(#76)
Choyo_n55 Choyo_n55 is offline
Car: E90 335i n55
Default 06-06-2019, 09:23 PM
Originally Posted by CTM95
Connect Kit is the bluetooth module that let's you use the app on a phone or tablet.
I'm using usb cable and laptop ,and get the same code 3166 and SES light,when i start the car...I have not updated my firmware yet and I'm running 5/15/1...
mfromani mfromani is offline
Car: E93
Default 06-20-2019, 05:46 PM
Well as it seems as my posts aren't ever answered by the powers that be I'm ripping this thing out. Been running MAP 0 and it still throws codes and the "half engine" reduced power mode light comes on randomly.
Anyone want a slightly used JB4? I'll sell it cheap.
Default 06-20-2019, 06:45 PM
If you're in need of individual tech support you can always email in also. We're not able to monitor and reply to every thread on the forum.
If you have older DME software you should definitely update it. Did leaving MAP connection stock resolve the issue for you?
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 06-20-2019, 07:33 PM
This entire thread is full of people experiencing the same issue. If you want each of them to email in that would be less productive. Understandably you guys are busy but currently you're selling a tuning solution that throws CELs even with unmodified emissions systems.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
andrews013's Avatar
Car: 2013 E92 335i xDrive
Default 06-21-2019, 06:37 AM
Exactly. The only way I could fix it was enabling auto-clear, which I would prefer to not do.
Default 06-21-2019, 09:09 AM
There are literally 1000s E series N55 JB4s out in use... and a handful of people in the thread going back to 2018 reporting this 3166 code.
Happy to continue working with you to resolve your cars issue but it's something specific to those few cars triggering it.
Scrolled back a bit and the latest test was to revert MAP sensor to stock to evaluate. And the result of that test was?
mishmosh mishmosh is offline
Car: bmw x1
Default 06-21-2019, 11:40 AM
With stock MAP connected, I am happy to report that with menu 10 at 1800 and menu 12 at 2000, 28A0 code has not appeared in the past 2 weeks. Still get 2c90 but have always had that (for years) and it doesn't trigger the dash check engine light.
So if you connected the stock MAP, make sure to check your menu 10 and 12 settings.
Car: E90 335i n55
Default 07-10-2019, 04:45 AM
Something strange happened to me with this error 3166. 3 weeks ago I decided to drive the car on map 0. I was driving so one day and then for three weeks this error did not appear but before it went out every third start of the car with SES lamp.
drwillb drwillb is offline
Car: 2012 n55 135i
Default 07-10-2019, 05:19 AM
I found a fix to all the code problems. About six weeks ago I completely removed the entire JB4 to pass state inspection. I haven’t had a single code since then.
2012 135i Mods: air scoops, CP, BMS filter, PS1, N20 TMAP, ADE FMIC, BMW PE, JB4, BMS BEF, 1M front body, full M3 suspension
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i
Car: E93
Default 08-19-2019, 05:26 PM
Stock MAP same result as reported random CEL with sometimes half engine light. Car is fine now that I took out the harness. Haven't had a half engine light in 6 weeks. I really wanted this to work but could never get the readiness settings to stay on so just wasn't going to pass smog check. JB4 and BT Connect is for sale on Ebay if anyone wants to give it a go. Maybe you'll have better luck.
MrHaloHalo MrHaloHalo is offline
Car: 2014 X1 35i
Default 12-17-2019, 03:23 PM
I loaded the PUMP_BEF last week (now that you don't have to remove and bench flash the DME to load MHD anymore) and have driven about 150 miles on map5. The 3166 code has not occurred once since I've been running the BEF!
Default 12-19-2019, 11:10 PM
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
