Six Pot's Avatar
Six Pot Six Pot is offline
Default 1M Big Single 6300-7000 Distruption - 03-04-2019, 10:52 AM
Afternoon Everyone,
I am trying to fine tune my setup but I am noticing hesitation in the 6300-7000rpm top end band. I have attached some 3/4 gear pull logs, nothing is really popping out at me. I notice a couple times where Afr1 hops up but afr2 stays within range. No Codes are being thrown, nor is the Map stepping down.
Anyone want to put a second set of eyes on this :-)
Mods:
ViE GTW3884 67mm w/ 1.0 ar Hotside
DOC Intake Mani with PI (100% E85)
PR Stage 3+ with FPR Return
BPM4 Fuel Module
PR Coils
NGK 2-Steps, ~ 3k on them before single
JB5 ISO + MHD Backend + PI Controller + 3.5 bar (Set on Map 3)
Much appreciated in advance!
2011 BMW VO 1M
ViE 3884 GTW 67mm 1.0AR Hot Side T51r Mod | PR Coil Packs
JB4 ISO | MHD | PR Stage 4 Elite | DOC Intake Manifold + TiAL + Pi
Seibon Dome Hood | Spec Twin Disk | PSP 900 IC | Slek Front Lip / Diffuser
Apex EC7 Wheels | KW HAS | N55 Mid + Y Pipe | P3 | ADe Catch Can
Six Pot's Avatar
Default 03-04-2019, 11:00 AM
Just noticed my Trims are stuck at 25... wonder if my O2s are bad :-/
2011 BMW VO 1M
Default 03-04-2019, 11:13 AM
Originally Posted by Six Pot
Afternoon Everyone,
Mods:
BPM4 Fuel Module
PR Coils
Hey can you describe “hesitation” a bit? I generally associate hesitation with the car wanting to misfire.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Six Pot's Avatar
Default 03-04-2019, 11:16 AM
Feels like its stumbling/struggling 6300 and above, its not as bad as a misfire but I guess it could be. I thought about swapping plugs first but then noticed the trims being stuck.
2011 BMW VO 1M
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 03-04-2019, 12:50 PM
Not a PI expert, but is LPFP reported the same with that kind of setup? Because it got right down to 50 right before your trims/AFR went out of whack each time. I'd be surprised if you had a LPFP issue with that setup but maybe there is problem somewhere.
Six Pot's Avatar
Default 03-04-2019, 02:03 PM
Well the FPR is vacuum referenced as well so that could skew that number. Still wouldn’t explain the trim being stuck as 25 across the board
2011 BMW VO 1M
chadillac2000's Avatar
Car: 2008 535i
Default 03-04-2019, 02:30 PM
Trims stuck at 25 are usually indicative of o2 sensor failure. It also means you're in open loop fueling, which is not good for any type of WOT situation as your ECU isn't taking into account the o2 readings. Surprised you aren't getting codes though. Does fueling enter back into closed loop and get unstuck when you come off WOT? How many miles and what brand are the o2 sensors you have currently installed?
Six Pot's Avatar
Default 03-04-2019, 03:09 PM
Has 45k miles, I am assuming they are the OEM O2s as the previous owner doesn't have any documentation around changing them nor have I. based on the logs it looks happy until the hiccups then sticks @ 25 (Open) according to the logs. * slight clarification, all logs were done in within minutes of each other and the car was never turned off so it looks like the Trims are going back to normal after a few seconds off throttle. My current assumptions are:
- Plugs , doesn't seem likely
- O2 sensors, replace all 4 with NTK?
- Exhaust leak perhaps
2011 BMW VO 1M
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 03-07-2019, 10:25 AM
If you have OEM o2 sensors they are really trash in single turbo applications. They don’t switch fast enough, die too easily and I actually don’t think they are accurate from my testing vs NTK
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 03-07-2019, 11:04 AM
Are both your rear O2s active ?
NTK or ADV I suppose if you can get those - seem hit or miss (I didn’t have much issues with mine)
e92 AT 335xi 2.0
Doc Race Kit 6062
