5alive 5alive is offline
Car: JB535
Default BavAuto HiPo Coils - Any Experience?!? - 02-06-2019, 02:51 AM
Been looking at these for awhile. No issues with my current coils so I haven't pushed the envelope.
Anyone have these installed and have feedback, +/-?
2008 535i | 6MT | Evo CP (stock DV)| jB4 (duh) | BMS BEF (PumpUSA) | BMS DCI | 93 (via 91 + Octane booster) | E85 ~35% | MFactory SMF | Spec Stage 2+ Clutch | UUC STS | 7" Street FMIC | Toggle Switch Gas Pedal delete
157k - Maintenance (HPFP, LPFP sensor, Fuel sending unit, CPK sensor, Injectors (12), Plugs 97506 (.020), Delphi Coils, AGM Battery, starter, Koni FSD @ corners...)
dmckmc dmckmc is offline
Car: E60 535i
Default 02-06-2019, 06:03 PM
I've got them on my 535i, 2008, mods below. I've had them around 15,000 miles, no issues at all. I can't say whether they are better than the OEM Bosch they replaced. The Bosch were all original except one and I was dealing with misfires once I started modding. Now, no misfires and the car runs great. I think it would be difficult to discern exactly how the BAV Auto perform without some monitoring software way more sophisticated than I own. Personally I would probably save the money next time as I believe there are bigger bangs for your money such as: tuning software/hardware, e85 and related fueling upgrades, colder plugs, etc...It may be worth it If you've maxed out your performance and are looking for a bit more. But then you likely would be at the point of buying one of the racing coil sets commonly discussed on these and other forums.
N54
FBO
JB4
BEF-E85
E40
PCV-EXT
XHP
Dave @ BMS/Fuel-It! Dave @ BMS/Fuel-It! is online now
Default 02-07-2019, 01:51 PM
I’ve been running Eldor with no issues what so ever + with the FCp warranty what’s not to like
tisdrew tisdrew is offline
Car: 2009 e90 335i 6MT
Default 02-07-2019, 02:14 PM
It looks like they took an eldor coil and painted the clip red...
I personally went with Delphi coils as these are used on the newer motors (n55/s55/n63/n20)
Car: JB535
Default 04-02-2019, 02:04 AM
Thanks.
Car: JB535
Default 04-02-2019, 02:05 AM
Appreciate your feedback.
