George @ BMS George @ BMS is online now
Default 11-30-2017, 04:55 PM
Originally Posted by MK7GTI
The option to reduce boost on the map is very interesting for stacked cars. I'm looking to upgrade OEM IS38 to my GTI MK7 and would like to use APR with JB4 stacked this feature would be fantastic.
We doing some evaluation now on stacked cars and should put it up soon.
Istvan's Avatar
Istvan Istvan is offline
Car: Golf MK7 R, DSG, ********, Milltek Catback, Intake, ECU Flash + JB4
Default 11-30-2017, 05:11 PM
You're going to love that thing. It's so easy to use for performance metrics.
Ive got it and I love it. Its wet and cold outside so cant do any launches but still managed a 0-60 in 4.2 spinning like hell and short shifting to second at about 15mph to get som grip.
But 60-130 I managed in 11.1s, and with some further tuning with George hopefully I will be able to do a high 10s run later.
And decreasing boost on flashed ecu would be great! 👍🏼👌
For fun: Golf R MK7, DSG, Down-pipe, Milltek Exhaust, Intake, ECU Flash + JB4
Daily: Mercedes E-class Estate 2017 with AMG-pack
RafaMonteiroo's Avatar
RafaMonteiroo RafaMonteiroo is offline
Car: MK7 GTI
Default 11-30-2017, 06:20 PM
Please, I really need
2014' VW GTI DSG // Down Pipe 3" // Catback 3 // Intake K&N Inbox OEM Mod // ECU Flashed by Reiko + JB4 Stacked // Turbo IHI IS38
xperiat3 xperiat3 is offline
Car: Porsche Macan 2.0T
Default 5A firmware - 12-09-2017, 09:04 AM
Hello can anyone post 5A firmware here? Thanks
moffe moffe is offline
Car: Golf R variant mk7.5
Default 12-09-2017, 11:35 AM
You can find that on the first page, post 3
Glfdriver18 Glfdriver18 is offline
Car: 2018 Golf R
Default 01-20-2018, 08:19 PM
@George @Terry
Just installed the JB4 and updated to latest 5A FW on my 2018R.
Just checking, based on the info here should I be seeing the oil temp and DSG transmission temp with this update? Neither are working on the gauge display in the app.
Also, the gear display is super nice when in D or S mode (it’s already on the digital dash in M mode) but it would be even better if it showed the 7th gear. Since the car is obviously outputting the data (it shows 7 on the dash) hopefully this can be accomplished?
Default 01-21-2018, 07:53 AM
Originally Posted by Glfdriver18
@George @Terry
Also, the gear display is super nice when in D or S mode (its already on the digital dash in M mode) but it would be even better if it showed the 7th gear. Since the car is obviously outputting the data (it shows 7 on the dash) hopefully this can be accomplished?
The oil temp and transmission temp is not supported on the VW JB4's .
We will be adding 7th gear down the line. It should have displayed assuming the data goes +1 each gear but it seems the ECU output is different for 7th so we going to have to hunt that down.
andrescaCO andrescaCO is offline
Car: AUDI S3 2014
Default Stacking Unitronic Stage II with Big Turbo Loba472 - 01-21-2018, 04:45 PM
Dear @George
I got a JB4 to my Audi S3 2014 and I would like to improve my car to high limits due I have big turbo from Loba, could u help me to setup a map 6 to do better work.
Thks so much just waiting for your reply
Andres
Default 01-22-2018, 07:02 AM
Originally Posted by andrescaCO
Dear @George
Andres
Got your email
Car: 2018 Golf R
Default 01-22-2018, 07:50 AM
Gotcha, thanks for the reply.
I know I read elsewhere that you wanted to keep some channels open for future use and to keep the sampling rate high. FWIW however, those two items (more so oil temp than trans though) are only accessible via OBD data for the car. Since the JB4 is using that port, with no ability to split the signal to another gauge, the app is the only option for that info. It wouod be very useful to have those parameters for track work.
I hope you can find a way to add them in the future.
Default 01-22-2018, 02:19 PM
Is the oil temp not available in the in cluster display on your car?
Will look at the trans. We adding WGDC next cause many people will need that to trouble shoot leaks as the cars are getting older.
Car: 2018 Golf R
Default 01-22-2018, 06:28 PM
Awesome, thanks. Yes, oil temp is avail in the cluster display, however it 'takes over' the whole display with that one line of info, it's a massive waste of the digital dash when it could be right on the tablet screen with the other gauges. But you're correct, it can be done.
Car: MK7 GTI
Default 01-23-2018, 05:45 AM
I think it's nice to have jb4 available in oiltemp, even available in a cluster in the car, too ... the more information you have in the datalog, the better ... if you also have external temp input, it would be nice too, to compare day logs warmer or colder ...
also being available oiltemp, to make the question of boost protection by oil temperature, not water, would be safer ...
Thank you
CrAzY-HoRsE CrAzY-HoRsE is offline
Car: SEAT Leon Cupra 290 (2016)
Default 01-23-2018, 07:04 AM
I see the revision is going up on the VW_JB4_OBDII_5A file, what does it contain and is it worth installing or should I wait for an official release.
MK7GTI's Avatar
MK7GTI MK7GTI is offline
Car: GTI MK7
Default 01-23-2018, 10:22 AM
Any news about reducing the flash boost on 1st and 2nd Gear?
GTI MK7 JB4 100-200KM/H 10.9s @Dragy
Car: MK7 GTI
Default 01-24-2018, 12:23 PM
is official, with Auto Shift Redux working, to fix Overboost in Shift Gear in DSG
I Need
r_diaz13 r_diaz13 is offline
Car: Jetta GLI MK6
Default 01-30-2018, 07:11 AM
Latest VW JB4 firmware attached.
VW_JB4_OBDII_4_T2:
1) Revised fuel mapping for improved drivability and performance.
Is this latest firmware also compatible with the JB4 for a Gen3 Jetta GL2014?. I know the Gen3 motors for the Jetta and GTI are different.
Car: MK7 GTI
Default 01-30-2018, 07:18 AM
One time George told me it's the same,
Just set Future Use D to 1, as this engine works differently.
Default 01-30-2018, 10:41 AM
Its compatible to all the Gen3 motors. 5A_3 is the latest version now.
Car: Jetta GLI MK6
Default 01-30-2018, 08:11 PM
Thanks George. Im loving my car and super impressed with the results.
blackout1231 blackout1231 is offline
Car: 2014 Jetta GLI Edition 30
Default 02-06-2018, 03:37 PM
If I wanted to upgrade to the JB4 (currently have the JB1), is this the one I would order?
http://www.burgertuning.com/vw_audi_...grade_kit.html
LHD REV1 Group 4 ***B***
2014 VW Jetta GLI
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 02-21-2018, 03:22 PM
Hi, anyone having issues with the 5A firmware popping an EPC when you try to connect to the unit while the car is running? Using iOS app with rev3 bluetooth module.
E90 LCI N54 6AT
Default 02-21-2018, 05:54 PM
Hey Ben, email George, he's our resident VW pro and may have some idea. I seem to remember some similar bug at some point we fixed.
Car: MK7 GTI
Default 02-21-2018, 07:42 PM
@George @Terry
Any news for next FW?
and about reducing the DME_BT boost on 1st, 2nd and 3rd Gear?
Thx
Default 02-22-2018, 09:42 AM
Originally Posted by RafaMonteiroo
@George @Terry
Thx
Its going to take some time for that. We not to push out S4 and RS3 units next before we look at that further. Its on the list of things to do though.
