(#151)
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 09-19-2018, 11:03 AM
Originally Posted by Fmonteiro444
Something weird happened today. I was at about 75mph cruising in 5th, manual mode. I gave it a little more than half throttle to pass someone and when I let off the gas it jerked pretty aggressively. Got a Drivetrain Malfunction for "1F0526 DME internal error: monitoring torque comparison" and hitting the gas did nothing. Tried to clear codes while driving but couldn't. Checked what map I was in and the JB4 said "invalid nap selection" and it magically ended up on Map 1. But when I checked the logs while this was happening it says I was still in Map 6. I had to pull over, restart the car, clear the codes, and switch back to Map 6.
Anyone got any thoughts on this?
This happened to me again twice today during my commute. This time I'm on EWG_15_T5B firmware. The worst part is it disconnects my tablet from the JB4 and I was not able to reconnect.
Terry any help with this?
Default 09-19-2018, 11:19 AM
Not had any reports of it, but I think it's a flash issue. Are you using our off the shelf BEF map or did you modify it?
Car: 09 E92 SG
Default 09-19-2018, 11:24 AM
Using a modified version of your BEF. I can send it to you. But all I've changed is fuel, timing, and fuel scalar.
Default 09-19-2018, 12:57 PM
I had this same thing happen to me feels like you hit a wall really scary. It was the fuel scalars on a modified flash ****ed up something about the fuel mass vs load that the dme didn’t like. I would leave scalars alone use the jb4 e85 or pump scalars
Car: 09 E92 SG
Default 09-19-2018, 01:36 PM
Seriously? So you can't tune the fuel scalars? How did you figure that out?
Default 09-19-2018, 05:36 PM
You can hange them but if you go to far you get these hard core shutdowns. When I changed back to bms bef it was normal again
Car: 09 E92 SG
Default 09-20-2018, 02:20 PM
That doesn’t explain the JB4 switching to an invalid map.
Default 09-20-2018, 07:07 PM
No it doesn’t I just wanted to share when this happened to me and the cause. It was scary, repeatable and very little online for help
Car: 09 E92 SG
Default 09-21-2018, 09:52 AM
So I think I finally got spool up to the perfect spot. I used some WGDC tables from Jeff and now I'm seeing 19.6psi br 3500rpm and 22.4psi by 3725rpm. Prior to this I was lucky to see 20psi by 4000-4100rpm. That's a hell of an improvement. Next step is to dial in the over boosting that's happening. I am so glad I went with the 8374.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 09-21-2018, 09:58 AM
Is AFR reading correctly?
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Car: 09 E92 SG
Default 09-21-2018, 10:44 AM
Yes, I need to lower the port injection duty cycle. It's entirely too rich.
Car: 2011 N55 135DCT
Default 09-21-2018, 11:19 AM
Looking good.
135idct 135idct is offline
Default 09-21-2018, 03:59 PM
looks good, but u should see a good tuner to fully tune ur setup not just modefy few tables, also it will spool faster.
any vbox test 100-200km, 60-130mph?
Car: 09 E92 SG
Default 09-22-2018, 08:32 AM
I donít want it to spool faster. Almost 20psi by 3500 is plenty fast. Iím still having throttle closures in 5th so no crazy pulls.
Default 09-22-2018, 08:51 AM
Did you change scalars? What changed helped he shut down?
Car: 09 E92 SG
Default 09-22-2018, 09:56 AM
I did. I also lowered load back to 160 in the BEF and used the correct XDF. I think I was using a different one than the one BMS supplied.
Default 09-22-2018, 11:22 AM
Both could have effected it. If your using Jeff’s flash it has a ramped load ceiling curve. There’s some benefit to running the bms load ceilings if using jb4. Idk wtf the scalars did that to my car because trim and hpfp was fine there something in the dme that flips out. I’ve been good just running the standard bms bef but I understand about spoiling. Mine spools faster than yours being 7670 but I don’t want lightning spool either. looking very impressive I hope you make me regret not getting the 8k series
Car: 09 E92 SG
Default 09-25-2018, 10:16 AM
This freaking car moves! It feels like a complete beast at 25psi. The only issue I'm running into now is I'm having a major throttle closure in 5th. The car hesitates dramatically at any psi at WOT shifting into 5th. Could it be a torque limiter?
First log is 23psi and second one is 25psi. You can see the 5th gear throttle closure in both logs.
Car: 2011 e92 335i
Default 09-25-2018, 10:58 AM
You should be able to pick up a little more power if you lean it out a little bit more. Looks good though. Congrats!
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Default 09-25-2018, 12:46 PM
Set open loop to 0. I wonder if you are hitting a limiter of some sort in 5th only. Other than that it looks really good.
Car: 09 E92 SG
Default 09-25-2018, 12:51 PM
Set FOL to zero? What will that do?
It definitely feels like a limiter.
Default 09-25-2018, 01:42 PM
Your fuel trims are negative you are getting too much fuel. Lowering the FOL will help trims. If that doesn't help much you will have to lower your fuel bias.
Car: 09 E92 SG
Default 09-25-2018, 01:46 PM
I'm still getting an initial trim spike on spool up. I was planning on lowering the PI fuel bias by 10 and going from there. But if you think I should drop FOL to zero I'll try that.
Default 09-26-2018, 06:12 AM
Have you modified your load ceiling? I see you are lower than typical BEF? Can you send me your bin please?
Car: 09 E92 SG
Default 09-26-2018, 12:37 PM
The load target in the BMS BEF is 160 across the board.
