(#201)
hornady hornady is offline
Car: m240i X-drive
Default 01-14-2019, 07:45 AM
Terry, I am having a hard time figuring out why I can't hit near boost targets. Everything but boost on the logs looks good.
Running M240i Xdrive with JB4, WMI 50/50 mix, EWG wire, no FF wire, 93 Octane Shell fuel. Only WMI settings I changed was 3000RPM-7000RPM instead of the standard selection and I have FutureUseA set to 30 with EWG harness installed.
5th Gear log attached.
Any thoughts?
Default 01-14-2019, 10:11 AM
Any thoughts?
Set FF to 30 and get another log. You might want to lower FUA to 10 as well for now.
What meth nozzle are you using btw, your fuel trims are maxed.
dRDiesel's Avatar
dRDiesel dRDiesel is online now
Car: BMW
Default 01-14-2019, 10:19 AM
Any thoughts?
Your FOL is on 0 try it on 60 and lower FUA to 10.
| 2013 BMW 335is |
| MHD Custom E60 | Stock Turbos| 2" Inlets | down-pip3s | DCI | PR coils | BMP Stage 2 fuel pump |
Car: m240i X-drive
Thanks for the quick reply.
I'm using dual CM7 nozzles.
Will try another log tonight with FF @ 30. Then a second with FF@30 and FUA@10.
Car: m240i X-drive
Default 01-14-2019, 10:28 AM
Thanks, so I should try modifying all three of these settings together then, correct?
FF@30 -- FUA@10 -- FOL@60
dRDiesel's Avatar
Car: BMW
Default 01-14-2019, 10:32 AM
Yeah i don't know why your FOL is on 0 unless not having the fuel wires keeps it at 0.
| 2013 BMW 335is |
Car: m240i X-drive
Default 01-14-2019, 10:49 AM
I was always told (initially at least) and still read Flex Fuel wires aren’t required and don’t really help with the B58. Is this still a true statement, or is it worth it for me to get them hooked up?
Default 01-14-2019, 11:03 AM
FOL at 0 or 60 makes no difference without the fuel wires.
dRDiesel's Avatar
Car: BMW
Default 01-14-2019, 11:07 AM
What i assumed a few posts above. His fuel trims are still maxed with meth injecting so the fuel wires should help his situation.
| 2013 BMW 335is |
Default 01-14-2019, 11:14 AM
Something is definitely up IMO. Two CM7 should be plenty of additional fuel.
dRDiesel's Avatar
Car: BMW
Default 01-14-2019, 11:17 AM
Yeah we need to send MHD a 24 pack of red bull to finish up that back end flash
| 2013 BMW 335is |
Car: m240i X-drive
Default 01-14-2019, 11:48 AM
I only have three plugs in my engine bay from the JB4, so I'm assuming FF wires did not come with it when I bought it new from BMS and need to be ordered separately.
If it is not a FF wire issue, could it be clogged nozzles or clogged filter in the solenoid?
A log from the same car, with the same setup about 1.5 years ago is attached to this post too. (June 2017). Trims look better to me in this log. Was a different firmware too though.
This is the post from Terry I was referring to about the FF wires on B58.
Car: m240i X-drive
Default 01-14-2019, 03:13 PM
Tried to run another log on my way home from work (best I could).
Boost and power feels much better changing the FuD and FF settings like recommended above. Boost and power look and feel good, but Trim sits right at 49 the whole time and AFR right AT 15.
I noticed my "N20 TMAP (0/1)" setting is set to 1, don't know if that matters.
My question at this point is...if I'm happy with the power and feel of the car but trim is absolutely maxxed out according to the logs, is this something I should be worried about and try to fix? Will it hurt the engine or car running lean like this?
Turboh's Avatar
Turboh Turboh is offline
Car: 2017 BMW 340iX
Default 01-14-2019, 03:59 PM
Your timing looks fine, under load. It is zero when throttle closes. Seems right to me. What I do not see is a drop in IAT when you accelerate. I wonder if you are spraying anything?
2020 330iX auto sport w/M track handling, JB4 ; 93 octane; Honda S2000; Ninja Z1000.
Car: m240i X-drive
Default 01-14-2019, 04:13 PM
Wouldn’t it not show on the log as IAT is measured at the intake and the meth is spraying right at the throttle body?
Default 01-14-2019, 04:36 PM
This is about how they run. No changes needed.
Car: m240i X-drive
Default 01-14-2019, 04:47 PM
Thank you Terry!!
Turboh's Avatar
Car: 2017 BMW 340iX
Default 01-14-2019, 08:23 PM
You are right about that. Wish it weren’t though.
Alex
imsorussian imsorussian is offline
Car: 2017 BMW 340i Xdrive
Default 01-15-2019, 03:45 AM
Setting meth safety to 3 will disable it completely?
Default 01-15-2019, 09:42 AM
Meth trigger to 3 with disable.
dRDiesel's Avatar
Car: BMW
Default 01-23-2019, 11:36 AM
Called for a dyno today, but they were fully booked. Was hoping we can see 450/450 with 100% meth + 4 gallons of E85.
| 2013 BMW 335is |
Hornet34 Hornet34 is offline
Car: M140
Default 03-04-2019, 06:32 PM
Had a chance to strap down our 2016 340i today for an hour of dyno tuning. Having done lots of runway testing last weekend at Shift Sector, including taking down a stock tune M4, I had a feeling the car was going to perform pretty well on the dyno. And was not disappointed.
The current setup is 100% stock except for a B58 JB4 BETA, BMS intake, and a BMS B58 water/meth kit. Exhaust is fully stock. Fuel was ~93 octane and meth mixture ~80%.
The BMS B58 water/meth kit has some additional parts not included in our normal kits including a PNP nozzle adapter, an EWG connector for the JB4, and some additional fittings.
With the EWG connector in place we're able to control as much boost as the turbo wants to make. But we've found power peaks out ~21psi, despite the turbo willingly making much more boost. Runs from 22-24psi at the same timing values all resulted in the same or less power. So we're probably approaching the stock turbo limits now. Maybe another 15-20whp ultimately in there with exhaust and other work.
Most impressive is how well it holds power to redline especially relative to previous turbo BMW motors like the N54 & notoriously weak top end N55. I'm pretty excited about this new motor.
Do you have a log in csv
