(#4276)
Default 06-05-2019, 03:02 PM
Originally Posted by Serstylz2
Thanks, I'll pick that up since you all saved me some cash on the maf housing
Car: 2018 Q60 3.0
Default 06-07-2019, 02:09 PM
Heat Exchanger or Intercooler???
2019 Q50 Red Sport
Burger JB4
Burger Cold Air Intake
Burger Fuel Wires
Burger Elite Heat Exchanger
Megan LDP
Car: q50
Default 06-07-2019, 02:19 PM
What? Stock intercoolers are fine, it's the HE that's terrible.
Car: 2018 Q60 3.0
Default 06-08-2019, 02:45 PM
So when ordering, is it the heat exchanger or the ELITE heat exchanger? They boy have the exact same description, but one says elite and is $399 and the other is $299.
2019 Q50 Red Sport
Burger JB4
Burger Fuel Wires
Megan LDP
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 06-08-2019, 03:02 PM
299 one is made overseas, 399 one is made in MURICA. Both are heat exchangers. The Q50 intercooler resides in the engine bay. It's not a front mount intercooler like you've seen in the past
12.64 @114mph
0-60 4.46
nspireaviation nspireaviation is offline
this your captain speakin
Car: 2018 Q50s
Default 06-11-2019, 04:25 PM
just downloaded the latest firmware for the vr30 jb4 Bluetooth, I cant select engine type in the settings, it doesn't exist, is this the norm now?
Also is there a link to a more technical side of each value I can select and change in the app?
2018 Q50s
UNEEK UNEEK is offline
Not a Racer
Default 06-11-2019, 04:48 PM
Hello guys and i am exited to join this team, I have recently purchased a 2019 Q50 Silver Sport, Right now this car is at 3,500 miles and its been giving me problems, At 3,000 miles my Fuel Injector was broken this was after the installation of my JB4 tune with BMS Cable , i don't know if this happened because of the tune or because it was the manufacturer defect ( The Fuel Injector was replaced) After I have taken the car to the highway full throttling it malfunction icon popped out and the check engine light is on also, I have updated the jb4 with the latest update but maybe i downloaded the wrong update, if you guys could send me the up to date update for this car that would be perfect, also I was just wondering on the data log on how to properly record, do you click start logging before you start moving or while you are moving on 3rd gear before 2,500, because i have tried data logging and after i click stop and view nothing shows. I have been running the car on map 5 with 93 octane but recently went to map 3 because of all the issues ive been having.Thanks again for reading this and hopefully I could fix the issue, other than that it is night and date from stock to this tune.
Default 06-11-2019, 09:56 PM
Not possible for the JB4 to damage a fuel injector so likely unrelated, maybe something to do with running more power exacerbating a factory defect sooner than it would have otherwise shown up.
Car: q50
Default 06-12-2019, 04:42 AM
You have to be wide open throttle for the logging to be active if you don't press the button to start logging.
vietnameeh vietnameeh is offline
Car: Q50
Default 06-12-2019, 08:01 AM
I did a quick log in Map 2
It might be too short, how does it look?
JB4 + Fuel Wires + 91 octane
Car: q50
Default 06-12-2019, 08:09 AM
Looks good to me!
Car: Q50
Default 06-12-2019, 08:11 AM
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Default 06-12-2019, 09:11 AM
Looks good to me!
+1.
Car: 2018 Q50s
Default 06-12-2019, 01:35 PM
Terry, can you confirm the current map profiles and target boosts for each? A couple people on the forum mentioned different numbers:
I logged Map 1, Map2, and Map3.
Map1 target was 4psi
Map2 target was 5psi
Map3 target was 3psi (yes 3psi)
Can you also confirm if there is still an engine selection under settings? I do not have it in my current jb4 app with the latest vr30v7 firmware.
Additionally is there a source for a more technical explanation of each parameter in the user adjustment settings?
2018 Q50s
Car: Q50
Default 06-12-2019, 02:12 PM
Looks good to me!
+1.
Thanks guys
can I ask to check once more. I logged in the same spot (went home for lunch lol)
this time the weather today is "hot" for CA 95*
this morning log was at 65*
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Car: q50
Default 06-13-2019, 08:29 AM
Originally Posted by vietnameeh
Thanks guys
Still looks fine. A little odd your pedal didn't look like it was all the way down, but close.
Car: Q50
Default 06-13-2019, 01:17 PM
based on that would I be able to try Map 3 ... or am I pushing it lol
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Car: q50
Default 06-13-2019, 01:32 PM
I would try moving to map 6 if it were me. Havent see anything that is cause for concern.
Car: Q50
Default 06-13-2019, 04:05 PM
Awesome thanks
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
Car: q50
Default 06-13-2019, 05:03 PM
Awesome thanks
shoot for one of the tapered boost curves, maxing at like 6 psi, and post a log. Try to get a higher gear log as that's when knock/timing drops will be more prominent.
EvolvingApe EvolvingApe is offline
Car: Infiniti Q50
Default Default Boost Targets - 06-15-2019, 03:25 PM
Would anyone be able to help me find what the default boost targets for Map 1 and Map 2 on the JB4 (latest firmware) are? I'm playing around with Map 6 at the moment and would love a baseline to work off of. Thanks in advance!
2019 Q50 Red Sport 400 RWD - JB4
Car: Infiniti Q50 RS400
Default 06-15-2019, 03:44 PM
3
3.5
4
4
4
4
4
4
3.5
3
2.5
2
4
4
4
4.5
5
5
5
5
5
4.5
4
3.5
Car: Infiniti Q50
Default 06-15-2019, 06:11 PM
Originally Posted by Rs400newbie
3
3.5
4
4
4
4
4
4
3.5
3
2.5
2
4
4
4
4.5
5
5
5
5
5
4.5
4
3.5
You're awesome. Much appreciated!
Car: 2018 Q50s
Default 06-16-2019, 04:13 AM
Can anyone look at my log, i did a quick 3rd-4th pull this morning when it was cool 78*. Running map6 with 4+ in the powerband
pic: jb4 map6 3rd-4th - Album on Imgur
csv attached as well
2018 Q50s
Car: Red Sport 400
Default 06-17-2019, 03:51 PM
Hello,
New to the Q50 and Tuning with JB4. Can someone please take a look at this log.
2019 RS AWD on 93 Costco (10% Ethanol)
Helm Holtz Axle Back
Fuel Wires
JB4 Map 6 +4 Tapered (credit Lordie @ VR30 Tech Talk FB Group)
(1500-7000)
2.5
3.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
4.0
3.0
2.0
BMS HE going on thursday, looking to push it to +5 after HE install. Any input would be appreciated.
