Default Infiniti Q50 3.0t VR30DDTT Red Sport and Silver Sport BMS Stage1 & JB4 - 05-08-2017, 02:51 PM
Order Link: http://burgertuning.com/infiniti_q50...nce_tuner.html
BMS data cable hard wired software and directionsClick here
Stage 1 Map Guide:
Map0: Stage1 disabled
Map1: Default performance map, 3psi over stock
Map3: Custom Target Map, select desired maximum boost over stock under "Boost Safety" user adjustment setting
All other maps and settings are unused
The idea behind the Stage1 is an inexpensive and easy to install/remove product that provides substantial gains with minimal headaches and trade offs. The Stage1 manipulates the ECU boost control signals allowing us to modify boost levels, but does not manipulate the ECU manifold boost reference, allowing it to properly map timing and fueling for the higher boost levels. The end result is something that runs as smoothly as stock only with higher boost targets under heavy throttle.
The Stage1 is not intended to provide the same maximum power gains you might get with a full custom ECU tune. Although based on today's dyno testing, the initial results for the Stage1 are still quite impressive. We envision a quick installation product that can be used with the factory tuning and even with aftermarket flash tuning for those looking raise boost a little in conjunction with higher octane via E85 or race gas.
For these tests we used a 30% E85 mixture, mixing in 5 gallons of E85 to a full tank of 91. Next round we will test 93 octane. With the stock tuning we were able to make ~320whp. We then used the Stage1 tune to test progressively higher boost levels, adding 4psi, 5psi, 6psi, and ultimately 7psi over stock. To my surprise each increase in boost resulted in a fairly steady increase in power, indicating plenty of tuning room within the platform.
Red Sport Dyno Results: http://www.n54tech.com/forums/showpo...6&postcount=82
Silver Sport Pump Gas Dyno Results: http://www.n54tech.com/forums/showpo...7&postcount=83
Silver Sport E85 Dyno Results:
How to connect and change map/boost level:
Quick directions:
1) Turn car on
2) Follow directions above to connect using either JB4 Mobile or BMS data cable
3) Once connected select map3 in drop down on logging page
4) Enter desired boost target on user adjustment page under boost safety and press save. Valid range is 0-8psi.
Stage 1 Firmware update (do not attempt to load on a JB4!):
Q50_STAGE1_2: Added option to adjust pedal to boost mapping using "Default Wastegate Position". Default value is 30, which represents 3.0psi. Below 3.0psi boost mapping is factory, above 3.0psi boost mapping is altered. Higher values may provide smoother but less powerful performance. When looking at your Stage1 logs DME BT represents the boost over stock. As you lower DWP you will hit your "over stock" boost target more quickly in the power band which may feel abrupt. If you raise it you'll hit your "over stock" boost target further up the power band which may feel smoother. If you raise it too high you'll never hit your full "over stock" boost target. During development we found 30 to be the best compromise set point and thus it's the default. It is now adjustable on map3. Probably best to avoid going below 10 or above 50.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 05-08-2017, 03:26 PM
JB4:
BMS data cable hard wired directions and software Click here
The JB4 is available as a complete system or as an upgrade kit to the Stage1 tuner. It adds CANbus control and other features to the Stage1 tuning allowing multiple maps based on expanded engine criteria, smoother partial throttle performance, additional engine safety systems such as lean run or over boost, more advanced logging for those wanting to experience with different fuels and E85 mixtures, boost by gear to improve traction, and much more to come via free firmware updates.
While Stage1 installs in under 60 seconds the JB4 install requires an additional OBDII cable to run through an existing grommet in the firewall adding 15-20 minutes to the process.
Note the Q50/Q60 JB4 uses different firmware and different map settings than Stage1. Details are posted in the upgrade PDF below.
JB4 Install Guide: http://www.burgertuning.com/instruct...b4_install.pdf
Stage1-> JB4 Upgrade guide: http://www.n54tech.com/flash_files/Q...B4_UPGRADE.pdf
JB4 Firmware:
Firmware updates are optional and loaded via either JB4 Mobile or a BMS data cable. We use updates to add new features, fix bugs, and make performance improvements, as documented in the firmware notes. Only the newest (highest number) firmware update is required as each firmware contains all previous updates.
Download using the new internal firmware database within JB4 Mobile or externally by clicking this link.
JB4_VR30_OBDII_7:
1) Adjustment to fuel control mapping to add more fuel at higher RPM
2) Added support for BMS WMI kit under map8
3) Added linear pedal mapping option under FutureUseD Bit7. Turn on to smooth out boost targeting as a function of gas pedal input.
4) Added custom fuel mapping option under FutureUseD Bit1. Turn on to manually adjust "fuel enrichment" offset by RPM. Default values would be 50 across the board. Not suggested for most customers to play around with or touch this.
5) Fixed bug with false AFR reading during decel.
JB4_VR30_OBDII_6:
1) Added support for JB4 fuel control wires. To enable install wires to JB4 and set FutureUseD bit0 on. Once enabled you'll see "fuel enrichment" dynamically adjust in JB4 logs as it drives AFR up to the revised targets. Setting bit0 on WITHOUT the fuel wire will not negatively effect anything, but AFR readings in logs will not be accurate.
2) Added beep confirmation indicator when changing maps. Car should beep the number of map selected.
3) Added beep confirmation indicator when saving settings. Car will double beep when saving.
JB4_Q50_OBDII_5:
1) Adjusted boost by gear to allow targeting of less than the factory (or flashed) boost target. For example a 1st gear setting of 6psi will reduce boost in 1st gear by 6psi regardless of the JB4 boost target. Very useful for those using JB4 in conjunction with flash maps that have higher boost targets.
2) Added map8 for progressive water/meth (WMI) control. Boost is held at stock levels until WMI is flowing to avoid tip in knock, boost is increased as a function of WMI flow, so that if there is a flow issue due to mechanical issue (leak, electrical failure, run out of fluid), boost will safely transition down to stock levels avoiding serious engine knock.
3) Added high fuel pressure logging under FP_H parameter. Scaling is 1 = 150psi.
4) Added high fuel pressure "target" under FP_L parameter with similar scaling. Useful for evaluating the new parameter FP_H under various power levels, fuels, and conditions. Later we'll figure out how to add actual low fuel pressure to this parameter.
5) Adjusted map3 so it's now blend of map3 and map5.
6) Adjusted map7 for increased boost target at lower engine speeds.
7) Revised partial throttle mapping for improved boost response.
JB4_Q50_OBDII_4:
1) Added oil temp to logging channels
2) Added charge air coolant temperature to logging, under "TransTemp" channel
4_1) Fixed bug in charge air coolant temp logging
JB4_Q50_OBDII_3_T1:
1) Changed map4 over to "valet map" that reduces boost 6psi over stock.
2) To avoid confusion adjusted IAT logging parameter to reflect MAF intake temperature on all models. Still working on getting charge air temperature (what we want to see!) active on all models, in addition to charge air coolant temperature.
JB4_Q50_OBDII_2:
1) Added some additional data for log analysis, for internal use
2) Adjusted CANbus module so the JB4 can continue to act as a Stage1 when OBDII port is removed or not plugged in.
JB4_Q50_OBDII_1_5:
1) Fixed bug with pedal input showing 109 at full throttle instead of 100
2) Fixed bug with air intake temperature not updating at full throttle
JB4_Q50_OBDII_1_4:
1) Enabled OBDII code read/delete using JB4 interface. Select E series N54 until a dedicated Q50/Q60 engine type is added to interface.
2) Adjusted road speed output per BETA interface. Note currently it will log in KMH, expect a toggle soon on the interface side to allow moving between KMH and MPH.
3) Enabled boost by speed. Values of 0 disables. Otherwise "1st gear" sets maximum boost added below 31mph, "2nd gear" sets maximum boost added below 55mph, and "3rd gear" sets maximum boost added below 84mph. Generally speaking this feature will be used by RWD vehicles and in most cases only in 1st gear, with a setting of say 2psi in 2nd gear to assist with traction as needed during launches.
JB4 Maps as of v5 firmware:
Map0 - JB4 disabled
Map1 - 4psi peak
Map2 - 5psi peak
Map3 - 5.5psi peak
Map4 - Low boost VALET map (200hp simulation!)
Map5 - 6psi peak
Map6 - User adjustable by RPM map using settings on user adjustment page. Setting of 5.0 would request 5psi over stock at that specific engine speed.
Map7 - 7psi peak
Map8 - Progressive WMI integrated map, boost profile under WMI flow adjustable on WMI page.
Optional fuel control wires:
Dyno Test: N54Tech.com - International Turbo Racing Discussion - View Single Post - Infiniti Q50 3.0t VR30DDTT Red Sport and Silver Sport BMS Stage1 JB4
Cliff Notes: Short fuel wire w/ resistor goes in spot 21, long wire goes in spot 20, and both wires then posi-tap to the white signal control wire in the primary o2 sensors. JB4 v6+ firmware required, to enable fuel control set FutureUseD bit0 on.
Water/Meth WMI Dyno & Details: JB4 Q50 Q60 VR30 Water/Meth (WMI) Dyno Info - N54Tech.com - International Turbo Racing Discussion
Q50/Q60 JB4 with BlueTooth kit demo:
How to attach BlueTooth kit:
How to update firmware:
Ando @ BMS's Avatar
Car: bmw 335i
Default 05-08-2017, 03:28 PM
This car is very impressive. Glad to have it as daily.
This can very well compete with B58 340i JB4 map 1.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 05-08-2017, 06:39 PM
Gotta wonder what the Red Sport would do, or if the mechanicals are any stouter.
Mike Levy
2017 X3 xDrive35i
2000 Kenne Bell F150 Lightning - FOR SALE
2018 Equinox LT 2.0T
houbmw houbmw is offline
Car: BMW n52 530i
Default 05-09-2017, 04:11 AM
WOW...thanks for the introduction to this platform.
1) Is the red sport a twin turbo compared to the 3.0 Premium being a single turbo? If you can, could you explain any major differences between the 2 models...from what I have read, the RED SPORT has extra intercooler I think.
2) Is the stock exhaust system extremely restrictive? I have seen on q50 and q60 forums that some companies are getting 20+HP and torque with just exhaust mods.
3) How is the transmission handling the power? I have a 3.7 2015 Q50 and it is a beast, but the transmission is horrible. I wish they had put the ZF 8 speed in it.
4) When you are adding boost to the 3.0 premium, how much is the stock boost...7psi? So when you adding 6 or 7 lbs of boost, total is 14/15lbs of boost...thats seems to be about what the Red Sport is pushing stock.
5) My lease ends in September and I am looking this month to get into a new Infiniti...It looks like it is better to get into a 3.0 instead of a Red Sport because of the optical sensors in the turbos. Would you state that tuning and modifications wise, 3.0 engine is better than the red sport?
Thank you again...I am looking forward to working with yall!
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 05-09-2017, 07:51 AM
This is pretty crazy good job guys!
Mods: Stock for now
Vorsprung_CJB's Avatar
Vorsprung_CJB Vorsprung_CJB is online now
Pessimistic Poster
Car: 135i N54
Default 05-09-2017, 08:34 AM
Wow 90WHP was that easy? Looks like the days of walking Infiniti's is coming to an end.
Default 05-09-2017, 10:25 AM
I hear it's roughly the same but with more aggressive tuning from the factory. But, looking forward to testing one in person one of these days.
Car: BMW n52 530i
Default 05-09-2017, 05:20 PM
https://onedrive.live.com/?authkey=%...211594&o=OneUp
https://conceptzperformance.com/blog...turbochargers/
HitmanHearns HitmanHearns is offline
Car: 2016 340i
Default 05-09-2017, 05:24 PM
This is awesome. Bye bye b58!
Mike_L's Avatar
Anti-Social
Default 05-09-2017, 06:32 PM
Based on what I'm reading, theres not all that much more in that motor as delivered. The turbos seem to be extremely small, and the way they're designed, a swap is not gonna be easy. Wonder if the heads and manifolds from the GT-R will swap, as that would make upgraded turbos much easier.
Still think I'd stick with BMW and the B58 or upcoming S58.
Mike Levy
2017 X3 xDrive35i
AUbeast86's Avatar
AUbeast86 AUbeast86 is offline
Car: 2007 335i e92 Coupe
Default 05-11-2017, 10:27 AM
Those days are here
Default 05-12-2017, 09:13 AM
It's an impressive platform and I think they also lease well like BMW. I'll stick with BMWs for my personal toys but the Q50 tuning market is going to be significant.
135idct 135idct is offline
Default 05-12-2017, 10:45 AM
if u wait few months u can get the facelift, it looks much better, the same engine.
Pessimistic Poster
Car: 135i N54
Default 05-12-2017, 12:38 PM
Was only a matter of time before the GT-R tech filtered down. Shame the only available transmission is garbage though.
Mike_L's Avatar
Anti-Social
Default 05-12-2017, 12:50 PM
Infinitis 7 speed isn't that bad. I mean its not a ZF8, but its not a Ford AODE either. Its still worlds better and quicker than anything manual.
Mike Levy
2017 X3 xDrive35i
Car: BMW n52 530i
Default 05-12-2017, 01:12 PM
The transmission sucks on this one...I have 43K on my 2014 3.7 Q50 and the transmission is the weakest link by far. Just my opinion...they could have went with something that handles a bit more torque unless they beefed up the internals somehow. This is the only thing hesitating me from getting into the Infiniti again, rather than go over to the 340i at a higher price.
Mike_L's Avatar
Anti-Social
Default 05-12-2017, 03:26 PM
I dunno. I haven't driven the Q50 I don't think (if I did it didn't leave an impact, cause I don't remember it). I did drive the M56 though when I bought my GT, which I thought used the same gearbox and it wasn't horrible. To each their own I guess.
Mike Levy
2017 X3 xDrive35i
Default 05-18-2017, 08:26 PM
Was able to get a red sport in today to checkout and tune. Same Stage1 tune worked flawlessly! Factory boost peaks at 13pi... Tuned for 91 I let it peak at 16psi. We'll get this car on the dyno next week to evaluate potential gains.
add911_11 add911_11 is offline
Car: F30 LCI 330I
Default 05-19-2017, 04:15 AM
Wow I am always interested in getting an infiniti in future... the price for Q50 Red Sport in Hong Kong is so tempting and much better then what BMW offers...
I only hope there are some well modded Q50 so to see how this beast could be turned!
Fast Intentions's Avatar
Fast Intentions Fast Intentions is offline
Car: 2014 F10 535
Default 05-24-2017, 01:57 PM
This is awesome. The market would be HUGE for a infinit version JB4. I get asked everyday when it'll be available by my friends who have these cars, most of them all red sports Sutton waiting to buy it.
Default 05-24-2017, 07:21 PM
Stage1 tunes are about ready to go. If demand is high we'll look in to Stage1->JB4 upgrade kits down the road.
Car: 2014 F10 535
Default 05-25-2017, 06:22 AM
That's great news! Gotta get this posted in the Infiniti Q50/q60 group. Except I can't do it, banned cause everyone catches feelings there lol
Car: 2014 F10 535
Default 05-25-2017, 06:24 AM
Terry get someone on the forums this **** will sell hot hot cakes!!
Default 05-25-2017, 09:09 AM
What is the main Q50 forum everyone uses?
