(#901)
Tyson413 Tyson413 is offline
Car: 2012 BMW 135i
Default 10-20-2017, 06:56 PM
Hello guys. I was trying to load BEF today and I couldn’t pay 199$ for it. The payment just wasn’t going through. Does anyone had the same problem as me?
Toome's Avatar
Toome Toome is offline
Car: 2012 BMW E92 335i M-Sport
Default 10-20-2017, 10:53 PM
That’s more of a Google issue than MHD. You probably have a new google account and that’s why it’s not excepting the payment.
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | JB4 ISO | BMS Pump BEF | BMS Intake | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | Alpina Flash | Euro Headlight Switch | Avant Garde M359 | Michelin PSS
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-21-2017, 08:34 AM
We currently experience issues with Google being too aggressive at filtering out fraudulent payments.
Here you can request a call from Google, other customers revolved this issue quickly with a call, use the "Get help" button at the bottom:
https://support.google.com/googleplay/answer/1267137
Alternatively, you can get Google Play cards to make your purchases.
Purchase rejection is most of the time it is due to
- your google account being new
- your payment method that was not so far used with Google (or since a long time).
- using your account to pay on several devices.
That restriction from Google is often cleared after some days but a call from Google is much quicker.
Car: 2012 BMW 135i
Default 10-21-2017, 08:45 AM
Thank you. I’ll try again today or tomorrow.
Car: 2012 BMW 135i
Default 10-22-2017, 09:54 AM
Hey guys. I finally installed MHD BEF in my car. Everything is fine but one thing. I have
c a t l e s s d o w n p I p e s and my check engine light is on. Can you tell me why? I didn’t check the box where it says oem down pipe.
Toome's Avatar
Default 10-22-2017, 10:47 AM
Are you sure the CEL is from catalyst efficiency?
Car: 2012 BMW 135i
Default 10-22-2017, 12:58 PM
I’m pretty sure. I didn’t have it before. I installed ********* on Friday and the light came on and next day I installed MHD BEF.
Peen Peen is offline
Car: 2011 BMW 335i
Default 10-22-2017, 01:09 PM
You have to disable the code in TunerPro.
2011 335i / MHD E85 BEF / JB4 ISO / xHP Stage 3 TCU / M3 Control Arms / VRSF Piping/ Phoenix CP / YCW Coilovers 6K-18K / Enkei Raijin 18' Wheels / Michellin PSS
Car: 2012 BMW 135i
Default 10-22-2017, 01:18 PM
What is TunerPro?
Car: 2012 BMW 135i
Default 10-22-2017, 01:36 PM
I thought MHD flash should take care of that.
Car: 2011 BMW 335i
Default 10-22-2017, 02:16 PM
TunerPro is mentioned in first post. MHD is just the name of program you use to flash. The MHD maps you pay for have the *** code disabled in the .bin
The maps Terry made do not have them disabled. Very easy to do on your own though.
Car: 2012 BMW 135i
Default 10-22-2017, 03:38 PM
So can you tell me how can I disable the light?
Car: 2011 BMW 335i
Default 10-22-2017, 03:53 PM
I'll PM you.
Car: 2012 BMW 135i
Default 10-25-2017, 12:21 PM
Hey guys. Need a little help here. Does any one know how to install TunerPro to fix CEL light from my C A T L E S S D P? Or maybe be some other way?
I have 2012 135i with MHD BEF and jb4.
Car: 2011 BMW 335i
Default 10-25-2017, 12:29 PM
I already told you. You're getting 2D11, which has to do with O2 sensor and 36BE which is a coding issue. Probably can just clear that one. Or use NCSexpert to fix 36BE.
3106 is the code to toggle for ** as far as I know.
Car: 2012 BMW 135i
Default 10-25-2017, 01:04 PM
I know. I’ll fix the sensor but D P code came out too.
Car: 2012 BMW 135i
Default 10-25-2017, 01:07 PM
I meant to say I fixed the sensor.
ElJugo ElJugo is offline
Car: 2012 BMW 335i N55
Default 10-28-2017, 12:59 PM
I have a 2012 335i LCI E92 N55..... do I still have to flash the DME before doing the MHD flash ? How do i go about doing so if I have to ?
Toome's Avatar
Default 10-30-2017, 08:33 AM
From MHD’s FAQ:
go to http://www.realoem.com/bmw/enUS/select and enter the last 7 digits of your VIN in serial number. Click Browse parts the ENGINE ELECTRICAL SYSTEM and check both CONTROL UNITS > MEVD1726 section. If it says "No parts found matching your car." you have a MEVD172 which is directly flashable.
If you end up having an MEVD1726, then you will need to have your DME removed and sent out to be unlocked.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHd upate 1.24 - 11-13-2017, 02:48 PM
1.24
- Added heartbeat signals while flashing to keep other ECUs in the car happy.
- Added Torque limiters 1-2-3 log channels.
Adding the torque limiter channels confirmed what we noticed with logs that the late E series (1726 DME) have more limiters than early n55 (172 DME). We're working on those extra limiters.
Newguy123's Avatar
Car: 12' 135i
Default 11-13-2017, 03:48 PM
Originally Posted by MHD
1.24
Any idea when boost by gear and on the fly map switching is coming?
18’ Glacier white RS3
#PURETURBOS
#FUELIT
KevinC39 KevinC39 is offline
Car: 11 335i 6MT RWD
Default 11-14-2017, 04:51 AM
Or Bluetooth.
E90 N55 RWD 6MT MHD
Stoolz Stoolz is offline
Car: 11 135i
Default 11-17-2017, 01:34 PM
Or a launch option ��
Default 11-17-2017, 01:57 PM
It's been here since 2010 for the N55... Just need a JB4 installed to activate.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 11-23-2017, 07:13 AM
Map switching is being tested on an actual car.
Originally Posted by KevinC39
Or Bluetooth.
We had to restart twice from scratch for various reasons.
We'll try to adapt the F series launch.
That would get you boost curve switching. The DME maps switching is interpolating boost, but also timing, fueling, load etc. Also, 2 maps can be blended 0 to 100% with a slider on the fly.
