(#676)
Default 01-22-2019, 05:41 PM
Originally Posted by Spencer1990
Terry does the pedal box work with c43/glc 43 and if so is it worth it for them? Thanks
Tested and it works!
DubVBenz DubVBenz is offline
Car: W212 M276 DELA 30 ; W211 OM642
Default 01-23-2019, 09:30 AM
Hi Terry - Getting ready to pull the trigger for my W212 E400 M276 3.0 BiTurbo. Can you confirm that the only two components I need are (from this page 2015+ W205 Mercedes C-Class Stage 1/JB4 tuner | BurgerTuning.com )
- JB4: $579
- JB4 Wireless Mobile Smart Phone Kit : $140
Also, any sort of bundle pricing available? Looking forward to testing this baby out!
Default 01-23-2019, 12:40 PM
Yes, that's it
Prices are per the site. You'll also have to buy the app for $29.
Default 01-23-2019, 12:43 PM
A part time employee here Russ drives a C43, grabbed a photo of the fuel pressure connector for those wondering where it attaches to.
Spencer1990 Spencer1990 is offline
Car: Mercedes
Default 02-06-2019, 08:32 PM
Hi Terry
Can you please send me the install instructions for pedal box. Thanks
Waisoserious Waisoserious is offline
Car: GLC43 Coupe
Default 02-07-2019, 09:37 AM
Is the JB4 upgrade unit completely compatible with the JB1 Beta? I have the JB1 Beta with the JB4 Bluetooth module addon.
Can I still upgrade using the $100.00 JB4 upgrade kit?
Default 02-07-2019, 10:07 AM
Yes!
Default 02-07-2019, 10:08 AM
Hi Terry
I don't believe we made a C43 specific video yet, Payam can later. But it goes in like the BMW pedal tuner video on the pedal tuner page. Pull back gas pedal, plug in, calibrate, enjoy!
Car: Mercedes
Default 02-07-2019, 07:14 PM
Thanks one quick question do you know if I still need to move the pin for green connector if I have the latest harness without the purple connector. Thanks
HTXgearhead HTXgearhead is offline
Car: Mercedes C43
Default 02-08-2019, 01:30 PM
Hi Terry,
As we move in to the spring season, what would you consider a “safe” IAT while running map 7 on E30? I regularly see IAT in the 120-130F range while driving in traffic.
Also, with the green plug installed, can I run more than E30 safely?
Thanks.
Default 02-08-2019, 01:43 PM
We'll have to keep an eye on and evaluate it as things heat up, it's not so much about what IAT is but rather how timing per octane looks as IAT increases. Advance is mapped on IAT within the ECU and timing will be reduced as it goes up but we'll want to make sure it's pulling enough to avoid unsafe conditions at very high power levels. Overall based on previous warm weather testing I don't foresee any issues during summer months.
Car: Mercedes
Default 02-08-2019, 01:48 PM
Hey Terry can you please answer my previous question about the green plug because I need to know ASAP. Thanks sorry about being pushy.
Car: Mercedes
Default 02-17-2019, 12:41 AM
Hey Terry is map 7 ok for 98-100 octane. Thanks
Default 02-17-2019, 03:04 PM
Best to check the harness and see if the pin is in the right spot or not.
Default 02-17-2019, 03:05 PM
Any tuning advice should be based off logs of your car/fuel. But if you're using unleaded race gas I presume it would be OK at least to evaluate.
Car: Mercedes
Default 02-17-2019, 07:40 PM
Hey Terry if my trims are maxing how much is this affecting performance. Thanks
Default 02-18-2019, 09:31 AM
Sometimes maxed out trims increases performance, with a leaner air/fuel ratio. It all depends on the details.
justint5387 justint5387 is offline
Car: ML400
Default 02-26-2019, 11:37 AM
Would this work on a ML400 or GLE400? I believe it shares the same engine
Default 02-27-2019, 10:39 AM
As far as I know yes it's compatible. But if you want to send photos of the TMAP and MAP sensors we can confirm the electronics are the same.
niktelk niktelk is offline
Car: C43 AMG
Default 03-08-2019, 01:51 AM
Just bought a JB4 for my C43. Do I need to upgrade the firmware to C_3?
Default 03-08-2019, 09:57 AM
I'm not sure what we're shipping with these days, can't hurt to update it.
Car: Mercedes
Default 03-08-2019, 03:25 PM
Any new firmware/etc coming out soon need more power lol.
dnguyenc400 dnguyenc400 is offline
Car: Mercedes C400
Default 03-12-2019, 03:12 PM
Hey Terry,
Running E30 on Map 7, does my log look like it's doing okay?
Should I run the green plug?
Default 03-12-2019, 03:49 PM
What we're working on next is some form of map switching capability in dash.
Originally Posted by dnguyenc400
Hey Terry,
Trims are maxed out, set open loop to 40, attach green connection, and run the same log.
