(#26)
Deen@StreetKingImports's Avatar
Deen@StreetKingImports Deen@StreetKingImports is offline
Car: 2013 Genesis Coupe
Default 12-13-2018, 01:38 PM
Originally Posted by Six Pot
Ill need to take a pic, WG clocking + Front Screamer clocking just doesn't clear the manifold.
Feel free to pm me all pics and information, maybe I can try to help out
codesx codesx is offline
Default 12-14-2018, 10:54 AM
If/when either of you have before and after dyno numbers, put 'em up!
The pictures are nice, but we all want the delta!
2008 335i Convertible, E93, N54, A/T
JB4 Map 1, PUMP BEF, 94 Octane (15 PSI)
xHP Stage 3 (v2.0)
Ultimate Racing CAI (selling)
VRSF CP
HKS BOV
NGK 5992 Plugs @ .020
Parts I have/ordered and am now working to install:
BMS WMI
BMS FMIC
BMS OCC
BMS DCI
RB PCV Valve
Maintenance:
2018 - Plugs, Ign Coils, Walnut Blasting
2019 - Valve Cover Gasket & OFHG (pending)
bigdaddyaaron's Avatar
bigdaddyaaron bigdaddyaaron is offline
Default 12-16-2018, 09:06 PM
When it was overclocked we had a straight down 10AN to 10AN to the block utilizing a Vader-like block converter. Post reclock @ 12 we no longer can route against the block so we literally have to go down then curve threw the manifold to get to the drain which now creates the issue at hand. So the only option we can think of is a metal line to mitigate it.
Just use DEI(or equivalent) firesleeve. I've had silicon drain line touching(forcefully lol) my bare manifold for just over 2 years and no drama. skip the gold tape bull**** and use something with actual insulation.
Six Pot's Avatar
Six Pot Six Pot is offline
Default 12-16-2018, 09:36 PM
Tried Firesleeve , already melted a line and the manifold is cermanic coated. We now have Hi temp blue line + a dei wrap + firesleeve, it still don’t trust it for longevity.
2011 BMW VO 1M
ViE 3884 GTW 67mm 1.0AR Hot Side T51r Mod | PR Coil Packs
JB4 ISO | MHD | PR Stage 4 Elite | DOC Intake Manifold + TiAL + Pi
Seibon Dome Hood | Spec Twin Disk | PSP 900 IC | Slek Front Lip / Diffuser
Apex EC7 Wheels | KW HAS | N55 Mid + Y Pipe | P3 | ADe Catch Can
Default 12-16-2018, 10:21 PM
Wow that's strange. I have hi-temp blue + firesleeve as well. The addition of that wrap should make the line damn near cold lol.
Also, if you have tape on the underside of your hood that could be contributing as well. That radiant heat needs to escape somewhere so that youre not cooking the ambient air on that side of the bay. You already have a bunch of tape reflecting radient heat right back towards the turbo/manifold.
Also, I noticed that exhaust scavenge you have setup: have you done any testing on that? The bung is angled directly in the path of the exhaust flow- especially being at the high pressure/low speed bend like that. Could be fine, but just wondering
Six Pot's Avatar
Default 12-17-2018, 10:58 AM
The hood is CF with M3 vents , no shielding so heat extraction should be just fine.
In regards to the scavenger it hasent been on the road enough yet to tell but the configuration is accurate in order to create pressure needed. The only other method would be to VTA or do a custom air filter but both have their own drawbacks
2011 BMW VO 1M
SlimE92 SlimE92 is offline
Car: E92 N54
Default 01-15-2019, 08:23 AM
Updates?
suspenceful's Avatar
Car: 2008 BSM 135i
Default 01-15-2019, 09:00 AM
Originally Posted by SlimE92
Updates?
What kind of updates are you looking for? Car has been hibernating in the garage all winter.
2008 BMW 135i 6MT - Doc Race Single Turbo 6266
752whp/691wtq @ 30psi, weighs 3260lbs
Complete build info: my1series.com
YouTube channel: youtube.com/jakespence135
Instagram updates: instagram.com/jakespence
N54 t-shirts, etc: bimmerstreet.com
Car: E92 N54
Default 01-15-2019, 10:13 AM
Dyno updates. But that’s right I did read before where you said you’ll bring it back out during spring my bad.
