(#2976)
Minisi Minisi is offline
Car: e92 335i
Default 10-25-2016, 01:26 PM
Originally Posted by Icelandic
Most 2008 cars are I8A0S but there are exceptions Ive read.
A comment from MHD in the thread
"Don't worry. Go flash a IJE0S map. If your car has MSD80 and require I8A0S, MHD will refuse to flash the IJE0S map."
will give this a try. see what happens. cheers for the advice.
LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default 10-25-2016, 08:37 PM
Originally Posted by MHD
Please email me, I am doubtful about that, more recent versions of the DME can be unlocked.
My friend with X1 (Carmine sent email)
Ting e92 Ting e92 is offline
Car: 2007 E92 335i
Default 10-26-2016, 01:46 AM
[QUOTE=MHD;504404]I think that's good with 4.4 and JB4 mobile gauges and codes. Note: read codes with MHD gives more info (since it displays shadow codes such as failing HPFP). Logging/gauges with MHD gives more channels and faster sampling rate.
If use MHD display gauges can show DME speed/KM?
mkster08 mkster08 is offline
Car: 2008 335 AT
Default 10-26-2016, 06:39 AM
Anyone else not been able to hit target boost on v7 e60 map? Throttle seems to only go to 90.7% no clue why it's only on that map
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-26-2016, 02:39 PM
Yes.
BoostedSedan's Avatar
BoostedSedan BoostedSedan is offline
Car: 2008 BMW 335i E90
Default 10-26-2016, 08:20 PM
Been reading tons of these pages, can't find solid answers, just installed mhd back end for jb4 running map 2 and bought full flash module for the purpose of exhaust burble, have latest updates for app and selected aggressive 4 seconds on exhaust burble before flashing and so far haven't herd a thing after driving for a day, got the temps as hot as possible flooring it and so far haven't herd any pops or crackles. Already re flashed to stock and back to back end flash to make sure i selected the option, have ********* ** and otherwise stock exhaust, I'm in Canada and has been cold today around 3 degrees Celsius but that shouldn't be an issue right? Was really looking forward to that popcorn sound Pls Help
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 10-26-2016, 11:07 PM
Try on manual to keep it in same gear push over 3500 rpm and remove your leg from paddle and check if you hear the sound
Default 10-27-2016, 12:49 PM
Done that, even all the way to 6000 let off and not a sound just hard engine braking
cmg5461 cmg5461 is offline
Car: 2008 E90 335xi 6MT
Default 10-28-2016, 05:55 AM
V7 E25 map, partial throttle from 2500->3000 rpm induces a stumble. It's fairly obvious is gears 1-3, the effect is less 4-6.
I can't log w/ MHD because of the JB4. I'll see if I can get a JB4 log today when I leave work.
E90 335xi 6MT - Deep Green
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-28-2016, 08:04 AM
On stock catback exhaust, especially on e90-91 that have a H pipe instead of the X pipe in e92/3, you'll get better results with the gold T mod https://www.youtube.com/watch?v=7go7fK5-_6M
Sure, email that to me.
Default 10-28-2016, 11:55 PM
Golf tee mod is done, so ******* ** and golf tee on E90 equals no exhaust burble option? if i get second *** delete will it help? or is there anyway to see if the option is actually working by looking at the log, i'd be happy to post logs to see if the exhaust burble option is functioning properly.
Default 10-29-2016, 04:25 PM
After doing some more reading, think I'm gonna run full ********* exhaust and take out the resonator and weld in test *****, keeping stock mufflers
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 10-30-2016, 04:42 AM
Any updates to the jb4 backend flash in the forsee able future?
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
crazyyardie's Avatar
crazyyardie crazyyardie is offline
Default 10-30-2016, 08:01 AM
Originally Posted by JazRedGT
Any updates to the jb4 backend flash"with inlets and outlets " in the forsee able future?
+1
scratch009 scratch009 is offline
Car: E92 N54
Default 11-02-2016, 01:57 AM
I had JB4 with BEF before, now been on a MHD v7 map with JB4 set to 4-4. Been driving like this for a while. Is there an advantage to switch the white connector to original (driving-wise)? Or can I just leave it as it is?
Default 11-02-2016, 11:28 AM
Putting the subconnector back to stock lets the DME control the boost. You don't have to deal with the JB4 wastegate adaption either.
fredcase fredcase is offline
Car: 07 335xi
Default 11-06-2016, 08:56 PM
What kind of timing are these maps running. I run the race bef now and LOVE smoothness of the powerband, torque to hp. Feels almost like a n/a v8.
Do any of the non ethonal maps run more than 8deg?
2007 335i MT, JB4 G5, Hybrid Pump BEF, DCI, 6" AMS FMIC, d_p's, inlets, Chargepipe with Raceport BOV, Tomioka 16t turbos
Default 11-06-2016, 08:59 PM
You can open the BEF files in tuner pro to look at the timing curves.
Yardkidd87 Yardkidd87 is offline
Default 11-07-2016, 09:53 AM
I did the backend flash this weekend here is my log. Am running the race map.
File Type: csv 2016-11-06 06_24_01 (yarddkidd335in54).csv (14.6 KB, 108 views)
nika1993's Avatar
nika1993 nika1993 is offline
Car: bmw 535i
Default 11-07-2016, 10:59 AM
I do not understood the dimensions of gasoline. In my country there are regular, premium and super. I refuel premium. For premium which map I choose in mhd? And for bmw 535i firmware sat gearbox which item should be selected during the installation?
MooreOfDerek MooreOfDerek is offline
Car: 08 BMW 335xi
Default 11-07-2016, 11:41 AM
Yo, What mods are you running? That log has solid boost through the RPM range. Also, what gas?
icechilli icechilli is offline
Car: BMW 1M Coupe
Default 11-09-2016, 01:18 AM
I have an N54 1M with Ikmos - I have fitted the Fuel-it Port Injection with Stg3 Pump with the JB controller and Hybrid Pure Stg2 . In the MHD BEF for Ikmos there isnt a E85 PI Hybrid map like the other types.
What should i do? Will the normal E85 flash work fine?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 11-09-2016, 03:04 AM
Super is probably 91 and premium 93, but look at the RON / MON / Oct indication on the pump.
Use the stock AT option for 535i SAT.
Default 11-09-2016, 05:52 AM
Shouldn't a race map target 20 psi. Are u on map 6 or map 7. Looks like a custom map 6 that holds boost. Do you have inlet and oulets ?
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 11-09-2016, 07:45 AM
Mine pops and cracks like crazy. Turn up the aggressiveness on the exhaust option.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
