(#526)
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default 01-19-2018, 12:05 PM
thx terry ill try add e25 and log again
Is the problem due to the Compression problem ?
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 01-19-2018, 12:08 PM
Any one can answer my question?
Why did the AFR value went up after updating to the ISO firmware and how can I lower it?
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
Default 01-19-2018, 12:10 PM
Your AFR seems normal in your log for the stock flash. If you want to adjust the AFR load up our back end flash map.
dror135's Avatar
Default 01-19-2018, 12:13 PM
what is "up our back end flash map"
bm3 ?
Default 01-19-2018, 12:15 PM
bm3 ?
http://www.n54tech.com/forums/showthread.php?t=51166
alo0oy215's Avatar
Car: 2012 f30 335i
The problem is not while accelerating, it is while ideling the AFR values are changing like crazy there jumping from 13.0 to above 15.0 while the car in parked or neutral
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
dror135's Avatar
Default 01-19-2018, 12:26 PM
thats cool terry MHD
ill try this
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 01-19-2018, 12:38 PM
Terry, Still throwing the same code as before and popping the Drivetrain Malfunction. Code seems completely random, can't pinpoint it happening. The Drivetrain Malfunction happens when the motor lugs and then tries to downshift.
I'll try to get another log tonight, but theres a huge police presence today, so no promises.
Mike Levy
2017 X3 xDrive35i
dror135's Avatar
Default 01-19-2018, 12:51 PM
Where to buy the software MHD ?
dror135's Avatar
Default 01-19-2018, 12:53 PM
and btw need to unlock thr dme ?
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 01-19-2018, 01:01 PM
Terry, here are a couple logs with the slow CANbus off so normal CANbus, one 3rd gear and one shifting.
2013 BMW 335xi F30 N55 PWG
Injen CAI/ER CP/VRSF C-less DPipe/Active A FMIC/JB4 ISO_11 - Map 7/e50/Custom tuned exhaust/stock turbo/Resonator Delete/MHD BEF with JB4 e85/Stage 2 LPFP Walbro 450/JB4 BEF
Summer '19 install: Speedtech BW 8374/PI & Tune by Trebila
alo0oy215's Avatar
Car: 2012 f30 335i
Default 01-19-2018, 02:00 PM
To get the MHD license you’ll have to contact MHD, they’ll send a link for you to download the app and flash map 0 then you have to contact terry and he will provide the BEF for you
No need to unlock the DME
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
dror135's Avatar
Default 01-19-2018, 02:14 PM
can you send a link ?
for MHD
alo0oy215's Avatar
Car: 2012 f30 335i
Default 01-19-2018, 02:17 PM
for MHD
You can contact them on this email mhd.tuning@gmail.com
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
6- BMS WMI KIT
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 01-19-2018, 04:29 PM
Guys,
Going to try the ISO and cut the diode tomorrow to see if it fix the over boosting.
Is t9 the latest one right?
Also, can someone tell me if everything else beside over boosting seems good on my old firmware. Thanks.
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
Mike_L's Avatar
Anti-Social
Default 01-19-2018, 06:30 PM
Got a log. Car threw a Drivetrain Malfunction right after I shut it off, threw the low boost code again. Also, for whatever reason, the JB4Mobile isn't showing Trans Temp anymore, which is really weird because it did this afternoon.
Mike Levy
2017 X3 xDrive35i
Default 01-19-2018, 07:00 PM
Trans temp is removed for the time being, we'll bring it back later.
Your boost is no where near target. PID gain should be 25, you set it to 10. And raise FF to 120. And keep raising it until boost hits target.
Mike_L's Avatar
Anti-Social
Default 01-19-2018, 07:29 PM
Gotcha. Is there a maximum for the FF?
Mike Levy
2017 X3 xDrive35i
Default 01-19-2018, 08:30 PM
150. Could be some sort of bug also as FF is above PWM, but boost is below target. So that is strange. Let's see how pidgain = 25 looks. I'll double check the code to see if I can find any possibility for a bug like that.
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 01-20-2018, 04:24 AM
Hi Guy's, I wanted to share my first Final Log Running Trebila Performance Custom BEF Flash
I am On The ISO_9 Firmware.
Any Inputs ? I feel Trebila Made a really good job the car is like a train now
CSV Log Attached
Lamz Lamz is offline
Car: 2013 F30 335i
Default 01-20-2018, 06:09 AM
Hi guys
Any feedback on iso 9 with regards to 4psi at idle and afr spiking from 15-29. Also ecu psi spikes to like 25 psi 2000-4000 rpm when i attempt a 3rd gear log. Get knocking errors and upper boost pressure errors. Im running stock turbo, bms intake, **, c/pipe, 95 octane on my f30 335i pwg. All settings as default, ff adapted to 143, 6 cyl at 10.
Marlinman's Avatar
Car: 335i coupe 2010
Default 01-20-2018, 06:18 AM
I think there were also some people throwing low boost codes who had the 0-6 cyl timing value set too low since it now relates the throttle aggressiveness. They raised it to between 20-40 and had good success. Check this thread on page 15 ish if I remember.
Lamz, here is an excerpt from the logging parameters and their meaning...concerning AFR that is!
AFR: The AFR (Air Fuel Ratio in Lbs air/ Lbs gasoline fuel) trend displays the higher (leaner of the two
banks of three cylinders.... cylinders 1>3 or cylinders 4>6. Typical values are 15:1 at light engine
loads decreasing to around 12.5:1 under heavy engine loads and high rpm.
Note: It is normal to have the AFR display 20:1 when car is coasting in gear or under a heave
misfiring condition as the DME will cut off fuel to either the misfiring cylinder(s) or all cylinders if
coasting.
Marlinman's Avatar
Default 01-20-2018, 06:20 AM
zole: Did you notice a difference with the slow speed turned off?
I'd really like to get map 5 going and if I can turn it off and it works, then I will try it
Car: 2013 F30 335i
Default 01-20-2018, 07:47 AM
Thanks. Was concerned that with boost sitting at 4psi when the car is parked that turbo is going to be stressed for no reason. Tben building boost from 4 instead of 0 will cause overboost in the lower rev range. I have reverted to fw 17/12 for now.
Marlinman's Avatar
Default 01-20-2018, 08:12 AM
Literally just sitting there, the boost reads 4PSI? is it captured in a log? That's kinda weird...
