(#51)
Juan_BIGBOOST_TURBO's Avatar
Juan_BIGBOOST_TURBO Juan_BIGBOOST_TURBO is offline
Default 04-30-2017, 08:27 PM
Originally Posted by JB4OFF
@juan
Do we have to purchase a new ******** with the stage 3 turbo?
We include the ** with our kit.
BigBoost Instagram: @bigboostturbo
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
Current B58 record holder: Currently: 822 WHP
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
BASELINE BASELINE is offline
Car: 340i
Default 05-01-2017, 08:02 AM
I want to be excited for this but I'm having a hard time understanding a few things...and I have a feeling I'm not alone.
So up until now, the famous fuel cap had us limited to around 400whp regardless of supporting mods...this limit was understood to be fueling limit. These cars dyno stock or modified at pretty lean conditions and that seems to be what it wants...A/F in the 14s.
Now someone has slapped a big Turbo on an otherwise stock car and made an extra 130whp...with no additional fueling support while running similar A/F. 130whp extra requires a **** ton more fuel... where is it coming from if we are "capped"? Someone please explain that to me. Is the ECU being tricked somehow?
Also, looking at the log posted above, seems the throttle plate is closing hard right after the Turbo hit 25psi. And when you look at the RPM line on the chart you can tell the linear angle changes downward, you're definitely feeling that.
But what I really want to know is where is the fuel flow coming from if we were capped 130whp ago??
Am I the only one perplexed?
Shorty Shorty is offline
Car: BMW M140
Default 05-01-2017, 08:40 AM
Me too dude hence why I said the same in an earlier. Like you said all that extra air needs fuel to go with it, where's it coming from? From my limited knowledge and experience on my automatic UK M140 in gears 6th and above the AFR richens out and it starts throwing more fuel in. So possibly able to make more power in higher gears due to having more fuel available.
Would be good to see some 3rd/4th gear logs aswell as maybe 5th and 6th to compare (Although probably wanna be doing 6th gear logs on the dyno as it means doing speeds Lol)
It's pretty exciting times and I can't wait for other people to start trying new things and pushing things forward.
Default 05-01-2017, 08:46 AM
To resolve doubts about limited fuel.
We can't argue there is a fuel cap, just take a look at the AFRs and Fuel Trims, it is just too high as Terry said. We were able to run 23-24 PSI on the stock turbo, with our stage 3.2 only 18, there is actually a fuel cap.
It is also important to take into account that is not only fuel what makes power.
In all engines how well they breath is also a clue factor in power. The magic of our setup is there is no back-pressure, this because our manifold has 25% bigger runners than the stock one, also the turbine housing has a much bigger A/R, which helps the engine flow much better and have a cleaner combustion cycle, no contaminated air will produce more horsepower with the same amount of fuel we had before.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-01-2017, 09:39 AM
We made 438whp on the stock fuel system without meth, using E85, with a lean AFR. Posted the result 12/15/15... ~18 months ago. If we had used race gas instead of E85 and a larger turbo I'm sure we could hit 500whp+ on a dynojet...
http://www.n54tech.com/forums/showthread.php?p=430180
Just because you can do for a few runs on a dyno doesn't mean it's safe or that we'd ever suggest customers do it. And doesn't mean the car is going to work properly during a race.
Look at the result as promosing for the turbo. It has nothing to do with the B58 fueling and tuning limitations that are remain the main obstacle in holding back B58 performance.
Default 05-01-2017, 11:07 AM
Agree with Terry, that is why we are testing the car on the street and will be testing it at the track.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
JB4OFF JB4OFF is offline
Car: 340i
Default 05-01-2017, 11:38 AM
The real question is how does the car run with the turbo and let's say stock or map 1 for instance?
Default 05-01-2017, 05:15 PM
Map 0 it made 400 WHP
Will upload all dyno graphs later.
We just made 563 WHP.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default Dyno Graphs - 05-01-2017, 06:05 PM
We made some changes in fuel. Last time we used pump gas mixed with Sunoco 260GT Plus, and today we made some dyno runs using un-mixed Sunoco 260 GT Plus, this made significant improvements in power and torque.
Map 7
Name:  563 WHP LOG.jpg
Map 2
Name:  B58 MAP 2.jpg
Map 1
Name:  B58 MAP 1.jpg
Map 3
Name:  B58 MAP 3.jpg
Map 0
Name:  B58 MAP 0.jpg
All Maps compared
Name:  B58 All Maps.jpg
Dyno Run Video:
https://youtu.be/bfn1mtgacCw
Car Pic 1:
Car Pic 2:
Name:  M240i Dyno 2.jpg
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Weehe Weehe is offline
Default 05-01-2017, 06:49 PM
Is this a 2.0L evo? Why does it take until 4500rpms to hit full boost? Nothing about that power curve looks good. I understand you are breaking new ground with a larger turbo, but there is a lot left to be desired.
Default 05-01-2017, 07:19 PM
Name:  Stock vs 3.2 BBT B58.jpg
This is the comparison from stock to stage 3.2. Of course a larger turbo takes longer to spool, but after 3500 our kit is already making more power than stock at much less boost. If you say "full boost" you must take into account "full boost" is 25 psi, which is achieved at 4400 RPMs, but if you are having "full boost" by 20 psi you are achieving at 3700 RPMs, and if you want "full boost" by 18 psi you have it at 3400 RPMs. Also, boost is delivered in a progressive manner, you request 18 psi first and then you start delivering what's left.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-01-2017, 07:53 PM
Here we have another comparison between stock and our turbo, both in map 0, and same gears. 3rd, 4th, 5th. We can see how odd the car feels on the red (Stock) graph. You can also see there is almost no difference in the turbo response as soon as you do WOT.
Name:  B58 stock vs stage 3.2 comparison.jpg
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
N54_liam N54_liam is offline
Car: 135i e82 n54
Default 05-02-2017, 12:30 AM
Good results following this with interest. Can I run sunoco gt260 or ms109 in a 140i on jb4?
Current: M140i
Previous: N54 - Forge BOV - Forge Chargepipe - Airtec Intercooler - DCI - VRSF - JB4 - LCA
Default 05-02-2017, 06:28 AM
Yes you can run these fuels on your car, preferably MS109. This should increase the car's response and top end.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
jpsimon jpsimon is offline
Car: 335xi coupe
Default 05-02-2017, 06:41 AM
awesome results so far, keep the updates coming!
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
kern417 kern417 is offline
Car: Rocket
Default 05-02-2017, 07:53 AM
looks great to me, but dynos would be more relevant on 93 oct and 12 or so afr so people know what a daily driven tune would look like power-wise.
Default 05-02-2017, 07:56 AM
We will do these dynos next, we didn't want to risk the engine at testing, so we decided to test with higher octane first too see if everything works fine. We will do some 91 and 93 octane testing this week.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-02-2017, 08:22 AM
Excited about the work. Let's get WMI going on this car, should clean everything up.
Default 05-02-2017, 08:28 AM
We began WMI installation today, should be ready soon!
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Car: Rocket
Default 05-03-2017, 04:55 AM
party time.
Car: 335xi coupe
Default 05-08-2017, 08:42 AM
How's the install coming along?
datazap.me
Default 05-08-2017, 08:49 AM
Install is on hold, we are working on some N55 kits to be shipped this week so, as soon as we finish we will update you guys.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Car: 340i
Default 05-08-2017, 05:46 PM
Hey Juan, when are you testing the 3.3 turbo on th car? Can the 3.3 turbo be ran with stock internals? You stated on bimmerpost that you'll be testing the 3.3 with WMI
Default 05-08-2017, 06:03 PM
Hey Peter,
Yes it can run it with stock internals. We will install it along with WMI. Should be ready by Friday of this week.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 05-12-2017, 07:15 AM
Guys,
It seems like the Meth injection made a lot of difference!
We made 575 RWHP on 95 octane fuel. I will try to strap the car on the dyno again today to see if we do better with race fuel and to measure torque as the RPM signal was faulty last night.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
