(#51)
MFactory MFactory is online now
Car: BMW E92 M3
Default 01-04-2017, 08:39 AM
andym3100k: Could you PM/Email me an image?
As mentioned, it's no bother making both 6 bolt and 8 bolt.
For everyone interested, please post up with your exact month/year/model, and I will try to verify before I start a proper list.
MFactory / YCW Engineering (LSD's, Gears, Flywheels, Clutches, Driveshafts, Axles) - www.teammfactory.com
YCW Suspension (Mid-Range Coilovers) - www.ycwsuspension.com
SWIFT Springs Europe (Exclusive Distributor) - www.swiftspringseurope.com
SWIFT Springs Asia (Exclusive Distributor) - www.swiftspringsasia.com
phil1320 phil1320 is offline
Car: 2011 335is
Default 01-04-2017, 08:44 AM
I have a 2011 335is with DCT. RealOEM lists that I need 6 bolts so like I said guessing I have a 6 bolt flywheel
Car: BMW E92 M3
Default 01-04-2017, 08:48 AM
On the regular MT's, all Feb 2009+ models switched over to the 6 bolt crank, so I'm guessing if you fall into this, then you definitely have a 6 bolt.
8 bolts were only for the 2006-2008 (Jan 2009) models, so this is what we'll need to try verify. Was the DCT even available during this year range? Could possibly be a regional issue, as andym3100k is from Singapore (not the US), whose model years follow Europe.
Jeffrey Jeffrey is offline
Car: 335
Default 01-04-2017, 08:59 AM
Oh man that would explain everything. DCT wasn't available in USA until the 335is and LCI models, IRC. I hope there is still interest for the 8 bolt ones. As for my conversion to DCT this is what I will need.
Edit: even the 2008 USA Z4 models are 6 bolts according to REALOEM.
Car: BMW E92 M3
Default 01-04-2017, 09:03 AM
Yeah, andym3100k has a 2008 model, which (if going by our MT fitments) is an 8 bolt (as verified by the image he sent me)
Sometimes the info on realoem is incorrect, but I'll need to double check. If anyone in the US with a 2006-2008 model is able to physically verify, that would be great.
Car: F06 N55 640i Gran Coupe
Default 01-04-2017, 09:06 AM
Yes I think you are right, I'm in singapore RHD & we follow Euro spec. The Car was made sometime End 2008 E92 335i DCT, anyway no worries guys cos MFactory can make us 6 & 8bolts so why worry ������
Let's get the ball rolling again ��
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS ** n FULL Custom Exhaust
Custom BC forge 18/17 set up
Car: 2011 335is
Default 01-04-2017, 09:29 AM
I'm still in!! Lucky you have an 8 bolt flywheel/crank!
Car: BMW E92 M3
Default 01-04-2017, 09:42 AM
Ok, I've started an official list on post #22 (http://www.n54tech.com/forums/showpo...7&postcount=22)
Please let me know your month/year/model, and I will add you to the list
Car: 2011 335is
Default 01-04-2017, 09:46 AM
Is it $475?
Car: BMW E92 M3
Default 01-04-2017, 09:48 AM
$499.95
Newguy123's Avatar
Car: 12' 135i
Default 01-04-2017, 09:55 AM
Feb 2012 N55 DCT 135i
18 Glacier white RS3
#PURETURBOS
#FUELIT
Car: BMW E92 M3
Default 01-04-2017, 10:26 AM
Added
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 01-04-2017, 11:43 AM
OCT 2010 135i n55 dct
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
Car: BMW E92 M3
Default 01-04-2017, 12:02 PM
Added
Car: 335
Default 01-04-2017, 05:30 PM
10/08 build date, 2009 335i.
Car: BMW E92 M3
Default 01-04-2017, 05:42 PM
Added
saddart saddart is offline
Default 01-05-2017, 12:14 PM
Oct 2008 RHD DCT euro spec
Car: BMW E92 M3
Default 01-05-2017, 01:11 PM
Added
Bmstation Bmstation is offline
Car: E87 120I N54
Default 01-06-2017, 08:48 AM
1/09 build dates and after have the 6 bolts
12/08 and before have 8 bolts...
All DCT including E92 M3,135I, 335I,M2,M4,M5,M6 will fit straight in.
Why don't just seperate the weight ring off the flywheel!
Correct me if im wrong
Newguy123's Avatar
Car: 12' 135i
Default 01-06-2017, 09:06 AM
Is this possible? Anyone have one laying around that can try?
#PURETURBOS
#FUELIT
Car: E87 120I N54
Default 01-06-2017, 09:11 AM
it will work, just drill the rivets out and the ring should just fall off.
Newguy123's Avatar
Car: 12' 135i
Default 01-06-2017, 09:32 AM
any idea on the weight of that weight ring?
#PURETURBOS
#FUELIT
Kish2604's Avatar
Kish2604 Kish2604 is offline
Car: E92 335i
Default 01-06-2017, 11:13 AM
Thanks for all the background work on this M factory, just to add further information on my order/car, I have a 2009 European build e92 335i couple, the vin number is pw81836.
Still in for a flywheel!
|RB old gen|Jb4 G5|3" **'s|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
Car: E87 120I N54
Default 01-06-2017, 01:36 PM
Approx 5 Kg.
It will bring the flywheel weight from 13.0 kg down to 8.1 kg
Car: BMW E92 M3
Default 01-06-2017, 04:48 PM
Wow, yours is a difficult one, as it's a 30th Jan 2009 build, so could technically go either way (2006-01/2009 are 8 bolt, 02/2009+ are 6 bolt)!
