(#26)
Default 09-14-2018, 12:20 PM
Originally Posted by DSCOFF
So in theory, even at E70, map 6 25psi I should be making more power with the new leaner afr targets?
With leaner afr can I stay with e70 or I need to inc to e85 if boost is at 25psi? Not quite clear on the logic on having leaner afrs except that it means u can run 100% e85 without affecting the fuel pump.
Not just leaner AFR targets, but a lot more ignition advance. So you should be making more power with the new E85_IGN boost for boost. On E70 (rather than straight E85) map5 at 24psi peak may be a better option but we'll just have to see the data to know for sure.
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 09-14-2018, 12:31 PM
Guess Ill find out soon enough. 😀 Keep up the great work Terry!
Default 09-14-2018, 12:58 PM
Added TEST11 firmware to S55 JB4 thread with revised target blending. Was much better in my testing on Sport+. Load and let me know what you think!
TideMD's Avatar
TideMD TideMD is offline
Car: 2016 M4
Default 09-14-2018, 02:14 PM
Will get this uploaded in the next few minutes and have some feedback later today. Road around a good bit today with the TEST10 and v13 RACE BEF, driving in a little bit in Comfort, Sport, Sport+, as well as running straight 93 pump gas and E35 mix, in various degrees of traffic and open highway runs.
I will say that Sport+ is a crap shoot right now.
Sometimes the takeoff is smooth from a stand still, other times is jumpy like the car used to be before the GTS DCT flash.
Same goes with flooring it from a gentle rolling start.
2016 F82 M4 / Sakhir Orange / Black extended leather / Opti-Coat Pro
NGK 1-step colder, 0.020" / BMC drop-in, carbon delete / Injen intake & CPs / AR Design catt'd down / AA mid
LCI rear light retrofit / AutoTecknic front splitters / Mode Carbon High Kick rear spoiler / 3D Design rear diffuser
Michelin Pilot Sport 4S 265/285 35-19 / BMS ceramic black exhaust tips / Macht Schnell spacers - 15mm(f), 12mm(r)
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-15-2018, 06:50 AM
Terry,
I noticed after Ive uploaded test 11 firmware, the jb4 still labels as 1.8.4//5? Should it be 1.8.4//11?
Default 09-15-2018, 07:45 AM
No, //5 is the board type. TEST versions aren't labeled internally in the firmware.
TideMD's Avatar
Car: 2016 M4
Default 09-15-2018, 10:17 AM
Huge improvement with TEST11. Many thanks for the quick update push!
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-16-2018, 12:38 AM
Hi Terry. Yup no doubt about it v13 ign on even E70 Map 6 25psi is quicker than v11d 😀. And so smooth too.
Timing is also more consistent. Before one or two cylinders would be slower to keep up with timing. Im still using oem plugs but will soon swap them for the 97506 NGK ones.
Didnt have the road to fully log but did one squirt in 4th. Seems ok?
Default 09-16-2018, 08:32 AM
Seems OK, rev it out more next time so I can verify timing comes up as it should.
TideMD's Avatar
Car: 2016 M4
Default 09-16-2018, 05:13 PM
Ran a few more logs under various driving conditions (highway vs city; mid vs high gear; WOT vs partial throttle), as well as with different mixes of E85.
Will make individual posts for each log grouping.
All logs captured with the same vehicle configuration (Map 5, Sport+, S3 DCT settings) and JB4/BEF versions (1_8_4_TEST11; S55 RACE v13).
Attached logs are running E40.
TideMD's Avatar
Car: 2016 M4
Default 09-16-2018, 05:16 PM
Logs running E20.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-17-2018, 04:35 AM
Hi Terry
Managed to get a longer run in 4th gear...😀
Default 09-17-2018, 05:40 AM
Looks pretty good!
Default 09-17-2018, 07:45 AM
Hi Terry
Is it the E85 or E85_IGN BEF?
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-17-2018, 09:29 AM
Its the s55 ign e85 bef but Im running e70.😀
Default 09-17-2018, 10:11 AM
Try the regular E85 BEF as ign isn't going as high as it we have it mapped, at least based on those two short pulls.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-17-2018, 04:14 PM
Timing should be around 12 deg up top? You think there is some knock?
I noticed my ff is climbing too after the two pulls. Ive left the duty bias unlocked as well.
Ill do a few more pulls.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-18-2018, 06:57 AM
Did another wot .. timing is getting higher now as FF still going up...
Default 09-18-2018, 06:59 AM
Looks very good, I don't see any knock. FF is learning up because you're a few psi under target. You can raise FF to 55 and get another log, that should help you hit target boost.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-18-2018, 08:09 AM
Oh ok tx Payam.. also boost taper after 6000rpm is quite normal on stock turbos?
TideMD's Avatar
Car: 2016 M4
Default 09-18-2018, 12:45 PM
Whats the deal with the FF auto-learning? Is that a basic feature, or is it activated in user settings or with certain maps?
Also, seems the duty bias auto-learning is no longer a feature with the latest firmware, correct?
Just want to make sure I have everything set properly to let the JB4 algorithm reach its optimal state and maintain safety parameters.
Default 09-18-2018, 02:18 PM
FF auto learning is on by default, do not disable it. Duty bias learning was hit and miss, do not enable it for now.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-18-2018, 04:46 PM
Oh I didnt realise this RE bias duty. So should I set DB to 50 again? You will notice my DB values set as they are from the auto learn...?
Default 09-18-2018, 05:28 PM
Yes default all to 50. And only FF will learn, at least for now. I'll revisit the duty bias learning algorithm later with the new JB4 changes made recently in mind.
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-18-2018, 07:02 PM
Ok tx Terry. Although I couldnt find any bit function for bias duty auto learn anyway unless it has been deleted in the latest firmware 😀
