(#501)
tmal's Avatar
tmal tmal is offline
Car: BMW E92 335i
Default 04-04-2019, 10:41 AM
Terry, some pulls on map2, please look at the logs.
Default settings like in the first post
Thanks much
2008 E92 335i AT - MMP1k's, MMP inlets/outlets, FMIC WAGNER EVO3, TMAP 3.5 Bar - PRW Stage 2+ LPFP - JB4 g5 - MHD BEF
N54710 N54710 is offline
Car: 2007 bmw 335i
Default Help needed - 04-06-2019, 05:45 PM
Hey terry I got a question for you. I have a 07 335i with a bad dme now my question is can I put a newer one in there is an 08 and 09 both at the junkyard. Can I use them and just change the timing though my jb4. Or do I need an 07 dme.
Haynpunch's Avatar
Car: 07 E90 335i
Default 04-06-2019, 07:12 PM
if you are going that route might as well upgrade to MSD81
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 2007 bmw 335i
Default 04-07-2019, 11:42 AM
So the dme from 09 335 would be better to use. Rather Than trying to find 07 dme. I’m running d.p., exhaust, charge pipe with bov, stage 2 turbos, stage 2 bucketless lpfp, dci , Mmp inlets , vrsf outlets, fmic, rb pcv, occ, jb4, mhd bef. So msd81 better than msd80?
Wladvertise Wladvertise is offline
Default 04-08-2019, 02:07 AM
So the dme from 09 335 would be better to use. Rather Than trying to find 07 dme. Iím running d.p., exhaust, charge pipe with bov, stage 2 turbos, stage 2 bucketless lpfp, dci , Mmp inlets , vrsf outlets, fmic, rb pcv, occ, jb4, mhd bef. So msd81 better than msd80?
you will have to Re-Code your DME either way, doesnīt matter if MSD80 or MSD81. But the newer MSD81 is way more reliable, so from your side i would go for it. It is also possible to buy full kits of DME+CAS+Keys, then you wouldnīt Need to Code. But i think this is the wrong thread for this discussion.
Ryan81789 Ryan81789 is offline
Car: 2009 BMW 335ix
Default 04-08-2019, 07:59 PM
I have some logs of my car. Not sure if Iím using the JB4 as well as I could be if anyone could look and explain it a little bit to me. Doesnít seem like the boost holds thru the rpm range
Default 04-09-2019, 09:42 AM
Best to post in the support section.
What mods do you have? You have some overboosting in the upper RPM actually.
JB4 firmware is really old, update that to the latest one and follow the directions here:
E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
Car: 2009 BMW 335ix
Talking 04-09-2019, 01:47 PM
Have a new long from tonight, car still doesnít seem like itís running right. Can anyone take a look and help me
2009 bmw 335i xdrive. Jb4, dual cone intake, sport intercooler, ******* d.p. stage 3 fuel it LPFP, VTT GC hybrid twin turbo kit, TMAP 3.5 bar
tmal's Avatar
Car: BMW E92 335i
Default 04-10-2019, 06:32 AM
I see these >
- do a better log(s), on 3th or 4th let's say from a little bit under 3k revs to redline with WOT
- your lpfp log value is 48, so problem with sensor?
- you should lover DB at range of revs as you're slightly overboost.
- set All cyl logging in setup menu
Did you follow the initial settings for hybrids? I mean FF learning should be off.
Redfred's Avatar
Redfred Redfred is offline
Car: 2008 335i auto
Default 04-18-2019, 09:19 AM
Hello first time form users here, gleaned for years in here. Can anyone please help with some map 6 tuning on hybrid turbos. Any help would be much appreciated. The the log is in 3rd gear map2. Let me know what you guys see. Forgot to mention, Jb4 and e85 backend flash installed, all other mods in signature.
2008 335i auto, mmp inlets, cldp's, 7" intercooler, charge pipe with tail bov, 3.5 bar tmap, turbo labs america hybrid turbos, stage 2 lpfp WB 450, fuel-it tbi, E85 bef, 100% e85.
Chunky Osiris's Avatar
Chunky Osiris Chunky Osiris is offline
1Lover
Car: 2008 135i MSport PPK - FBO - MHD Tune
Send a message via Skype™ to Chunky Osiris
Default 04-18-2019, 01:15 PM
Looking through the most current release of Back End Flashes, I only see E85 or greater maps for Hybrid Turbos. I'm installing Tomioka Racing 19Ts and I'd like to use a Hybrid BE flash but I don't have regular access to E85 so I use 93. Is there a hybrid flash I can use?
1Lover
Default 04-18-2019, 03:21 PM
OK, so I just read through the entire 21 pages of this thread. Looks like Pump Flash in Map 2 to start out with is the way to go. It would be good to add that information to the original post to keep others from asking.
Redfred's Avatar
Car: 2008 335i auto
Default 04-19-2019, 04:32 PM
Terry or anyone else I need a little help tuning my jb4 map 6. Can you look at my logs and give some inside as to what you see, potential problems etc.
Haynpunch's Avatar
Car: 07 E90 335i
Default 04-19-2019, 11:00 PM
In the very first post of this thread....
Basic Setup Notes: line 4 and line 7 says exactly that
07 E90 AT - xHP
FBO
Hybrids
Haynpunch's Avatar
Car: 07 E90 335i
Default 04-19-2019, 11:01 PM
Post in the support section
07 E90 AT - xHP
FBO
Hybrids
1Lover
Default 04-20-2019, 06:13 AM
Now that I look at it again, you're right. It just wasn't that clear to me when I first read it. I don't mean the Map 2 part, I was only speaking about which BE Flash to use. It doesn't specifically say even with upgraded hybrids to still just use the proper octane flash meaning there isn't one for the hybrids if you're not running E85, PI, Meth etc. This is a thread about upgraded twins though so I could have assumed I suppose but I did not. I still think that line 4 could explain that a little more clearly.
I was also not bitching about reading through the entire thread. I was merely stating that I had done so to try and be as informed as I can be on the situation rather than just rely on the group to answer my questions.
Furylibre Furylibre is offline
Car: 335XI
Default Just installed Pure Stage 2 turbos. - 05-31-2019, 01:15 PM
Hello everyone.
A little question; My Mecanic just finnished install new PS2 turbos on my car, 2008 N54 E90xi, and i already have a JB4 installed.
I want to know if i can travel 30 miles slowly to get home without installing the BEF without dammaging the engine. I do not have the room there to install the power supply and i want to do the flashing at home without a hurry. I planned to use MAP 5 while riding home.
Once home, i'll do the BEF, and Set MAP 6 as the settings in the first page of this trhead. Will it be ok ?
Wrecker 426's Avatar
Wrecker 426 Wrecker 426 is offline
Car: 335xi
Default 05-31-2019, 03:06 PM
Just leave it on map 4 if your really worried, I wouldn’t worry about map, it’s not going to target anything your turbos can’t handle I didn’t tuna BEF for a while
07' 335xi, VTT Stage 2, Meth CM10, Stage 2 LPFP pri, walbro 525 LPFP 2nd, JB4 E85 BEF, VRSF exhaust, Phoenix Race IC, MMP AL inlets, VTT AL Outlet, PR Coils, Fuel-IT CPI 950cc, Manual swapped, SMF Spec Twin disk
Car: 335XI
Default 06-03-2019, 10:45 AM
Thank you for the advice.
My main concern is about fuel/air and others parameters other than boost.
Car: 2009 BMW 335ix
Default Jb4 tuning help - 06-12-2019, 07:32 PM
I recently had an mhd e85 hybrid turbo bef put on my car. Looking for some help on adjusting the jb4 to help getting it running how it should. Took a map 2 log from 2k-7k rpm. If anyone can help
Default 06-28-2019, 10:37 AM
Sorry missed the post. Log doesn't have default duty bias and options setting in the first post.
What turbos?
silverbimmer335 silverbimmer335 is offline
Car: e92 BMW 335i 2007
Default 07-06-2019, 07:11 AM
Hi Terry,
Hope this message finds you well.
I would like to do the backend flash mod on my car
My car is: 2007 BMW 335i e92
Mods: Pure turbo stage 2 hiflow, inlet relocated 2", outlet, FBO, 3.5bar, lpfp stage 2 (DW400 stage 2+), dual oil cooler, JB4 g5, MHD. Flywheel single mass, clutch stage 3+
FUEL: daily 94 + meth / RACE EVENT: 104 + meth
My meth kit is the AEM with 5 gallons tank (new just install) (50/50)
After the backend flash will be installed, which map do you recommend to use on the JB4 and what are the setup on jb4 I have to put to use the meth
Thank you a lot
Max
Default 07-08-2019, 10:41 AM
I'd start with RACE and evaluate it. Main thing is the JB4 side settings so boost control is correct. Those are in the first post.
Jscottrad Jscottrad is offline
Jscottrad
Default Tuning in new MMP Stage 3's - 07-18-2019, 08:44 AM
Hi, any help would be appreciated, just finished installing MMP stage 3 turbos.
Haynpunch's Avatar
Car: 07 E90 335i
Default 07-19-2019, 04:46 PM
List all your mods
Looks like your lpfp is struggling
07 E90 AT - xHP
FBO
Hybrids
