(#601)
Kay-os Kay-os is offline
Car: BMW M235i
Default 04-28-2018, 08:17 PM
If your question is why do we run the N55 motors so lean it's because the fuel pump is weak and can't maintain pressure well at richer targets, and due to DI the motor tends to run better leaner, in our years of experience tuning it.
Hi Terry. Will the AFR be different (more rich?) from JB4 only vs JB4 + BEF? I'm FBO and JB4 Map 5 log AFR is about 14.8-15 at around 4000rpm and about 11.7-12 at about 6000 rpm. Will my AFR be a tad richer with the BEF? I am a newbie in tuning, and from what I have read is turbo engines should run richer to lower temps and decrease knocks.
Thanks.
2014 BMW M235i auto. JB4 & EWG connector + BEF (BMS EWG Race 10 map), 98 RON pump fuel (93 oct), BMS WMI kit (dual BM5 nozzles, 80% meth mix, boost additive 50, Scaling 60, min flow boost 7.0), GruppeM intake, ER CP, Forge BOV, Wagner Evo II competition intercooler, ER ******* **, eisenmann exhaust, quaife LSD.
Snowman Snowman is offline
Car: BMW M135I
Default 04-28-2018, 10:39 PM
Sounds like you're just confused. Obviously with the BEF we adjust the fuel trims and AFR targets. Logs in the link look as mapped.
If your trims are sticking at 50 or 0 then may want to make an adjustment. If not then AFR targets are as mapped within the BEF. Is there a link to your specific log with the "problem" you want me to look at?
Thanks for your reply Terry, however i wish it was that simple
If you look at row 19-21 in log with BEF the AFR "spikes" and at the same time the TRIMS are hitting 10-11. AFter that event the trims decrease and so does the AFR slowly.
Since ive only checked a few logs and ive only seen this in one, i guess this could be an isolated event.
But according to you the maximum value of 50 in the JB4 logs, for trim, has not changed regardless of stock flash och BEF?
I'm trying to understand what has changed since in the BEF's since i will help a friend with a custom map 6 once we flashed his car with your race-BEF..
HeikkiV HeikkiV is offline
Car: 2010 e61 n54
Default 05-02-2018, 06:31 PM
For those of us who run the JB4 CANbus wires to the harness behind the OBD port instead of using the BMS OBD connector, is it sufficient to put the JB4 on map 0 to flash? or do we need to remove the JB4 CANbus wires completely every time we want to flash a new BEF map. I have the two canbus wires positapped to the grey/blue OBD wires directly, as I know many others do.
*EDIT*: realized that MHD can't communicate with the ECU while the CANbus wires are connected. Added an in-line dual throw switch for quick-disconnect of the JB4 wires when flashing by BEF with MHD.
redbullfan redbullfan is offline
Car: 2013 F30 335i
Default 05-03-2018, 08:05 AM
Hey guys, I got MHD yesterday and installed the pwg3_race3 map and im running pwg11 on my JB4
This morning I got the following codes:
1221
0818
0001
I have 2 questions, what do these codes mean and also what is the difference between pwg3_race3 and pwg3_race3b?
Default 05-03-2018, 09:51 AM
1221
0818
0001
Select F series before reading codes, the higher the number/letter the newer the map.
Dspeed23 Dspeed23 is offline
Car: 2015 m235xi
Default 05-05-2018, 08:37 AM
If you are running just a OTS map does the JB4 have to be removed completely from the car or can you put it on Map 0 and unplug it from the OBD port? Thanks.
sku01 sku01 is offline
Car: 535i GT
Default 05-05-2018, 02:44 PM
Any help guys. Trying BEF for the first time today. Getting codes:
121002 Map sensor short to ground
123002 waste gate control short circuit to ground
120408 reduced power mode
Any ideas where I can start troubleshooting? Reflashed to Map0 then reloaded the BEF.
firmware is latest iso10 T13.
Car: 535i GT
Default 05-05-2018, 03:12 PM
Sounds like an issue with boost solenoid circuit, maybe damaged board cutting diode wrong.
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default 05-06-2018, 03:39 PM
hi terry i flashed pwg3_race3c
i have problem with afr and fph
ign very bad too
what i can do ?
thx
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
Default 05-06-2018, 05:06 PM
If FP_H is faulty you need to determine why. Did you touch the low pressure system?
dror135's Avatar
Default 05-06-2018, 10:18 PM
I have fh_l stg 2 from fuel-it
Ldenne123's Avatar
Ldenne123 Ldenne123 is offline
Car: M135i 2014 EWG JB4 MAP 2 + MHD BEF *****
Default 05-08-2018, 11:49 AM
Hi there recently done the mhd backflash following the steps provided
Just to confirm i was right in unplugging jb4 which is on map 2 ,fashing the stage 0 first then flashing the correct BEF from you list (ewg pump.8) once flashed replugg the jb4 back in and map2 , set futureused bit 6 on job done ?
Also added the cold start delete option what the opinions on this with *****, my car seems to run a little rough when first started now i have added this option
Default 05-08-2018, 12:07 PM
The order of operations doesn't matter. Cold start disabling can have side effects. If you dislike them then turn it back on.
Ldenne123's Avatar
Thumbs up 05-08-2018, 12:39 PM
Thanks for quick response terry think i will do
Car: BMW M135I
Default 05-08-2018, 01:06 PM
Pushing this up since it never got replied, hoping that Terry will spot it this time
Default 05-08-2018, 06:12 PM
Fuel trim is just one value based on JB4 settings, flash settings, including boost targets, air/fuel ratio targets, etc. If fuel trims are exceeding say 45 the you need to rescale them by raising open loop in the JB4. If open loop is already at 70, then you will need to adjust the fuel scalar settings in the BEF directly.
Bee Pee Bee Pee is offline
Car: BMW F20 m135i
Default Bmw m2 + MHD pump fuel BEF and JB4 on 98/99RON pump gas - 05-10-2018, 02:37 AM
Anyone running this set up ?
If so, how is it ?
F20 M135i EB AT with options - what a hoot !
Car: 2010 e61 n54
Default 05-11-2018, 03:17 PM
Any chance we will see a PWG1_E85 back end flash added?
Currently getting some burbles / shaking / jerking at high RPMS while running e20 with the pump BEF and the latest ISO on my FBO pwg f30. Avg_Ign higher than I'd like at around 6.5 and not sure why.
Default 05-11-2018, 04:38 PM
Just email us for it for now.
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 05-13-2018, 09:22 AM
Is it possible to get a pwg3 pump gas map?
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
dror135's Avatar
Default 05-13-2018, 09:25 AM
+1
Ldenne123's Avatar
Default 05-13-2018, 02:33 PM
Hi, new to this done a short log the other day on the jb4 bef pump , noticed my throttle reading 102% is this normal... thanks
135idct 135idct is offline
Default 05-13-2018, 07:55 PM
EWG, RACE bef.
Log
long pull to ~155 mph
Default 05-13-2018, 09:41 PM
Originally Posted by 135idct
EWG, RACE bef.
Log
Looks really healthy to me!
