(#4426)
Twilly Twilly is offline
Car: 07 335i 6MT
Default 12-26-2017, 10:33 AM
hey guys im having an issue still with having jb4 control boost over wastegate pressures.
heres my log, wonder if you guys can see something im not seeing. Ive checked my lines they look fine. and I have done the proper jb4 BEF and Frimware files.
VM 6266, CKI o2 sensors, stock Map sensor
Please let me know what you think or if you guys have any other suggestions!
p.s first time posting a log so hopefully it worked
Car: 07 335i 6MT
Default 12-26-2017, 10:35 AM
wrong thread. Fail on my end.
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 12-26-2017, 09:08 PM
Update 7846 seemed to mess up the display on my iPhone 7+...
Everything is smaller now. Font, buttons, and even the whole page.
Edit- Just saw the note on the bar and circular gauge displays not being complete yet.. bummer, because I use the circular gauges normally. Tried the Needle Fill and the landscape needs a little adjustment on the right (screenshot #4).
Dantesboyz's Avatar
Dantesboyz Dantesboyz is offline
Car: 08 335i 97 332is F125KM
Default 12-27-2017, 09:56 AM
Hello all, I installed JB4 in my car back in april, bought new from BMS, last updated the program on my laptop like a month ago. I don't fiddle with settings too much, but my wife bought me this Bluetooth adapter for it for Christmas and I'm anxious to get it in there. I looked over the installation notes, doesn't look too complicated. I plan on putting the app on an older kindle fire that my daughter doesn't use anymore. I'm not the greatest software person, but trying to figure out if anyone has had issue with the kindles??? I figure screen size is decent, and if I replace it I can reload the app under the same account...it's an older kindle but as far as I know good on updates. my daughter got a new one last year so this one can basically live in my car until it dies.
BlackB's Avatar
BlackB BlackB is offline
Car: BMW e92 335i
Default 12-27-2017, 11:38 PM
Hi, You need Wi-Fi and Bluetooth. I have the Samsung Note and that works fine. It may be, the note does not find the JB4 BT mobile, then I have to restart the note, then it works! Greetings from Gernany
JB4 G5 Map7 Add-On BT Rev.3 Android/MHD V8.0 Stage2+ E85+BEF/Wagner FMIC/BMS WMI Single CM10/RB PCV/Oil Cooler/Mocal Oil Cooler Valve+STETT Line/BMS N54 DCI or SIMOTA Intake/MMP In+Alu Outlads/MMP Stage3 Turbo/BMS Oil Catch Can/NGK/M3 Cowl Filters/BMS ALU Chargepipe/Fuel-IT PI ACI or JB4 Modul+Fuel Line Y Adapter+Ethanol Sensor/Fuel-IT Stage3+Hobbs switch12,5Psi/6AT Oil Cooler xHP Software/Wavetrac/Powerflex/H&R/N20 T MAP.
BlackB's Avatar
Car: BMW e92 335i
Samsung Note4
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 12-30-2017, 06:21 PM
Originally Posted by Dmac @ BMS/DMD
Bought a Pixel 2 just for testing and on the latest beta (A207) I have zero connection issues.
The Pixel 2 and Pixel 2 XL are manufactured by different hardware companies.
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 01-04-2018, 01:06 AM
Expect a release candidate to be uploaded soon.
I have no first hand knowledge of the functionality of the kindle. Try it and let us know.
Any other Pixel 2 XL users have issues with A208?
Android users, I've started the rollout of the new public update at 20%. If you run into any issues email me at support@jb4connectkit.com.
Update Details:
Updated base sdk and all supporting code to enable better support for newer devices.
Updated settings UI.
Fixed issue with country verification.
All JB4 related code should be up-to-date with the desktop app now.
Updated permissions checks for 8.0+ devices.
BT updates.
Select All in Export window (after you tap select multiple).
Bullitt1841's Avatar
Default 01-09-2018, 06:26 PM
Originally Posted by cnm135i
Hi
EXTREMELY dificult to read the map selection with just a tiny bit of sunshine. White boxes and black writing - or something even better thanks
Huawei Nova
Android 7.0 EMUI 5.0.1
Interface A208
Mine's black on black, you've got it easy
Samsung Galaxy S5 (SM-G900V)
stalpet's Avatar
stalpet stalpet is offline
Car: BMW 640i F13
Default 01-10-2018, 12:15 AM
Hi!
Yesterday i have installed JB4 with BT Kit and i noticed the a little problem.
2011 BMW 640i F13 N55 wit PWG Harness A
JB4 latest Firmware 12/0//3
Android Huawei Mate 10 Pro
At the display gauges RPM is sometimes not available, sometimes ok and sometimes it reacts too slow and so it shows totally wrong RPM...
Boost, Gear, Map works always...
Thank you for Help!
Peter
BMW 640i F13, M-Performance Exhaust, BMS Intake, FTP Boost + Charge Pipe
Car: 2008 135i
Default 01-10-2018, 01:52 PM
Hi
Huawei Nova
Interface A208
Addressing.
Hi again
I have to restart my phone in order to open the .csv on a PC (not visible in the folder until after restart). This has been a problem since day one. Annoying, but a small thing. Can it be fixed?
Huawei Nova
Interface A208
Thanks for a great product and the support!
Nothing I can do about that. Sounds like the filesystem isn't refreshing properly.
Originally Posted by stalpet
Hi!
Thank you for Help!
Peter
Sounds like an issue at the OBDII/CANbus wiring. Email support for more help.
watercooled watercooled is offline
Car: F30
Default Rev3 slow gauge response on both Android phone & latest Ipad - 01-10-2018, 05:14 PM
My gauges update in half second intervals. does anyone know where I should begin to troubleshoot this issue? I thought the problem was my android phone, so I bought the app again on my wife's ipad and get the same response on both.
so far I have tried repositioning the rev3 antenna , and even holding the tablet right next to the JB4 in the engine, but no change in gauge response.
Every other feature works perfect, it just makes the gauge GUI useless for what im using it for.
Car: 2008 135i
Default 01-11-2018, 01:23 PM
Take a log and send it to me. Email address is in my signature.
oldmanjoe oldmanjoe is offline
Car: BMW M140i
Default 01-12-2018, 03:44 AM
Donnie I assume your watching this forum thread as well as email, I tried your suggestion of disabling BT and WiFi and then restarting. Restarted and activated bluetooth... same problem no device found. Restarted in prescribed many 10 X, same result. Tried Huaweii Y6 same result.
Both devices can see the Rev 3 kit.
Checked wiring, all looks good, besides if it wasnt transmitting no device would see it.
Only change that started this whole malarky is App Version 208.
Car: 2008 135i
Default 01-12-2018, 12:26 PM
Anyone else with a Nokia 6 or Huaweii Y6 have an issue connecting?
MDM MDM is offline
Car: M5
Default Unlink/Unregister JB4 - 01-12-2018, 09:19 PM
Question: I've sold my JB4 with Bluetooth kit...however do you need to unlink or unregister your JB4 before someone new uses JB4 on their car? If so how do unlink account?
Default 01-16-2018, 10:10 PM
Updated to 7997 and the font is so small you can barely even read it. I know you’re trying to cater to iPhone X users, but can you make the font relevant or auto-size to the iPhone pluses? Going back to 7397 again.. but what happens once it expires in less than 10 days? Will I be forced to “upgrade” (or downgrade imo) to a newer revision?
Car: 2008 135i
Default 01-16-2018, 10:23 PM
They can just email me and I'll fix it.
No biggie, I can adjust the font size. What device are you using?
Default 01-16-2018, 11:24 PM
Would appreciate it! Hopefully you’re getting feedback from others too. Let me know if I’m the only one “complaining” about things. Lol.
Using an iPhone 7plus. 7397’s (and previous) font size and layout was perfect for me. After the changes for iPhone X, things started getting a little off on the 7plus. The only thing to update on 7397 were the blue links; to make them more legible by changing them a different color for the grey background.
Car: 2008 135i
Default 01-18-2018, 11:46 AM
I don't take it as complaining so if you see an issue don't hesitate to make me aware.
More feedback from the beta community would be greatly appreciated. The more people that point out issues quickly, the faster I can address them and continue on to a public release.
Default 01-18-2018, 12:14 PM
Where do you want the beta feedback sent/posted?
Car: 2008 135i
Default 01-18-2018, 12:35 PM
I've updated my sig on here to reflect this new email address.
Default 01-18-2018, 01:12 PM
Cool. Thanks!
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 01-18-2018, 04:43 PM
I'll add it in tomorrow.
Android users:
New beta is live. LOTS of changes were made so play with it and let me know if you run into any issues. Email me at support@jb4connectkit.com with bug reports/comments.
It's on android working perfectly but Didn't see that yet on IOS or its not done yet?
Car: 2008 135i
Default 01-19-2018, 04:08 PM
iOS is basically done in the beta channel for iPhone 4S-iPhone X. Working out the last bit of UI stuff for iPad.
Android beta users:
I'll be making another beta build to help diagnose the bluetooth connection issues some of you are having after the update. Looking for ~5 people to test this with. Email me at orders@jb4connectkit.com if you'd like to be involved.
