(#4301)
Speedy164's Avatar
Speedy164 Speedy164 is offline
Car: 2019 Infiniti Q50 sport AWD
Default 06-17-2019, 06:05 PM
Hello Terry I have a 2019 Infiniti Q50 Silversport with HKS lower ** and fuel wires running Map6 can you look at these logs please let me know what you think.
Default 06-17-2019, 06:21 PM
They are map5 logs but seem fine to me!
V@pors's Avatar
V@pors V@pors is offline
Car: 2017 Infiniti Q60 RS AWD
Default Hesitation between 2-3K RPM - 06-17-2019, 09:29 PM
Hey everyone. I am experiencing some hesitation or missing under light to moderate acceleration. Car is not throwing any codes. I have attached a log of a full throttle 3rd gear pull. Any ideas why I would be experiencing this under light to medium acceleration? Any input would be greatly appreciated.
2017 Q60 RS400 AWD Midnight Black/Monaco Red
AMS Cold Air Intake | AMS Heat Exchanger | AMS Coolant Expansion Tank
BMS JB4 w/Fuel & EWG Wires | Z1/HKS BOV kit | Fast Intentions catted FDP's | HKS Legamax CBE | Mishimoto OCC
Z1 2-piece rotors | HRE FF04 10x20" front 11x20" rear rims | Pirelli PZero PZ4 tires 265/35/20 x 305/30/20
Blackview DR750s-2CH camera system| Blackview Power Magic Pro
Car: q50
Default 06-18-2019, 04:35 AM
Originally Posted by nspireaviation
Can anyone look at my log, i did a quick 3rd-4th pull this morning when it was cool 78*. Running map6 with 4+ in the powerband
pic: jb4 map6 3rd-4th - Album on Imgur
csv attached as well
You'd benefit from some fuel wires. Otherwise looks ok to me.
Originally Posted by 05g356mtt
Hello,
New to the Q50 and Tuning with JB4. Can someone please take a look at this log.
2019 RS AWD on 93 Costco (10% Ethanol)
Helm Holtz Axle Back
Fuel Wires
JB4 Map 6 +4 Tapered (credit Lordie @ VR30 Tech Talk FB Group)
(1500-7000)
2.5
3.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
3.0
2.0
BMS HE going on thursday, looking to push it to +5 after HE install. Any input would be appreciated.
Nice log!
Car: q50
Default 06-18-2019, 04:43 AM
You probably should manually turn on record under the light to medium acceleration. From the log at WOT, AFR and trims look fine. Timing really drops during the beginning of the pull (<5 degrees), almost like you're commanding too much boost too early. Maybe try and go back to map 1 or 0 and see if the issue goes away.
Speedy164's Avatar
Default 06-18-2019, 01:47 PM
Oops sorry Terry here are my Map 6 logs, 2019 Q50 Silversport 93 octane, HKS ** and fuel wires
nspireaviation nspireaviation is offline
this your captain speakin
Car: 2018 Q50s
Default 06-18-2019, 04:11 PM
Nice log!
fuel wires with just 93pump (10% E)? would that really help? - still trying to learn what ideal AFR's are for this car - is it the normal 12.5?
2018 Q50s
Car: q50
Default 06-18-2019, 04:34 PM
Before the meth that's what I ran. The new target is mid to low 12s which is more suitable for direct injection.
Default 06-18-2019, 05:25 PM
It's fairly aggressive for 93 but if it's working for you then roll with it.
Speedy164's Avatar
Default 06-18-2019, 05:37 PM
It's my first time testing it out maybe I'll dial it down 1 psi, if you are saying fairly aggressive. I don't want to ruin or break anything. I just ran Map 6 today.
Car: Red Sport 400
Default 06-19-2019, 09:14 AM
Nice log!
Appreciate the input! Mind taking a look at this log? Pushed it to +5 last night, Ign dipped to 2 at 3000ish, but went back up. Is it normal to dip that low?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-19-2019, 09:42 AM
Added a FB101 on Monday, and AMS lowers going on Friday, looking fwd to some fresh logs and hopefully feeling the power gains from the lowers
12.64 @114mph
0-60 4.46
jrobohm's Avatar
jrobohm jrobohm is offline
Default 06-19-2019, 10:04 AM
You will love the AMS LDP
Be sure to save some $s for the BMS WMI - early results / logs on my Q50 are impressive. Soon as I have the settings dialed in I will go back to the dyno and post the results.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM3.5s
  • Pure Stage 2 Turbos
  • Z1 PU Motor Mounts
  • AMS HPFP (RA338) & LPFP
  • AMS Flex Fuel Kit v2
  • AMS LDP
  • Fast Intentions Res. Touring 2.5 CBE
  • Mishimoto Oil Catch Can
V@pors's Avatar
Default 06-19-2019, 08:36 PM
Thanks for your input. I did some runs at moderate throttle and have attached a file for your review. I have also attached a pic of my Map 6 settings. I may not be understanding something, but I am not sure how I could be commanding too much boost too early since I don't even add any boost until 3,000 RPM. Anyway, if you graph the .csv file, you can see how the RPM seems to increase sporadically, which shows what I am talking about.
Also, in researching this, I found that my Future Use D, Bit 7 was turned on. I don't recall turning it on. Does it default to "on" with update to the new firmware version? Also, what should the "default" setting be? Mine was somehow set at "129." I turned Bit 7 off for this run for which I attached the .csv file. Thanks.
Car: q50
Default 06-20-2019, 04:34 AM
Your timing is pretty low the entire pull, but that's likely due to the boost you're running. My hunch is that right at 5900 might be a hint of knock. It isn't a serious drop like we normally see, but there shouldn't be a timing drop that high in the rpm range. I'm actually surprised its not worse given the amount of boost youre running with no meth.
No idea on the bit 7 being 129 thats wierd. I dont think I had mine on. Only thing I use is the fuel wires enabled bit and meth bits. As far as the log, yes I see the rpm "stair step", that is odd. You running 93? It almost looks like its spark breaking up, like you need to do plugs. When's the last time you've done basic maintenance like air filters and put some fuel system cleaner in it?
Car: Red Sport 400
Default 06-20-2019, 06:35 AM
Appreciate the input again, definitely helps with trying to understand reading the parameters. I'll go back down to +4 since that log seemed a lot cleaner.
5oh_mo 5oh_mo is offline
Car: Q50
Default 06-22-2019, 07:15 AM
What would cause a dip in torque demand from 3900 - 4800 on a Red Sport? Optical sensors?
17' Q50 RS
Default 06-22-2019, 02:17 PM
Recovering from food poisoning so maybe missing something here, but not much WOT here to look at.
Bit7 is an option to dampen part throttle boost per notes in the first post.
PRQ50 PRQ50 is offline
Car: Q50
Default 06-23-2019, 12:11 PM
Are there any plans of adding actual transmission fluid temperature, to the parameters of the JB4 for those of us doing our own transmission fluid changes?
2017 Q50 RS AWD
JB4+FW
AMS intakes
FI ldp
FB HE
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-23-2019, 12:28 PM
I use the Trans Temp gauge to determine if I am close to heat soaking.. is that the best gauge to use?
12.64 @114mph
0-60 4.46
Default 06-23-2019, 12:49 PM
We don't currently have the logging PID for it so until we find that we can't add it.
UNEEK UNEEK is offline
Not a Racer
Default 06-23-2019, 06:27 PM
This is my first log, current update my engine check light is on, This is on standard mode up going up the bridge, seems a little off ?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-23-2019, 06:58 PM
Hit the "Go Advanced" button then 'Manage Attachments' option. Upload the csv file
12.64 @114mph
0-60 4.46
Car: Red Sport 400
Default 06-24-2019, 05:45 AM
This may be a dumb question but after logging a few runs, I've noticed the stock ecu psi on my RS seem to max out at 13.1psi at 4500rpm while others seem to be able to hit higher ecu psi. Is this where better fuel comes into play?
Ordered LDP's, with LDP's not being restrictive as stock cats will stock ecu psi be higher?
Default 06-24-2019, 10:24 AM
ECU psi depends on IAT, fuel used, elevation, etc. It's never an absolute target, so it does vary.
