(#326)
t-800's Avatar
t-800 t-800 is offline
Car: rs3
Default 05-17-2019, 11:46 AM
Ahh, okay I just wasn't sure exactly on the first post. Great job man!
Thanks !
RS3............In the UK
Ctjallen Ctjallen is offline
Car: 2018 RS3
Default 05-17-2019, 01:49 PM
I found 100 octane close to where I live, anybody run their RS3 on 100 yet?
Default 05-18-2019, 05:43 PM
I ran around 100 and map 5 was good. When in doubt shoot over logs though.
Car: 2018 RS3
Default 100 octane - 05-18-2019, 07:02 PM
How long did it take the ECU to adjust to the higher octane?
Default 05-20-2019, 06:25 AM
One or two full throttle pulls and you good.
Hckymstr19 Hckymstr19 is offline
Car: Audi rs3
Default 05-20-2019, 07:01 AM
Hey george did I read somewhere that you are currently working on being able to tap into the second set of injectors with the jb4?
Default 05-20-2019, 07:26 AM
At this point we are working on the low pressure side to add more fuel. We havent done work on secondary yet or at the moment seen a need since it seems supply from the back is the primary challenge.
Myrder Myrder is offline
Car: 2010 335i
Default 05-22-2019, 08:33 AM
Thats interesting, it seems all the flashes utilize the port injection to get full e85 available while running the stock LPFP
335i LMB E92 6MT MSport Logic7
Default 05-22-2019, 09:07 AM
Yes once you flash you have a little more headroom on the fuel trims side. But run in to limitations on the fuel pump and fuel injectors shortly after. For those who want to run straight E85 you're going to have to bite the bullet and flash the car. And once you do can still use the JB4 on top of that for fine tuning, boost by gear, logging to your smart phone, etc, etc.
Car: 2010 335i
Default 05-27-2019, 12:09 PM
Hey Terry,
You going to develop intake or any bolt on for the rs3/ttrs platform? They can use a dsg breather and maybe a catch can too. Just seems kinda stagnant compared to your other platforms.
Bullitt1841's Avatar
Default 05-27-2019, 01:42 PM
Hey Terry,
Not much of a market for the RS platform based on how many cars are produced and the fact that there's already multiple offerings out there. There's a lot more R&D for making hard parts. I could see breathers or catch cans, though. Give it time.
Car: 2010 335i
Default 05-27-2019, 02:29 PM
I suppose that has some merit. Under 3000 rs3 from 2017-2019 and ttrs even less. Though there are some low hanging fruit there for parts for sure.
Default 05-27-2019, 02:53 PM
Hey Terry,
Testing a DSG breather/catch can system now. Trying to get the right design to keep it simple to install/remove and still effective. Will share details when ready.
As to the intake would be cheap/easy to do but I think that market is already well saturated? What is the cheapest intake out?
We will have an IC option using the same core we're developing for the B9 S4 and Kia Stinger.
tegxsi tegxsi is offline
Car: RS3
Default 05-27-2019, 06:47 PM
Most intakes are ridiculously expensive because they are made with carbon fiber.
I think CTS makes the cheapest intake.
I'm running a Forge motorsport 3.5" inlet hard pipe with K&N panel filter. It works for me...keeps things quiet.
Keep in mind the the 2019 models have changes on the DV hose.
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
Car: 2010 335i
Default 05-27-2019, 10:24 PM
Plus one on the 2019s. Also yea intakes are like... $400 cheapest...
Luqmaanmall@gmail.com Luqmaanmall@gmail.com is offline
Car: 2018 RS3/ 2018 M240i
Default 2018 RS3 - 06-11-2019, 09:55 AM
Hi
Has Anyone experienced a knocking sound/inconsistent idle after driving their RS3 a bit hard. I experienced this on MAP1, oil temp was around 104°C. Once I put it into MAP0 and temps lowered, it seems to have disappeared. Also, randomly under acceleration, the car seems to lose boost completely in 3rd gear. My car only has a BMC filter and runs on 93 unleaded. The JB4 read 2 codes (P0804 and P01302), not sure what these are. Any help would be greatly appreciated!
Default 06-11-2019, 10:35 AM
The JB4 monitors knock in all cylinders, post up a log so we can check it out! On the faults if you clear all codes ign on, engine off (sometimes takes a couple times to clear), when do they come back?
Matthias Matthias is offline
Car: RS3
Default Boost lags,..?! - 06-14-2019, 10:05 AM
2019-06-13noboosst 16_00_06_Map-6.csv
Hi all,
same problems here with the boost sometimes, which user"theskunk" reports.
Pull the Pedal , no Boost. Then get off an pull again, geos off like hell.
Only Pipercross plate filter and PPH Air Pipe 90.
Runs with 102 Oktan. JB4 with BCM and v4 Firmware.
Happened in all Maps. Exampel in Map 6 + 6 psi
Results enclosed.
Is there any new Firmware in progress ?
Greetings
Default 06-14-2019, 10:44 AM
Originally Posted by Matthias
Attachment 87426
Attachment 87425
Hi all,
Results enclosed.
Greetings
We working on resolving it. Our car rarely does it which makes it a bit harder to pin point but its on our priority list.
t-800's Avatar
Car: rs3
Default 06-19-2019, 08:11 AM
I've had this (UK) a few times now, upon pressing the pedal it feels like nothing is happening, usually 3rd gear, then it eventually goes.....
Default 06-19-2019, 10:46 AM
I haven’t been able to recreate the issue, it seems that shifting a bit early into 3rd causes the loss in boost. Been running Map4 on 102 octane (BMC filter is the only hardware) and haven’t experienced the same issue, only happened in map 1/2 on 93 octane.
Car: RS3
Default 06-19-2019, 05:18 PM
There are times when the ECU limits throttle to ~65%. Other times the car will start to build boost then the ECU suddenly cuts throttle to ~30%.
Usually if you let up then go WOT again and it's fine. Occasionally the car won't go no matter how many times I try letting up.
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
theskunk's Avatar
theskunk theskunk is offline
Car: Audi RS3
Default 06-21-2019, 08:25 PM
I was having it about once a lap on an open track day at VIR on Monday. Ultimately, I decided to disconnect the JB4 until an update comes along to resolve this. If additional logs are useful, I’m happy to reconnect.
Daily Driver: 2018 RS3, Black Optics, Dynamic+, Driver Assist, STM resonator delete, STM intercooler, CTS Turbo Intake, EMD Springs/Swaybars, Girodisc Rotors, Carbotech pads, 034 goodies everywhere.
Tow-Vehicle: 2018 Jeep Grand Cherokee, Overland, 4x4 + Hemi
Past:
2000 3.8L Mustang - All bolt ons, 8.8 rear conversion
2007 Honda Accord - I had a moment of “sensible-ness”
2011 BMW 335D - Custom intake, JBD
2014 Audi S4 - Intake, Chipwerke, Couple of VCDS mods
Glfdriver18 Glfdriver18 is offline
Car: 2018 Golf R
Default 06-24-2019, 08:25 AM
Just traded my 18 R for a 2019 RS3, can’t wait to get a JB4 on it. However, this intermittent loss of boost issue is making me wary. I just want something that works, every time. Probably stay stock until they manage to figure it out.
Default 06-24-2019, 09:16 AM
Given the intermittent nature and the fact that the issue comes up on the RS3/TTRS but not the B9 S4 that uses the same hardware, it's been really tricky to pin down. We're testing a circuit board change right now to see if that has any effect on it.
