drdiabetes drdiabetes is offline
Car: bmw 335i e92 AT
Default Oxygen sensors for SINGLE TURBO... ADV or NTK?? - 05-21-2019, 09:56 AM
Hello, I am single turbo 6466 doc race kit. As it is known, oem o2 sensors get cooked in the pre turbo atmosphere.
I have been reserching in forums and someones go into ADV ( by motiv) and others go into NTK.
Adv are sold out , 450usd pair and need some special config
NTK are like 330usd pair, and I think no special config.
Also some people use oem bosch sensor + separator
What is your experience single turbos boys??
Can someone clarify this ???
Thank you
335i AT 2008
DOC RACE 6466 SINGLE TURBO
JB4 G5ISO + MHD TUNING
FUEL IT PI kit BMS controlled
FUEL IT STAGE 4 LPFP
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
NGK SPARKS TWO STEPS COLDER
gingerbreadman gingerbreadman is offline
Car: 08 335i
Default 05-21-2019, 04:03 PM
Docrace 6266 here with the ADVs and tuned by Motiv. No issues whatsoever and had them on for about 2yrs now.
current
2008 335i: Stoptech ST60 and ST40 BBK, VRSF 7" fmic, VRSF ***, ST coilovers, Vk motorwerks oil cooler, ER charge pipe, forge dv, cobb v3, bms occ, K&N Drop-in Mr. 5 intake, Steve AZ Stage II Fuel pump, E60 Tune by BQ Tuning/Wedgeperformance. (coming: MMP Intakes + N20 T-map sensor=22psi)
Previous
-N52 to N54 swapped e90: RIP
-T3/T4 turbo'd Mustang
-4G63 Mitsubishi eclipse
steve30's Avatar
steve30 steve30 is offline
Car: E36 M3, E90 335i
Default 05-21-2019, 06:03 PM
I'm running the doc race kit as well. I went with the ADV's initially and it worked for a short period and then kept having issues. I tried to resolve it with Chris but nothing worked. I'm now using the NTK's and everything is working properly. It's really hit or miss with the ADV's. Some guys don't seem to have issues, where others cant resolve it and NTK's end up resolving it.
Default 05-21-2019, 07:23 PM
Do ntks need some calibration as adv do??? Or they are just as installing oem sensor??
335i AT 2008
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
Car: 08 335i
Default 05-22-2019, 03:07 PM
IIRC they are just pnp...no calibration needed.
current
Previous
steve30's Avatar
Default 05-23-2019, 06:04 AM
yes the NTK's are just plug and play.
Default 05-23-2019, 11:19 AM
I use the Bosch ones. Rock auto for $80.
Default 05-24-2019, 12:53 AM
Used ADV for a bit- Initially had issues- got them sorted with motiv
Used NTK with my hybrid pure setup (plug & play btw)- had issues with a few sets
Default 06-28-2019, 02:38 PM
Update
I installed a pair of NTKs and one get roasted in 200miles.
Now, I will try a "spacer" that moves away the O2 sensor some inches with oem bosch o2 sensor
335i AT 2008
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
chadillac2000's Avatar
Car: 2008 535i
Default 06-29-2019, 07:56 AM
Been running NTKs with no issues for 40,000 miles now with zero problems. Started single turbo life with a set of ADVs that gave me problems from the first start up until I replaced them. Motiv sent multiple tunes, but nothing corrected the problem. Swapped a set of NTKs in and everything worked perfectly and still is. Having to tear back into the car to swap o2 sensors after going through all the work of a single turbo swap was frustrating to say the least.
SPANKY's Avatar
SPANKY SPANKY is offline
Car: 2008 335i
Default 06-29-2019, 02:57 PM
what i dont understand is the adv02 are rated for high temps compared to ntk and yet the adv02 dont work properly.
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH-
-NGK PLUGS*BMS OCC*RB VALVE-
-E85 MHD FLASH-
Default 06-30-2019, 04:50 AM
Ntks also supposed to be for pre turbo atmosphere and mine failed after 200miles.
I don't know why they fail , I have seen ntk or bosch in big turbo subarus , audis etc where the exhaust manifold gets incandescent red and they don't fail.
I suppose that there is something else killing o2 sensors. May be external temperature?? By the way, I always kill the same sensor ( bank1). Bank2 never fail and it is also in a "unhealthy " atmosphere.
335i AT 2008
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
Martin335ST Martin335ST is offline
Car: BMW 335 Single Turbo
Default NTK sensors - 09-20-2019, 06:27 PM
Can you point me to a part number? Which specific NTKs are you running? I'm looking to get proper O2 sensors for my single turbo setup, Doc Race 6266.
Default 12-30-2019, 10:13 AM
upgrade
Ntk + innovate heat bung extender bank 2 burned!!!
Any solution for single turbos??? Or I better buy a ten of bosch sensors and replace them as disposable units???
I burnt 4 sensors 1) oem bank1 2) ntk bank1 3) oem bank1 + spacers
4) oem bank2 + innovate heat sink extender
I run 6466 doc race kit
335i AT 2008
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 12-30-2019, 03:09 PM
upgrade
Maybe your EGT is too high? You're doing it right using the extenders and syncs, it's an unfortunate effect of running pre turbo o2. But in response to an earlier post, ADV and OEM sensors should be recalibrated when ran pre-turbo. Factory tables are very off.
DamnDatsun's Avatar
Car: 2010 135i msport
Default 12-30-2019, 04:56 PM
Ive seen a bunch of people talking about turning the ignition on (without starting the engine) and letting the o2's "warm up" for 45-60 seconds, THEN starting the engine. A bit inconvenient, but after recently having to replace o2's myself, I'm going to give it a try.
I had stock sensors btw. Lasted about 3k miles.
Default 01-04-2020, 07:40 PM
What do you mean by racalibrate oem sensors?? Adv need tune... does oem too??
335i AT 2008
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
Default 01-04-2020, 09:14 PM
Updates!!!
New bosch o2 sensor + innovate heat sink.
Do some pulls in 3 geard. From 2000 to 4000 4500 rpm ok..then running lean and misfire.
Another pull and the same. Couldn't finish because the car misfire .
Last pull :
30BA dme internal failure
2C3B lambda probe in front of catalitic converted : not plugged
29CC misfire , several cilinders.
( cil 1 2 3)
The car has check engine now and running in 3 cilinders.
Bank 1 afr stack at 20 ( sensor has 20 miles)
I attached some logs... as i said i couldn't run from 2000 to 6500rpm as the car started to misfire
What do you think?? Could be the tune??? It is impossible to burn o2 sensors as me..and know I have this new issues.
I will have the ecu fixed ( injectors integrated circuits???) Then check cil 6.. (injectors / coils/ spark).
What do you think??
335i AT 2008
XHP flash stage 3
VRSF RACE EXHAUST
VRSF 7.5 FMIC
v8bait's Avatar
Car: E92 335i 6MT
Default 01-05-2020, 08:06 AM
If you want them to read accurately, yes.
Updates!!!
Last pull :
( cil 1 2 3)
What do you think??
You had an injector mosfet fail, and need to check your O2 sensor wiring for burns/cuts etc. Alternately the failed mosfet to back 1 injectors could be why you're seeing those readings, so repair the dme first before spending more money imo. Mosfets are cheap and fix the issue permanently.
