(#1651)
Default 02-12-2019, 03:54 PM
Originally Posted by KLR STINGER
Depending on Spring used that is normal. In fact some spring combinations open at idle is even normal. I like to run the minimal amount of spring pressure to ensure valve is just barely closed at idle. Once under boost the pressure behind the diaphram keeps closed shut, but a lighter spring rate will allow for faster response.
The computer retains control and will let it stay open sometimes, probably some sort of emissions things. You can go a really large spring to block it but the valve doesn't work properly then, and you also take away the ECU's ability to control it when it wants.
Eronenris Eronenris is offline
Car: Kia Stinger GT2
Default 02-12-2019, 04:12 PM
When I try and upload the firmware for my jb4 I keep getting an error.
it says.
failed checksum testing file 21210
read 5051350
Default 02-12-2019, 04:33 PM
Did it start the upgrade process? If so may need to hold phone closer to JB4 mobile device, ensure ign is fully on, etc, to get it to update.
Default 02-12-2019, 04:40 PM
Firmware v7 worked. But 8 wonít.
Do I have to do anything at this point to make the fuel wires work. Is there anywhere I can check to make sure I have everything working properly?
Like I was not sure how to install that obd2 wire. No directional clip or anything. I just made sure 2 out of the 3 wires had contacts.
stingerGT stingerGT is offline
Car: 2018 Stinger GT2
Default 02-12-2019, 05:16 PM
If you don't have the obd2 wire connected, the fuel control does not work.
Default 02-12-2019, 05:26 PM
OBDII should only lock in one way, post a photo if you need us to check it. Fuel wire install video is in the first post.
Default 02-12-2019, 05:41 PM
I watched the video and did it how it said, I am just very particular and like confirmation that things are what they are supposed to be. Would a log show it working or not?
Iím just confused because I see this list on your original post.
bit0 - Turn on to disable JB4 fuel control, also required for accurate AFR logging if fuel wires are NOT installed
bit1 - Turn on to enable fuel control adjustment by RPM, default values of 80 across will match internal mapping. With default setting JB4 uses internal settings for fuel control.
bit2 - Turn on to disable JB4 hot/cold water & oil temperature protection
bit3 - Turn on enable IAT/timing spoofing, requires wire added to JB4 harness and 6cyl setting for spoofing level
bit4 - Unassigned
bit5 - Unassigned
bit6 - Turn on if vehicle has an aftermarket flash map loaded to the ECU
bit7 - Unassigned
How do I get to this screen to turn these on or off?
Also what is this, it smells slightly like gas right here. It may be just in my head, but I smell gas now when driving and I never did before.
Wonít let me post pic from phone, Iíll add it later.
Default 02-12-2019, 07:29 PM
If you read the individual FutureUseD settings, you'll find that none of those settings apply to you. You don't need to enable any of them or touch any other setting when installing the fuel control wires. A full throttle JB4 log would show it's working right, yes.
I can't see what you're smelling, sorry, but the tuning can't make any new odors.
Default 02-12-2019, 07:50 PM
If you read the individual FutureUseD settings, you'll find that none of those settings apply to you. You don't enable any of them per the directions.
Would any of the lines I took off of the manifold smell like gas if not put on properly? I checked all the lines, and it looks fine.
Here is a 3rd gear pull log, how does it look.
Last question, when changing maps does it change instantly, or does it take time to learn?
Default 02-12-2019, 07:52 PM
There is no log attached.
Maps change instantly, a little adaption period is required for full power though.
Default 02-12-2019, 07:54 PM
It's there now.
Default 02-12-2019, 10:05 PM
Really short run but seems OK to me.
Default 02-12-2019, 11:05 PM
It was 3rd gear from 2k rpm.
I can do a longer log if needed.
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 02-13-2019, 08:10 AM
Hey @Terry, question for you. I'm running the "valet" map because of our crappy weather up here. I'm going into no boost / limp mode and got a P0200 CEL yesterday. I managed to catch it in a log this morning. In fact, I think I can duplicate it. The car will run in any other map fine. The ignition timing jumps up really high after the boost cuts out. I am running 93 octane. The system resets when I restart the car. I did have to manually clear the DTC.
Let me know what you'd like me to do next.
-MurlinatoR
Connoisseur of all things Kia
Default 02-13-2019, 10:37 AM
Code comes up only on VALET? Could be a bug, I haven't run that map full time much yet. Will see if I can recreate and update in the next firmware version.
MurlinatoR's Avatar
Kia Efficinato
Default 02-13-2019, 10:51 AM
Yes Sir. Been flawless until yesterday when I ran it in map 4 because of the ice. The first time it went limp *insert funny joke here* without a DTC. I pulled over and restarted and all good. I tried a few other maps, including 0, and all good. Put it back in 4 and it threw the code and went limp again. Cleared the code and left it in 0 until this morning.
Put it in 4 and hit the throttle. After the shift into 2nd, it failed again.
-MurlinatoR
MurlinatoR's Avatar
Kia Efficinato
Default 02-13-2019, 03:04 PM
And what do you see with the logs? Anything obvious?
-MurlinatoR
Default 02-13-2019, 06:56 PM
Does anyone else feel like the car is faster in normal mode, vs sport mode. Mine feels much harder pulling from a stop than sport mode does.
MurlinatoR's Avatar
Kia Efficinato
Default 02-13-2019, 07:08 PM
What mode is "normal"? LOL
-MurlinatoR
Default 02-13-2019, 07:22 PM
Comfort, sorry.
Default 02-13-2019, 07:51 PM
I haven't looked in to your VALET code yet, when I get a chance I'll let you know what I find.
MurlinatoR's Avatar
Kia Efficinato
Default 02-13-2019, 10:04 PM
Comfort, sorry.
What map do you have your JB4 on? You have summer or all season tires?
-MurlinatoR
Default 02-13-2019, 10:47 PM
Map2, awd, factory tires.
Scorped Scorped is offline
Car: Stinger GT2
Default 02-14-2019, 12:10 AM
Terry and/or other experts, I finally got around to logging a few runs; how am I looking so far?
Thanks in advance.....
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 02-14-2019, 05:43 AM
Pretty dang good!
