MRC-5.56's Avatar
MRC-5.56 MRC-5.56 is offline
Car: future 335i
Default Hybrid turbo 335i - first logs with port injection and e50 fuel - 02-16-2019, 05:12 PM
Hey all,
I finally was able to load the bms e85_hybrid_pi back end flash and filled up the tank with an e50 mix. Last weekend i fitted a port injection kit with the bms pi controller.*
Any way i did a few logs in map #2 today. The car felt like it pulled pretty strong but coming into boost there was a hesitation before taking off. I have the PI settings to what the pi thread says to do but i think it may be spraying to much as the trims are at 0. Any advice would be highly appreciated.*
Logs are attached*
Car is a mmp stage 3 e92 with stage 2 pump for now.*
Thank you
Default 02-16-2019, 09:01 PM
Originally Posted by MRC-5.56
Hey all,
Logs are attached*
Thank you
Letís drop your FB settings down to 40 & see what the trims look like
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
