JB4 to start, and enjoy!
Car: 2018 F-150 2.7
Default 07-08-2019, 07:39 PM
I would occasionally get that code, usually after a bit of idling and driving like a granny. This was back when I was stlll running version 3 though.
WOOSH!
Default 07-09-2019, 05:37 AM
Blend E85 with E30 or premium?
Default 07-09-2019, 09:13 AM
You have e30 at the pump? If so just fill up with that.
Or mix e85 with premium, yes.
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 07-09-2019, 12:11 PM
Im getting p04DB - Crankcase ventilation system disconnected.
v3 and v6 stock intake. Dealer replaced Crank case hose. Came back again. Anyone else?
Car: 2018 F-150 2.7
Default 07-09-2019, 03:26 PM
Have yet to see that before, had a catch can for a bit as well.
WOOSH!
Default 07-09-2019, 04:28 PM
I've seen that one before from time to time. I think it's tuning related but not exactly sure how yet. Never comes up on map0 right? It should be an easy fix once we narrow it down.
Able to pull your freeze frame data on it with an OBDII tool?
